Configuring S42B Close Loop Stepper Controller
@fcwilt none this was as test to see if it would return back to position. this is to help recover from layer shifts.
if nozzle gets snagged on something.. its an issue that has been a problem for me and I havent found another mechanical reason to resolve it. -
@Adamfilip said in Configuring S42B Close Loop Stepper Controller:
I've seen the nozzle get snagged on bits of the previous layer sticking up, most always in the area of the gap created by holes the are being made in a vertical section of the object.
It would be interesting to see how these devices would behave when that happened.
I may have to try closed-loop.
Thanks.
Im still trying to resolve some glitches and reached out to BIGTREETECH for support.
Sometime its working fine and sometimes they are not responding at all.. and sometimes they will vibrate very strongly. perhaps its a magnet issue..I think im going to crazy glue the magnet onto the stepper motor shaft.
What wiring configuration did you end up with?
I'm considering trying out the MKS servo42 which has similar connections.
Many thanks
Barry M -
@adamfilip the magnet placing is very sensitive, with my previous Creality and SKR boards I just could not get the distance to work right on the y-axis on my ender 5+ b/c it is a dual shaft stepper.
The x-axis always worked fine (OEM complete motor with board and screen already installed out of the box), absolute delight not to have layer shifts anymore, for example PETG blob blocking the carriage and ruining the whole print.
@arhi check if microstepping is 16, dipswitch 4 on, 123 off => press calibrate, make sure the carriage is in the middle of the axis b/c it will calibrate in both directions.
then make sure to press reset and the screen really resets, otherwise it won't work
then dip 4 off, 1 and 2 stay off and dip 3 on, that's it
I wouldn't recommend it without the OLED screen
there is one more thing which may affect you, in Marlin I had to change minimum_stepper_pulse to 3 instead of 2 and maximum_stepper_rate to 150000 from 250000
@masso said in Configuring S42B Close Loop Stepper Controller:
@arhi check if ..
not running marlin, was stepping from my own rig, very slow, like 1sec on, 1sec off, so that was not an issue... configuration and calibration were all ok, oled on all 5 drivers ... it's just not working ok, skipping steps, missing positions .. dunno if it is firmware or hw problem I gave them away my time is waaaaaaaaaaay to valuable to be wasting them on debugging PRC hw
@arhi I understand completely
BTT quality is a nightmare, don't ask me how I know. I wish I had started with RepRap and Duet board two years ago when I picked up the hobby, but then again, I've gotten an extensive education on what doesn't work and a bigger appreciation for what does.
