polar kinematics speed limiting code
In PolarKinematics.cpp there's something I don't understand, which might be a bug (but I'm nervous of saying that because normally when I think I've found something, it's me that's wrong).
The LimitSpeedAndAcceleration function is:
// Limit the speed and acceleration of a move to values that the mechanics can handle. // The speeds in Cartesian space have already been limited. void PolarKinematics::LimitSpeedAndAcceleration(DDA& dda, const float *normalisedDirectionVector, size_t numVisibleAxes, bool continuousRotationShortcut) const noexcept { int32_t turntableMovement = labs(dda.DriveCoordinates()[1] - dda.GetPrevious()->DriveCoordinates()[1]); if (turntableMovement != 0) { const float stepsPerDegree = reprap.GetPlatform().DriveStepsPerUnit(1); if (continuousRotationShortcut) { const int32_t stepsPerRotation = lrintf(360.0 * stepsPerDegree); if (turntableMovement > stepsPerRotation/2) { turntableMovement -= stepsPerRotation; } else if (turntableMovement < -stepsPerRotation/2) { turntableMovement += stepsPerRotation; } } if (turntableMovement != 0) { const float stepRatio = dda.GetTotalDistance() * stepsPerDegree/abs(turntableMovement); dda.LimitSpeedAndAcceleration(stepRatio * maxTurntableSpeed, stepRatio * maxTurntableAcceleration); } } }
At line 5 of the snippet, turntableMovement is set to an absolute (ie positive) number:
So then what is this doing:
This will never evaluate true:- If reprap.GetPlatform().DriveStepsPerUnit(1) is positive (which is reasonable, but I haven't checked) it plainly won't evaluate true because stepsPerRotation will be positive and turntableMovement is positive, so we have 'if [+ve number] < [-ve number]'.
- If reprap.GetPlatform().DriveStepsPerUnit(1) is negative, this won't evaluate at all because the previous
will become 'if [+ve number] > [-ve number]', so will always be true, so theelse if
will never be tested.
I think turntableMovement should be created signed, which also makes sense of the subsequent
at line 23 of the snippet. -
@achrn I agree, it looks like the labs() call should be removed. I will remove it in 3.4beta7.
