RRF 3.4 input shaping preview available
@dc42 thanks for the new release. It seems that is running good, you should call the next beta "clunk free".
However i noticed i can't stop during mid-print because the firmware goes to status "generic.status.cancelling" when cancel button is pressed. From there i can't press the cancel anymore and the printer won't start a new job
M122
3/8/2021, 19:41:13 M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0beta2-inputshaping (2021-08-02 19:33:23) running on Duet WiFi 1.02 or later + DueX5 Board ID: 0JD0M-9P61A-J8PS8-6JTD2-3SJ6R-9USUU Used output buffers: 3 of 24 (24 max) === RTOS === Static ram: 23932 Dynamic ram: 76624 of which 188 recycled Never used RAM 7376, free system stack 106 words Tasks: NETWORK(ready,14.1%,217) HEAT(delaying,0.0%,326) Move(notifyWait,1.2%,277) DUEX(notifyWait,0.0%,24) MAIN(running,84.5%,420) IDLE(ready,0.1%,29), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:25:32 ago, cause: software Last software reset at 2021-08-03 19:15, reason: User, GCodes spinning, available RAM 7376, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x04 Aux0 errors 0,0,0 Step timer max interval 0 MCU temperature: min 39.5, current 40.2, max 40.7 Supply voltage: min 23.6, current 23.8, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/886/886, gc cycles 0 Driver 0: position 28800, standstill, SG min/max 0/1023 Driver 1: position -27200, standstill, SG min/max 0/1023 Driver 2: position 13510, standstill, SG min/max not available Driver 3: position 0, standstill, SG min/max 0/1023 Driver 4: position 0, standstill, SG min/max not available Driver 5: position 0, standstill, SG min/max 0/1023 Driver 6: position 0, standstill, SG min/max 0/248 Driver 7: position 0, standstill, SG min/max 0/1023 Driver 8: position 0, standstill, SG min/max 0/1023 Driver 9: position 0, standstill, SG min/max not available Driver 10: position 0 Driver 11: position 0 Date/time: 2021-08-03 19:41:13 Cache data hit count 4294967295 Slowest loop: 191.24ms; fastest: 0.14ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 1.8ms, write time 5.4ms, max retries 0 === Move === DMs created 83, segments created 46, maxWait 15496ms, bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves 10346, completed moves 10346, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 0 is on, I-accum = 0.2 Heater 1 is on, I-accum = 0.5 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === DueX === Read count 1, 0.04 reads/min === Network === Slowest loop: 209.69ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.24 WiFi MAC address 48:3f:da:79:65:eb WiFi Vcc 3.34, reset reason Power up WiFi flash size 4194304, free heap 27144 WiFi IP address 192.168.1.230 WiFi signal strength -23dBm, mode none, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
@mikes, that bug was fixed in the 3.4.0 beta 2 release.
@dc42 i lost one day and the beta is already out! thank you!
I wish to thank all who have tested the RRF input shaping previews. With your help, I believe I have the new step generation code working well including input shaping and pressure advance. This has given me the confidence to include the new code in RRF 3.4.0 beta 2 which we released today.
Please upgrade to that release, and start new threads for any issues you encounter with it.
@dc42 said in RRF 3.4 input shaping preview available:
@jenpet said in RRF 3.4 input shaping preview available:
@dc42 the two contour lines get thinner and thinner at the end so that there is a gap between them.
Now I try to lower PA value again.If you mean the two perimeter lines, they are joined in the perimeter at the top, joined for part of the length of the perimeter on the right, and not joined at all in the perimeter at the bottom. The difference between top and bottom suggests to me that you have chosen an unfortunate wall thickness and the slicer has failed to ensure consistent infill by altering the extrusion widths - so that whether the perimeters are joined or not is very sensitive to small changes. I am assuming that the thickness of all three walls is supposed to be the same.
I also have problems with pressure advance and input shaping with de PA values I already got finetuned without input shaping.
Top one: input shapping ei3 @48Hz + PA 0.1 (orbiter extruder direct)
Bottom one: just input shapping and no PA
Both 100mm/sec, 6000mm/s2 acceleration
You can see corners are ok with the PA, and bulges with no PA...
