Spurios "sensor not work" and not enough movement faults
I'm sorry, I missed your reply of 1 May. You are welcome to send it back to me for reprogramming at: Woodpeckers, Wearne, Langport TA10 0QQ. If you send just the PCB, in an antistatic bag and a padded bag, then it should be thin enough go as a large letter which will reduce the postage.
DC, OK, will do thanks. It just paused my print reporting -4% movement? IS this any sort of clue as to what the issue could be?
@dc42 I bought mine about a year ago from Filastruder and gave up when it wouldn't work. I think mine is a firmware issue as well. It's probable an early one because the serial # is 015. I have my min set really low, M591 D0 P3 C3 S1 R10:130 L24.7 E3.0. It starts off fine and prints for a while with a min of 93% and then drops to 24%, stays there for a while and eventually will drop again. If I pause it without doing anything to the filament or changing anything it goes back to normal 93%. My extrusion is fine and no clogs. Would it be possible for me to exchange it with Filastruder? I know it was a year ago but I never could get to work.
Thanks -
@chickenwoman said in Spurios "sensor not work" and not enough movement faults:
ThanksHi, sorry to hear you've had some issues, please contact Filastruder and seek an exchange. Refer them to this post as authorization. Normally it would only be a 6 month warranty window but in this instance we will do an exchange.
@Phaedrux Thank you, I appreciate it.
