RepRapFirmware 3.0 is released!
I found something odd, or it is just to late at night.
This is my heater and fan definition:
M308 S3 Y"mcu-temp" A"MCUTemp" ; configure sensor 3 as MCU Temperature
M308 S4 Y"drivers" A"DriverTemp" ; configure sensor 4 as Dirver Temperature; Fans
M950 F1 C"out8" Q500 ; create fan 0 on pin out7 and set its frequency
M106 P1 S1 H1 T45 C"Tool Fan" ; set fan 0 value. Thermostatic control is turned on
M950 F0 C"out7" Q500 ; create fan 1 on pin out8 and set its frequency
M106 P0 S0 H-1 C"Part Fan" ; set fan 1 value. Thermostatic control is turned off
M950 F2 C"!out4" ; create fan 2 on pin out4 and set its frequency
M106 P2 H3:H4 T48:60 C"MCU FAN" ; set fan 2 value. Thermostatic control is turned onI have noticed that in this config the bedtemp drives the MCU fan....like the "drivers" is using the bed temp...and not the drivers temp.
Can somebody please check?Am I missing something?
Btw. how do I activate the tacho and get and on DWC?
I have a DUET3 6HC with RRF3.0 in use
To use a 4-wire fan including the tacho, create the fan like this:
M950 F2 C"!out4+out4.tach" Q25000
Check your config by running M98 P"config.g" to see if there are any error messages. You can also send M308 S2, M308 S3 and M106 P2 to check that the settings for the electronics cooling fan and associated sensors are correct.
thx for reacting so fast.
I will check on your input.Before my last post I run the following check...
Considering that for basic setup:
M950 F2 C"!out4" -> works
M106 P2 H3:H4 T48:60 C"MCU FAN" -> shows strange behaviour as "drivers" is influenced by "bedtemp"I checked this by changing M106 to:
M106 P2 H4 T48:60 C"MCU FAN"While MCUTemp stayed at ~40°C I run the bed heating to 50°C and at 48°C the fan started running....
Then I made a recheck for only "mcutemp" like:
M106 P2 H3 T38:60 C"MCU FAN"And everything worked as supposed: as MCUtemp came below 38°C the fan turned of.
Any clues?
What temperature does Driver Temp show in DWC while you heat the bed?
0.0°C -
@Hornetrider said in RepRapFirmware 3.0 is released!:
I've just spotted the problem. You are using:
but it should be:
M106 P2 H3:4 T48:60 C"MCU FAN"
Sending M106 P2 would have revealed that it was monitoring sensors 0 and 3.
thx!
I'll give it a try later today and get back to you. -
now everything is like it should be... thx a lot! -
I have several duet 2 wifi’s on deltas and a railcore Zl and have converted the deltas to rrf3. I decided to put a maestro on a Frankenstein Ender 3 Pro that had a bltouch and v6 on it ( I first tested it with a spare duet wifi I had on hand using 2.05 and that worked perfectly). So I installed the maestro and tested using 2.05. No problems. I then upgraded to 3.0. All works perfectly except for deploy and retract probe. I added M950 S0 P”zprobe.mod” before my M558. I then changed the deployprobe.g and retractprobe.g to M280 P0 S10 and M280 P0 S90. When I went to homez, the probe didn't deploy. I tested issuing the commands in the console. Nothing. I searched here and saw that someone said they had to put the M950 command again just before the M280’s in deployprobe and retractprobe. I tried that and it works perfectly. There is no config-override file so nothing is undoing the original M950 in config.g. Any ideas on why this is happening? Thx for any help.
That are the lines for my Maestro.
Already on RRF3.01bM558 P9 C"zprobe.in" H5 F120 T3000
M950 S0 C"zprobe.mod" -
@4lathe said in RepRapFirmware 3.0 is released!:
In 3.0 the Z probe defaults to using probe.in+zprobe.mod. You need to use
M558 to make the Z probe use just zprobe.in. Only then will zprobe.mod be free to use in M950. -
Just tried that. Works fine. Might be worth a comment somewhere to tell people that M950 has to be after the M558 since it default assigns both.
On another issue, I upgraded to 3.01 no issues. I also upgraded to dwc 2.0.5 but in the system page it still shows 2.0.4.
Sorry to post on this again, but used the version on chrishamm’s github page and it now shows 2.0.5.
Thanks, I'll check which version I included in the release.
In 3.01 there is no default Z probe, so the ordering issue between M950 and M558 should not arise.
I just updated from 2.0 to 3.0 on a corexy, I used the online configurator, but the stallguard does not work, the cart does not stop, while in 2.0 it worked perfectly.
In config,g i've put :
M574 X1 S3 ; configure sensorless endstop for low end on X
M574 Y1 S3 ; configure sensorless endstop for low end on Y
M574 Z1 S2 ; configure Z-probe endstop for low end on Zand in homex.g (for example) i've put:
M915 P0:1 S0 R0 F0 H400; both motors because corexy; Sensitivity 10, don't take action, don't filter, 400steps/sec
G91 ; relative positioning
G1 H1 X-325 F1800 ; move quickly to X axis endstop and stop there (first pass)
G1 X5 F6000 ; go back a few mm
G90 ; absolute positioning -
Try upgrading to 3.01beta. I have a CoreXY tool changer running 3.01 with stall homing working on X and Y.
Also, try running M98 P"config.g" to see if it generates any error messages.
Hello everyone
I just switched to RF3I would have the following questions
How can I convert M581 S-1 into RF3?
Why does my X homing fail?
Y, Z and homeall work?
; homeall.g G91 ; relative positioning G1 H1 Z215 F1600 ; move Z up stopping at the endstop G1 H1 X-235 Y235 F4800 ; move quickly to X and Y axis endstops and stop there (first pass) G1 X5 Y-5 F6000 ; go back a few mm G1 H1 X-7.5 Y7.5 F1300 ; move slowly to X and Y axis endstops once more (second pass) G1 Z-5.0 F1400 G1 H1 Z7.5 F800 ; move Z up until the switch triggers G90 ; absolute positioning ; homex.g G91 ; relative positioning G1 H1 X-232 F4800 ; move quickly to X axis endstop and stop there (first pass) G1 X5 F6000 ; go back a few mm G1 H1 X-7.5 F1300 ; move slowly to X axis endstop once more (second pass) G90 ; absolute positioning ; homey.g G91 ; relative positioning G1 H1 Y235 F4800 ; move quickly to Y axis endstop and stop there (first pass) G1 Y-5 F6000 ; go back a few mm G1 H1 Y7.5 F1300 ; move slowly to Y axis endstop once more (second pass) G90 ; absolute positioning ; homez.g G91 ; relative positioning G1 H1 Z215 F1600 ; move Z up until the switch triggers G1 Z-5.0 F1400 G1 H1 Z7.5 F800 ; move Z up until the switch triggers G90 ; absolute positioning ; Endstops M574 X1 S1 P"!xstop" ; configure active-low endstop for low end on X via pin xstop M574 Y2 S1 P"!ystop" ; configure active-low endstop for high end on Y via pin ystop M574 Z2 S1 P"!zstop" ; configure active-low endstop for high end on Z via pin zstop
If I write H2 in this sentence
it works, but with Y, Z and homeall it is not necessary either?I'm totally keen on the meta commands, but first one by one
greetings
@zerspaner_gerd You need that H2 in there as you described for the move back a few mm. My config has these and was generated by the config tool.
