Help PID tuning Dyzend Pro
I don't think it's suitable for your needs. Perhaps a thermocouple would be a better solution if you really need the high temps, otherwise the 300c heater and thermistor from dyze is probably a much better choice.
@nhof Donc avec ces modification je pourrais avoir une plage entre 200c et 450c ?
@nhof I'm a little confused about why Dyze and Slice use high temp thermistors, but I guess it's a cost factor combined with the daughterboard requirements for PT and thermocouples?
@Phaedrux I'm guessing just to maximize compatibility with the greatest number of control boards. Some customers might not have good amplifier options for their systems? Or a lack of general 'industry' knowledge about other options for temp feedback.
I've used the dyze 500C thermistor before and it worked ok at high temps, on a ramps + marlin board. Haven't tried on the Duet.
These days I just use PT1000s because they works with the thermistor inputs on the duet without an addon board, and they're good enough for what I do.
@chris974M Yes, the PT100 or thermocouple should work well between 200-450C.
If you have questions on the temperature sensor components you can also check with Dyze Design. They are in Montreal, so they can help you in French as well
@nhof Thanks you
@dc42 said in Help PID tuning Dyzend Pro:
If anyone really wants to get this thermistor working with Duet 2, then I suggest you connect it to one of the thermistor inputs on the expansion connector, with a 27K reference resistor connected between the input and VRef. Then use R27000 in the M305 or M308 command.
Dear dc42, i am very interested in do this. Could you explain a little more, with a schematic?
Best Regards
@FBG said in Help PID tuning Dyzend Pro:
Best Regards
I am also using Duet Expansion Breakout Board
- Connect the thermistor between pins 35 (Thermistor3) and 40 (VSSA) of the 50-pin expansion connector
- Connect a 27K 1% tolerance resistor between pins 35 (Thermistor3 again) and pin 41 ADVREF) of the expansion connector
That's it.
would you be willing to locate the appropriate pins on a maestro for this process
@ejarmo said in Help PID tuning Dyzend Pro:
The Maestro does not have an expansion connector with thermistor inputs, so this process does not apply. You would need to desolder one of the existing 2K2 thermistor series resistors and replace it by a 27K resistor.
There is just a chance that you may be able to get the thermistor working with the existing series resistor if you use the new semi-automatic calibration procedure that firmware 3.2beta1 supports. The calibration procedure is described at https://duet3d.dozuki.com/Wiki/Calibrating_thermistor_and_PT1000_readings. Caution, if you are currently running version 2.x firmware on your Maestro then upgrading to 3.x firmware requires significant changes to the config.g file.
@chris974m said in Help PID tuning Dyzend Pro:
@dc42 @dc42 désoler pour ma très longue absence je reviens sur se sujet qui est aujourd'hui mon dernier problème que je n'avait pas fini de régler. Sur l'extension a 50 broches j'ai une duex5 de connectez comment je dois procéder ?
Merci pour vos réponsessorry for my very long absence I come back to this subject which is today my last problem that I had not finished solving. On the 50 pin extension I have a duex5 to connect how should I proceed? Thank you for your answers
See here on using the Duex
https://duet3d.dozuki.com/Wiki/Duex2_and_Duex5_Features -
@phaedrux merci pour ta réponse rapide, se n'est pas pour l'utilisation de la duex5 mais pour les branchement de la résistance 27k et de la dyzend
@chris974m, if you have a Duet Ethernet or Duet WiFi, and you do not have a DueX2 or DueX5 connected, then you can use one of the thermistor inputs on the expansion connector like this:
- Connect the thermistor between the chosen thermistor input and VSSA
- Connect the 27K resistor between the same thermistor input and VREF
@dc42 désoler encore j'ai du mal peut être a comprendre mais je ne peut pas m'en servir en ayant la duex5 de concerter
Je ne peut donc pas me servir de cette thermistance ? si quelqu'un pourrait m'aider please
Do you have a Duex 5? Yes or no?
@phaedrux Oui j’ai un duex5 de connecter
