CoreXY: Strange jerk on Y axis.
@phaedrux Yes, the flashing light is a piezo probe. The sensor is very sensitive.
And yes, I am using mesh bed compensation. I will disable the compensation and try again. -
@phaedrux Okay, these are the result:
- Disabling the mesh compensation solves the problem
- Reducing the ammount of probe points solves the problem!
2a) On a 220x220 bed 11 probing points per axis results in the stuttering Y axis.
2b) If I use only 5 points per axis the movements are smooth
@ikarisan said in CoreXY: Strange jerk on Y axis.:
Then this is the problem.
@phaedrux said in CoreXY: Strange jerk on Y axis.:
You can see stuttering like that if the Z axis jerk is too low.
Can you post your config.g?
@phaedrux Sure.... 0_1557776986379_config.g
Z20.00 E40.00
Try increasing your jerk values for Z and E. They are super low. Remember that it's in mm/min. Try at least Z60 and E1000
@phaedrux I got the E values from: https://zestytechnology.readthedocs.io/en/latest/nimble/tuning.html but I will try your Z values.
Ah I see. In that case leavethee as it is recommended by zesty.
It seems that there is a problem with the movement if I configure many probing points.
On a 220x220 bed these parameters work fine and the Y axis does not stutter:Xmin: 20, Xmax: 200, Distance: 45
But if I use
Xmin: 20, Xmax: 200, Distance: 20
the movements on Y stutters again.
Can you post the images of your heightmap?
How fast are you traveling when it does this, and what did you end up changing your Z jerk to?
But if I use
Stuttering when bed compensation is enabled is a result of the Z jerk being set too low to permit the changes in Z speed that are demanded by changes in the height map.
