Problem after Update
Hey,
Im jsut building another Voron V2 and i wanted to use the same Firmware Setup as in my other Printers.
But i use RRF3.2.2 on my new Build and it seems that something changed because my steppers wont work.I connectes them the same way as on my old printer.
All it does is making some noise.To check the cables i connected one Stepper to my other printer and there it works.....
Can it be that something changed from RRF3 to 3.2.2.
And if so am i able to change the firmware to 3.0?
If it try this, i get an error message that some folders are missing...
What weard, because i updated 3.2.2 on this board via de Web InterfaceThanks alot.
This post is deleted! -
Please post the results of sending M122 and M98 P"config.g".
You're sure the motor phases are paired correctly?
