Ender 3 Pro configuration
@dc42 said in Ender 3 Pro configuration:
M305 P1 T100000 B4148 C2.117e-7
I will try right away. Thanks.
With those settings the extruder motor is skipping and the black filament i am using now seems to be really thin looking.
@baesjerker Make sure filament is Dry, filament is extremely hygroscopic, it absorbs moisture from the air EASILY. Best to make a dry box for it, I use I think tupperware containers, large ones (10 or 20 gallon) They are air tight, then I throw an Evadry (Amazon or Costco I think also sells them) reusable humidity absorber in there will my filament. If there is any moisture in your filament, due to the temperature of the nozzle during extrusion, the water instantly boils and creates bubbles, blobs, air gaps and all sorts of seemingly impossible and inconsistent problems that are a friggin nightmare to try to diagnose/troubleshoot. As a direct result of that, some of the things you could be changing could be bringing you further away from dimensional precision and worsen your print quality. A word of advise: Keep a ledger, document EVERY change, no matter how small. If you do this, reverting to old settings is effortless and there is no possible room for error. I make this easier by simply commenting out code and adding lines, instead of changing values. Just....don't forget to add comments so YOU know which settings are for what.
Assuming your filament has been properly dried (24 hours at the very least) then recalibrate your extruder. Don't even attempt this without a quality caliper, at the very least.
What are your Travel Speeds, your non-printing speeds, set to?
What is your print temperature?
DC42 is right, retraction settings are important because pla is known to ooze and you must relieve the back pressure on the nozzle and get it away from the heat of the nozzle enough for it not to come out while moving to the next print coordinate.
Temperature is equally important, however, if the temperature is too high, the filament is more of a liquid and retraction won't do a damn thing. Travel speed (non-printing moves) should also be as high as you can without creating skipping or overtravel because the the faster the nozzle gets to the target coordinate, the less time the nozzle has to ooze. Change temperature first, then travel (non-printing) speed. I usually go overboard and go with like 300-800 but make sure it's north of 250. THEN retraction speed, then retraction distance. You want retraction speed somewhere around 30-60 depending on how dialed in you are (usually), if I'm wrong about this, someone correct me.
You want retraction distance as small as possible, but with bowden I've found 4-10mm the typical range (but depends entirely how long the tube is, or even the type of filament).
Do you have
https://duet3d.dozuki.com/Wiki/Gcode#Section_M572_Set_or_report_extruder_pressure_advance
In your config? I don't recall what mine is set to, there is a thread here about an in-depth analysis of pressure advance.
What filament are you using out of curiosity? What brand?
Everything comes into play and every variable must be flawless in order to get the results you're looking for. Start eliminating variables.
carefully and methodically. It's time-consuming, yes, but we're working on automating additive manufacturing, standardizing 3D printing.
Thanks for the tips. I store my filament in a closed box, but I do not have evadry. Could Silica Gel work as a substitute? I have a high quality calliper. Travel speeds are based on the Cura profile @Phaedrux posted yesterday. I think it was 120 or something.
Thanks for that one @Phaedrux. It actually removed a lot of the stringing issue. Now it’s so much better.
I have tried temps from 180 and up to 220. Results is almost the same.
I will try some more settings in Cura. Trial and error.
I have filaments from PrimaValue (green), Addnorth (transparent), Polymaker (red) and NinjaTek (white). I also have a no brand local black one.
No I don’t have extruded pressure advance in my Config. I will check it out.
@baesjerker said in Ender 3 Pro configuration:
Pick a filament and stick with it for now so there is less variation. You are looking for consistency, stick with Polymaker for tuning, in my personal opinion and experience.
Evadry is silica dry beads, but in a thing that you can remove, plug into an outlet (it is supposed to get hot), it cooks out the moisture, and then you throw it back in the dry box. Worth every penny, I have six or seven of them around the house, three in older cars, one in the gun safe, one in a chest with documents and photos in it, and two or three in filament dry boxes. They really are so unbelievably convenient and quite very good.
With PLA, I'd recommend no more than 210. I'm typically at 190-205 range, but the cooling of the filament must be improved on the ender cuz it's crap.
120 for travel speeds are nowhere near high enough, again in my personal opinion and experience. I don't typically have overtravel issues (although I'm going to verify this with an indicator within the next two weeks). You can easily double that number without a single issue, in fact, I'd highly recommend it.
I activate the visibility of quite a LOT of settings within Cura, I control as much as I possibly can. For example, extrusion width, wall thickness, number of perimeters, connect infill lines, initial line width, infill/perimeter overlap, et cetera, et cetera.
I get high dimensional precision with a low-end printer because I take a tremendous amount of time tweaking and tuning each and every variable I can, even taking into account the compression and elongation of the thermoplastic from the extruder to the time it comes out of the nozzle. I set the XY & Z steps per mm way before plastic is ever even introduced or a heater is turned on. That way, I know the machine is accurate and I can focus on extrusion.
As of right now, my extruder steps per mm for my Ender is 94. Then the microstepping value is handled by another code entirely.
I tend not to change my steps per mm until I am absolutely certain it is not extrusion based as I try to come to my steps per mm as carefully and precisely as I can. 90% of the issues you'll encounter will usually be a result of improper slicer settings. That is why I tighten my stuff that little bit more, use solid mounts, assemble on granite, measure everything, and ultimately, why I get the results I get.
I haven't touched my printer in a while but when I finish, I'll upload my my config and slicer settings both here and on github, along with my start and end G-Code:)
Glad that's improved it for you. That Cura profile is based on the Cura profile that comes with Cura as well as some modifications to make it closer to the profile used for the demo gcode files that come on the Ender SD card as well as some tweaks of my own. It's produced some very clean prints for me.
Did you also make those changes to the config file speed settings?
@noskillzengineer great. Thank you for explaining everything in more detail. I will try to up the non printing speed and check the results. Looking forward to check out your settings.
@phaedrux i printed out a hero me fan duct yesterday and there was almost no stringing.
So it helped a lot. No, I didn’t change the speed in the config. What do I change there? Match the Cura profile? Thanks. -
What extruder motor does your printer use, and what extruder motor current have you set in M906? From another post I see that your extruder steps/mm is very low, indicating that you have an ungeared extruder. With that type of extruders, it's usually necessary to run the motor close to its rated current to get enough torque when printing PLA. OTOH if you run it too high, the heat from the motor reaches the filament and softens it, which can also lead to problems.
It’s the stock Ender 3 Pro extruder motor. I believe it’s called “Creality 3D 42-40”. It has a shaft with a adjustable gear. Current is set to 900 and steps/mm is now around 103. I tried to calibrate it and ended up with that number.
https://gist.github.com/knoopx/e6c40a009e796203b93a75a3ed6a5ab8
its a 1A motor.
