RepRapFirmware 3.01-RC3 released
@c310 said in RepRapFirmware 3.01-RC3 released:
@TurtlePrint said in RepRapFirmware 3.01-RC3 released:
When sending the M112 command the printer turns off and then starts the hot end fan "fan1" at full speed
i have the same issue too. after M112 (or hardware mushroom button) printer stops, starts reboot and stucks with the cooling fan at 100% speed.
M112 has always done that. The printer should still respond to M999.
@dc42 thanks, m999 works however to do so i need to use /reprap UI, DWC remains "blocked" untill power cycle.
in old good times of 2.x firmware mushroom button not only stopped operations, but also made
web interface responsive after reset (that does not happen in 3.01-RC3 )what is a way to link m999 to emergency stop button (instead of triggering m112) without macros ?
or what can be done to run m999 after m112 generated by mushroom button ? -
@insertnamehere said in RepRapFirmware 3.01-RC3 released:
I'm using conditional code to optimized bed leveling.
On occasions when the 2 points used are equal I get an initial deviation of NAN.
3/10/2020, 11:10:16 AM Leadscrew adjustments made: -0.001 -0.001, points used 2, (mean, deviation) before (-0.001, nan) after (0.000, 0.000)
I would expect that when 2 points are the same that the standard deviation for those points would be 0. If I'm wrong, how can I test for NAN in the conditional code?
The NaNs should be gone in the internal build at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0.
When do you plan to release RC4?
I may be off track here, but the reset problem described (here and in several other threads)... I believe the fix for that is having DuetControlServer restart itself as the last action when processing an M999.
I've built a version that does that, and opened a pull request on Github in chrishamm/DuetControlServer repository.
Meanwhile, if anyone is willing to try the 1.2.4.0 version of DuetControlServer with this fix, download this file:
http://danalspub.com/wp-content/uploads/2020/03/DuetControlServer.zip
Unzip, and place the two files inside in /opt/dsf/bin
The 'DuetControlServer' file should have attributes of -rwxr-xr-x. If for some reason it does not, run chmod 755 DuetControlServer
After the copies:
sudo systemctl stop duetcontrolserver
sudo systemctl start duetcontrolserverIf you decide to go back, run:
sudo apt-get reinstall duetcontrolserver
or
sudo apt-get reinstall duetcontrolserver=specific version number you wish
You can find all available versions via:
apt-cache policy duetcontrolserver -
@Danal I'll test it later today. Thanks!
@Danal Had to recompile with your pull request because I use a 64 bit distro but it seemed to work OK.
@gtj0 said in RepRapFirmware 3.01-RC3 released:
Yeah, I compile for 32 because the Duet distro is Debian.
Thanks for checking it!! It was a one line change... "systemctl" restarts it.
DUET3-SBC/DSF Wrong print process percentage on PI/DSF
Hi guys.
My Pi shows a wrong percentage of the print progress.
PanalDue shows it right.Is this a known error?
I will reboot and reset the system and start a new print and check it again.
@dc42 said in RepRapFirmware 3.01-RC3 released:
Thanks @dc42, it works correctly now.
3/14/2020, 11:17:11 AM Leadscrew adjustments made: 0.000 0.000, points used 2, (mean, deviation) before (0.000, 0.000) after (-0.000, 0.000)
BED LEVELLING COMPLETED
Final Deviation 0.000mm -
I have been using3.01- RC3 since it was released. I have discovered what could be a bug in the way the load filament works.
The extruder runs backwards, I also have a macro to load which also runs backward.
When printing the extruder works as expected and also the extrude button on DWC works correctly.
This is my filament load:-; Load filament Real light blue
M98 P"0:/macros/Set LED Red"
if heat.heaters[1].current <190
M291 P"Please wait while the nozzle is being heated up" R"Auto Filament Load" S1 T0
M104 S195 ; Set current tool temperature to 195C
M116 S5 ; waiting for nozzle to reach temperature
M291 P"Feed Real light blue filament into the extruder by hand and click OK" R"Auto Filament Load" S3
M291 P"Loading Real-light blue filament" S1 T0 ; Display new message
G1 E10 F600 ; Feed 10mm of filament at 600mm/min
G1 E250 F3000 ; Feed 210mm of filament at 3000mm/min
G1 E20 F300 ; Feed 20mm of filament at 300mm/min
G4 S1 ; Wait one second
G1 E-3 F1800 ; Retract 10mm of filament at 1800mm/min
M400 ; Wait for the moves to finish
M104 S0 ; Set the temperature to zero
M98 P"0:/macros/Set LED Green"
M291 P"Real light blue filament Loaded" R"Auto Filament Load" S1 T0I have only noticed this since RC3, I'm sure RC2 worked properly.
Might you be in absolute extrusion mode when you run that macro? Try putting M83 at the start of it.
