Attempting to extrude with no tool selected - During Print
With PanelDue firmware 1.23 I started to get some checksum errors as well. I had previously noticed some screen flicker. So I decided to replace the cable with a new recrimped one and now everything is fine again. No screen flicker, no checksum errors. My frame is grounded as well as the DC- of the PSU.
Perhaps some of the newer features in 1.23 are exacerbating existing poor cabling.
I have grounded my printer frame with the ground of 220V power outlet. Should I disconnect this grounding and instead connect the frame to the negative of the power supply output? Or must this connection persist and additionally the negative output connect to the frame? -
@bernie-mix said in Attempting to extrude with no tool selected - During Print:
I have grounded my printer frame with the ground of 220V power outlet. Should I disconnect this grounding and instead connect the frame to the negative of the power supply output? Or must this connection persist and additionally the negative output connect to the frame?Unless you use the USB connection regularly, it's best to connect the frame to mains ground and also connect the negative PSU output to mains ground. But if/when you use the USB connection, see https://duet3d.dozuki.com/Wiki/USB_ground_loops.
@scachi I finally got around to checking the stepper motor cables. I recrimped my second z motor and bam no more check sum errors. Thank you!
