Expansion board setup on Duet3D wifi using external controller
@dc42 says only 3 axis visable?
I'm sorry, I haven't yet found a way to view a .g file on an Android tablet. If anyone knows how to, please tell me. Otherwise I'll look at this tomorrow.
@dc42 said in Expansion board setup on Duet3D wifi using external controller:
I don't use Android myself, but one of these perhaps? https://techwiser.com/android-text-editor-for-programming/
@phaedrux said in Expansion board setup on Duet3D wifi using external controller:
The problem seems to be that the app has to declare to Android what file extensions it supports, and I haven't yet found an editor that declares .g and/or .gcode as a supported extension.
@billsrf said in Expansion board setup on Duet3D wifi using external controller:
@dc42 im using the remapping M code to set the pulse dir. But, it will not accept it. I upload it, reset the firmware and go back to check it and the step timing is not there, its not updating the settings. I am getting 3.8 volts+ and 3.7V- across the DIR+ and -. The little blue light flashes when I hit extrude like it is getting the command pulse. The motor is active mode, ie.. when it is powered, i cannot move the motor by hand. 0_1559312541048_config (1).g
From the config.g file that you posted:
M569 P0 S1 ; Physical drive X goes forwards
M569 P1 S1 ; Physical drive Y goes forwards
M569 P2 S1 ; Physical drive Z goes forwards
M569 P5 S0 ; Physical drive EXT goes backwards
M584 X0 Y1 Z2 E5 ; Apply custom drive mappingSo you have not set the step pulse timing on driver 5.
Your earlier posts suggested that when you sent M569 P5 T2.5:2.5:2.5:2.5 from the command line, it wasn't sticking, or possibly the board was resetting. Which firmware version are you using?
@dc42 here is the firmware version.
Please upgrade to firmware 2.02 and then try the M569 command again: send M569 P5 T2.5:2.5:2.5:2.5 from the command line or in config,g, then send M569 P5 from the command line and see if the correct parameters are reported.
I did as you said and it updated, but not what I typed in..??? still does not move. I went to a better driver controller but still no movement. 0_1559655180593_ACE-102_Manual_Rev_1.07.pdf 0_1559655190635_config (2).g
@dc42 is my tool map correct?
@dc42 @phaedrux it will not allow up date to active high setting either. Im very confused why it will not change settings??? I set the R to 1 as it says in the wiki, M569 P5 R1 T2.5:2.5:5.0 and it does't change anything. 0_1559665353230_M569-2.JPG
R1 on the M569 command is needed when connecting stepstick and similar drivers directly to the expansion connector of the Duet. It is not needed when connecting large external drivers via the breakout board.
The test for whether the R parameter is correct is to see whether the stepper motors are locked. With the correct setting, the motor shafts should be free to move after power up, but each motor should lock the first time you try to move it.
The step pulse timings get rounded up to the next multiple of whole step clocks. That is why the values reported by M569 are a little larger than the values you commanded.
I suspect there is an error in the M569 P5 command in your config.g file, because it looks like it has not been executed.
@dc42 ok, how do we fix the error? also, i disconnected the enable wires and it now turns CW when extrude or retract is activated.
@dc42 ok, disconnected the enable + & -. Now it works like it is supposed to. Why is this happening?
It sounds to me that the MF input of the driver is actually a disable input, not an enable input. Either add R1 to the M569 command, or swap the MF+ and MF- wires over.
@dc42 swapping the wires worked, I added the R1 to the code but it didn't work so I swapped the wires. Still confused, but at least it is working now. Thank you. How do we fix the M569 code string?
Can you confirm that you added R1 to the M569 commands for all the external drivers? For example, to the M569 P5 command. Using a separate command such as M569 P5 R1 should also have worked (and similarly for the other drivers). When you send e.g. M569 P5 to report the driver parameters, the report should change to include "active high enable".
