duet 3 endstop wiring
Please reset the homing files to the ones the the configurator generated, and post them here along with your current config.g file.
@dc42 ok,
here the Z home
**; homez.g
; called to home the Z axis
; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun May 03 2020 01:01:37 GMT-0600 (Mountain Daylight Time)
G91 ; relative positioning
G1 H2 Z-5 F3000 ; lift Z relative to current position
G1 H1 Z-805 F1800 ; move Z down until the endstop is triggered
G92 Z0 ; set Z position to axis minimum (you may want to adjust this); Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 Z-5 F50 ; lift Z relative to current position
;G90 ; absolute positioning**here the Y home
; homey.g
; called to home the Y axis
G1 H1 Y255 F1800 ; move quickly to Y axis endstop and stop there (first pass)
G1 H2 Y-5 F3000 ; go back a few mm
G1 H1 Y255 F360 ; move slowly to Y axis endstop once more (second pass)
G1 H2 Z5 F3000 ; lower Z again
G90 ; absolute positioningthe X files
; homex.g
; called to home the X axis
G1 H1 X-365 F1800 ; move quickly to X axis endstop and stop there (first pass)
G1 H2 X5 F3000 ; go back a few mm
G1 H1 X-365 F360 ; move slowly to X axis endstop once more (second pass)
G90 ; absolute positioningANd my config file
**; Configuration file for Duet 3 (firmware version 3)
; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun May 03 2020 01:01:37 GMT-0600 (Mountain Daylight Time); General preferences
M550 P"The mean printer" ; set printer name; Network
M551 P"9410648" ; set password
M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
M586 P0 S1 ; enable HTTP
M586 P1 S1 ; enable FTP
M569 P0.1 S1 ; physical drive 0.1 goes forwards
M569 P0.2 S1 ; physical drive 0.2 goes forwards
M569 P0.5 S0 ; physical drive 0.5 goes backwards
M569 P0.4 S1 ; physical drive 0.4 goes forwards
M584 X0.0 Y0.1 Z0.2 E0.5:0.4 ; set drive mapping
M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
M92 X160.00 Y160.00 Z3200.00 E172.64:172.60 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
M906 X1500 Y1500 Z1200 E1500:1500 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X360 Y250 Z800 S0 ; set axis maxima; Endstops
M574 X1 S1 P"!io0.in" ; configure active-high endstop for low end on X via pin io0.in
M574 Y2 S1 P"!io2.in" ; configure active-high endstop for high end on Y via pin io2.in
M574 Z2 S1 P"!io1.in" ; configure active-high endstop for low end on Z via pin io1.in; Z-Probe
M558 P0 H-5 F120 T3000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M308 S0 P"temp3" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin temp3
M308 S1 P"spi.cs0" Y"thermocouple-max31856" ; configure sensor 1 as thermocouple via CS pin spi.cs0
M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
M143 H1 S260 ; set temperature limit for heater 1 to 260C
M308 S2 P"spi.cs1" Y"thermocouple-max31856" ; configure sensor 2 as thermocouple via CS pin spi.cs1
M950 H2 C"out2" T2 ; create nozzle heater output on out2 and map it to sensor 2
M143 H2 S290 ; set temperature limit for heater 2 to 290C
M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
M106 P0 C"extruder 1" S1 H1 T45 ; set fan 0 name and value. Thermostatic control is turned on
M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
M106 P1 C"extruder 2" S1 H2 T45 ; set fan 1 name and value. Thermostatic control is turned on
M950 F2 C"out9" Q500 ; create fan 2 on pin out9 and set its frequency
M106 P2 C"blower" S0 H-1 ; set fan 2 name and value. Thermostatic control is turned off
M950 F3 C"out6" Q500 ; create fan 3 on pin out6 and set its frequency
M106 P3 C"electrical" S1 H1:2 T30 ; set fan 3 name and value. Thermostatic control is turned on; Tools
M563 P1 D0 H1 F0 ; define tool 1
G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
M563 P2 D1 H2 F0 ; define tool 2
G10 P2 X0 Y0 Z0 ; set tool 2 axis offsets
G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C; Custom settings are not defined
T1 ; select first tool**MY bed should go down hit the limit switch and back up but nothing happen when i try to home that one but it will move when using control
Here something weird , i was trying to tune the heat bed and started homing Y actually worked like intended i didn't change anything in the config when it wasnt working 15 min earlier
So i tested something here , tried ot home the Z with heat bed OFF it move 10mm and stop , started heated bed and boom Z axis keep moving , ANy idea what G CODE i should had or remove or modify ?
You're set up to home to Z max. Where is the endstop located? Is it at the bottom when the be is closest to the nozzle or is it at the opposite end?
@Phaedrux ends stop is at the bottom the opposite side of the hot end ,
@Dad003 said in duet 3 endstop wiring:
; homez.g
;G90 ; absolute positioningOk, in that case your homez should have a positive Z movement to the endstop rather than negative.
G1 H1 Z805 F1800
So after a few frustrating days i still have problem , my Y axis and Z axis will not home , they move a little and the duet web control show as home when they didnt even touch the limit switch
here a video of the Y axis showing my problem , if i run a macro to move the axis after they home everything move fine but homing Y and Z unless they are already next to the limit switch doesnt work they start moving than stop sometime they move more like the video show . Either it a parameter that i dont see somewhere in the config but it not the gcode in the home files since the X work fine , if it neither in the file than is a firmware issue and it a big one , him running the last available firmware 3.01 RC11.
https://www.youtube.com/watch?v=VYiLlLr1R1s
; homey.g
G1 H2 Z5 F3000 ; lower Z relative to current position
G1 H2 Y-5 F3000
G1 H1 Y300 F3000 ; move quickly to Y axis endstop and stop there (first pass)
G1 H1 Y300 F360 ; move slowly to Y axis endstop once more (second pass)
G90 ; absolute positioning; homez.g
G1 H2 Z10 F3000 ; lift Z relative to current position
G1 H1 Z805 F3000 ; move Z down until the endstop is triggered
G92 Z572 ; set Z position to axis minimum (you may want to adjust this); Uncomment the following lines to lift Z after probing
;G90 ; absolute positioning; Configuration file for Duet 3 (firmware version 3)
M906 X1600 Y1600 Z1200 E1600:1600 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X360 Y250 Z572 S0 ; set axis maxima; Endstops
M308 S0 P"temp3" Y"thermistor" T100000 B4725 ; configure sensor 0 as thermistor on pin temp3
G10 P2 X0 Y34.05 Z0 ; set tool 2 axis offsets
T1 ; select first tool -
If you have physical normally closed switches, you do not need the !
Go to the "machine specific" tab and look lower right. There is a sub-screen that shows endstop status. Verify the say "No" under triggered. Then press them with your finger and be sure each says "yes" .
they are all on no and they all work , when i press them
Then the switches themselves are working and configured correctly.
Therefore, look at the homing files, or axis configuration, or other similar things.
everything move like it should be excepted the homing of Y and Z axis and g code is directly from the tools and check it and check so many time tryed to change value trying to find the problem and nothing , nothing work the homing of the Y or Z never seem to move the same distance every time i call them
here something interesting out of the 3 axis stepper , i had to make the wire longer and one motor i only did was to cut the connector to put the duet one in place , so i swapped this connector from the X that was working fine to the Y and the Y suddenly home like it should ! i got rid of the cable and than Z work like it should now , i might have a bad cable it look now
