PETG Drying
@doctrucker said in PETG Drying:
Thanks for the links. Will try at some point and report. Humidity sensor hooked up to Arduino may be investigated!
you can interface a humidity sensor to the Duet as well:
https://duet3d.dozuki.com/Wiki/Gcode#Section_M305_Set_temperature_sensor_parametersChannels 400, 401... are DHTxx temperature channels. The DATA line of the DHTxx must be connected to one of pins CS1, CS2... on the SPI bus. Specify the sensor type (11 for DHT11, 21 for DHT21 or 22 for DHT22) via the T-parameter. e.g. M305 P102 X401 T22 S"DHT temperature"
Channels 450, 451... are as 400, 401... but specify the corresponding humidity sensor of the DHTxx
So in theory you could have heaters/fans connected to a filament chamber that was controlled by the Duet and also fed the printer.
@t3p3tony sounds good, the mirror of a hopper pre-heat/dryer on a molding machine. Neat, and could keep the filament dust free too. I'll bare that in mind and ensure anything I buy for it can be ported across.
@fma said in PETG Drying:
Some companies are now making real-time filament drying:
- Fyladry (interview here: https://youtu.be/-FvGRm7I1Dc?t=307)
- Thordsen 3D (interview here: https://youtu.be/0cj6dqMgja4?t=1032)
Filadry its a scam, Fake specs and low quality product. Its like an anet dryer.
I'm not surprised. This is something I would not buy until I see good reviews with decent testing setup.
I'm the one who got @deckingman's wet PETG, I've actually used it all up now (thanks again!), and used it to drive development of my vacuum filament dryer.
Here's the writeup -
That's a very nice write-up for your vacuum dryer. I may investigate it myself. I currently use a large food dehydrator for the filament, and a small convection oven for silica gel, but they each just dump the humidity back into the room. I already have a nice vacuum pump, so I'd save on that.
Well, I have just ordered from Amazon what Deckingman posted above from Susi.
Need to try something just incase, as Phaedrux and Deckingman have suggessted it might be damp..
I printed 6 PET-G parts last night and they all were weak and the slightest presure they snapped, like a twiglet.
The PET-G was stored in an air tight bucket with silica.
I am printing a pair in the PETG-G CF which I struggled with in another post, after it had been in the airing cupboard for over 24hours, and made sure my partner did not put her washing in there!
I found 2 of the original brackets I printed in PET-G 2 weeks ago, same manufacturer as of the snapped ones, applied the same sort of pressure as I had with the ones above and increased it and they did not snap, much much stronger.
It really sounds like over cooling with the weakness between layers. Then It occured to me that the Ender 3 hotend fan blows quite a bit downward onto the parts through the gap around the heat block. Perhaps you could seal up the gap somehow.
I haven't printed PETG on my Ender 3 yet, but it seems like others do so without too much trouble. Is your ambient temp rather low? Perhaps a makeshift enclosure could help.
I am not running a part cooling fan, its about 18/19 deg C in my upstairs workshop.
This is my hotend.
Titan Aero's fan blow towards the heatsink, according to E3D that is correct.
This the outlet from the heatsink, all 4 edges.
I coud turn the fan around so it pulls the air through the heatsink.
The light blue parts were printed with the same hotend.I had a delivery today, I shall craft an enclosure!
Ah yes, you're using the Titan Aero, I forgot. I was thinking of the stock Ender.
Still, the Aero does blow downwards a bit. Especially with the stock fan. That thing is quite powerful.
Maybe give something like this a try?
https://www.thingiverse.com/thing:2325332
I used it myself before swapping the stock Aero fan for a Noctua.
@phaedrux Your a star, I shall print them tomorrow.
Wish I coulld buy you a beer or drop a bottle of your fave tipple round!
P. -
@paulhew said in PETG Drying:
Bit late now but I ordered from ebay second hand. I did also find that Aldi are currently doing desktop convection ovens for £25. No use for drying below 70. It will allow me to heat up a second hand hotend assembly that's locked up with plastic and dry silica gel at 135C.
I've three spools of cheap black PLA that O've not used for an age that probably need drying that I will start with.
If anyone else is interested in meadurong humidity have a read here:
http://www.kandrsmith.org/RJS/Misc/Hygrometers/calib_many.html
At a glance it appears the DHT22 isn't that great above 50% or a way from 25C.
No worries @DocTrucker , sometimes I would rather get something that will work and I have prime so free delivery and easy returns.
Update on Drying solution that @deckingman posted.
Bought the dehumidifier and 'cake' box.
Drilled 5 holes in the cake box and all goes together nicely.Put a roll of PETG in it as it was giving me grief and within 5mins I could see moisture inside the chamber, not lots but noticable.
Took it out after 2 hours and tried again and printed first time.Also thanks to @OBELIKS for the drying times, very useful.
@paulhew Glad that worked for you. It's still on my todo list to try (it's coming up 2 years since Susi sent me the info)
