UPDATING OLD V 1.1 board TO LATEST 3.3 RELEASE
I have successfully updated the FW to 3.3 on this board I use to control my CoerXY printer. but I seem to have a troubling problem. When I got into system thru DWC and open the config.g, I'm not seeing what I know should be there. Instead I'm seeing a config.g for a Configuration file for factory testing Duet Ethernet and Wifi with V2.05.1 firmware. My config.g seems to have disappeared. THIS IS NOT GOOD TO SAY THE LEAST. Can anyone assist me?
@gbusy24 how did you update?
Sounds like you replaced the contents of the SD card with something off the internet -
@jay_s_uk I first updated from 2.05 to 3.0 by installing the Duet2 and 3 combined FW from the duet page on github like I always have. Updated to 3.0 by the same method. Worked fine that way on my new Duet 2 board I recently purchased. Used the same process. Only difference is that I hadn't set up any config.g's on it yet.
Strange thing I notice is there is a ' CoreXY sample config file for dc42 Duet firmware' in the config.g BK. folder. I have no idea what a 'BK' type file is. None of the parameters are correct for my machine. This may be something left over from 2016 when I first got the board When I first got the board.
Do you see a config.g.bak file?
Do you have a backup of your older config files?
@gbusy24 said in UPDATING OLD V 1.1 board TO LATEST 3.3 RELEASE:
Does that mean you uploaded the full zip file package, or just the firmware bin file?
@phaedrux I uploaded the complete package. Unfortunately, I do not seem to have a backup file although I sort of remember saving it 5 years ago. You know how that goes. I actually do have some backup files that I'm working on but it's difficult because they are embedded deep within some FB messenger posts with
someone 5 years ago. I might as well bite the bullet and realize I am going to have to set everything up again. I've tried the configurator but it gets pretty confusing at times. Maybe not confusing but just cumbersome is the word I will choose -
@o_lampe Thanks for that info. Wasn't aware of all that. Time to get at it then.
