Help, stepper motor/endstops problem
@nhof thanks for the info on the date.
I was getting an error message
G0/G1 insufficient axes homed
with the end stops connected and disconnected.
They are makerbot mechanical v1. 2.
I have 2 spare ones that I might put in. May test their operation first without putting them on the printer. Just plug in and see if I get a response.
Will wait for any further advice.
Check this for wiring the makerbot switches, you may need to switch a wire.
That insufficient axes homed error happens when trying to move an axes before it's been homed.
I get this error message: "Error: G0/G1: insufficient axes homed"
Recent firmware versions do not allow axes to be moved before they have been homed. The only movements allows are homing moves (G1 moves with S1 or H1 parameter) and individual motor moves (G1 moves with S2 or H2 parameter). So any Z movements that your homing files make before Z is homed should use the S2 parameter. Alternatively, add M564 H0 to config.g to allow axis movement before homing. -
I have reinstalled the endstops and all is working there as it should, but I am still getting no control of the stepper motors. I can control the fans and heaters, all the light on the Maestro board are lit up, VIN, 5v, 3.3v, and E0 and Bed heater LEDs light up when in use.
Just
"Error: G0/G1 Insufficient axes homed".
my M122 is:
6:37:01 PMM122
RepRapFirmware for Duet 2 Maestro version 2.02(RTOS) running on Duet Maestro 1.0
Board ID: 08DAM-9F9DA-MWNS8-6J1F6-3SS6Q-KP1UW
Used output buffers: 1 of 20 (15 max)
Static ram: 19476
Dynamic ram: 92992 of which 0 recycled
Exception stack ram used: 224
Never used ram: 18380
Tasks: NETWORK(ready,672) HEAT(blocked,1324) MAIN(running,3940) IDLE(ready,204)
Owned mutexes:
Last reset 00:37:03 ago, cause: software
Last software reset at 2019-04-21 17:59, reason: Unknown, spinning module Platform, available RAM 18004 bytes (slot 0)
Software reset code 0x40b0 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0400f80f BFAR 0xe000ed38 SP 0x20000f64 Task 0x5754454e
Stack: 004042e7 00404652 21000200 000026e8 000026e8 200003e0 00404401 00000000 200003e0 200003e0 20000fe8 200000b8 00403d97 a5a5a5a5 0044a5f3 20007ee0 0044a6f9 20000750 ffffffff 00000800 20000629 200003e0 20000fe8
Error status: 0
Free file entries: 8
SD card 0 detected, interface speed: 15.0MBytes/sec
SD card longest block write time: 0.4ms, max retries 0
MCU temperature: min 31.9, current 32.2, max 32.9
Supply voltage: min 12.3, current 12.3, max 12.3, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 13844
Driver 1: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 13844
Driver 2: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 13844
Driver 3: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 13844
Driver 4: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 13843
Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 13843
Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 13844
Date/time: 2019-04-21 18:37:00
Slowest loop: 2.58ms; fastest: 0.07ms
I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 235, MinFreeDm: 235, MaxWait: 575790ms, Underruns: 0, 0
Scheduled moves: 22, completed moves: 21
Bed compensation in use: none
Bed heaters = 0, chamberHeaters = -1 -1
Segments left: 0
Stack records: 2 allocated, 1 in use
Movement lock held by http
http is idle in state(s) 1 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
lcd is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 14.00ms; fastest: 0.03ms
HTTP sessions: 1 of 8
Interface state 5, link 100Mbps full duplexand my config files is:
Configuration file for Duet Maestro (firmware version 1.21)
; generated by RepRapFirmware Configuration Tool v2 on Fri Apr 19 2019 22:05:21 GMT+0100 (British Summer Time); General preferences
M665 R58 L116 B55 H120 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them; Network
M550 P"Maestro MPMD@SBC" ; Set machine name
M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M92 X80.00 Y80.00 Z80.00 E663.00 ; Set steps per mm
M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; Set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; Set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; Set accelerations (mm/s^2)
M906 X1000.00 Y1000.00 Z1000.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
M208 Z0 S1 ; Set minimum Z; Endstops
M574 X2 Y2 Z2 S0 ; Set active low and disabled endstops; Z-Probe
M558 P5 H5 F120 I1 T6000 ; Set Z probe type to unmodulated and the dive height + speeds + invert
M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
G31 P500 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
M557 R55 S20 ; Define mesh grid; Heaters
M305 P0 T100000 B3988 ; Set thermistor + ADC parameters for heater 0
M305 P1 T100000 B3988 ; Set thermistor + ADC parameters for heater 1
M143 H1 S280 ; Set temperature limit for heater 1 to 280C; Fans
M106 P0 S0 I0 F500 H1 T90 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 S"print head" D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Automatic saving after power loss is not enabled
I have also tried entering M564 H0 in the DWI, but this still doesn't give me any control of the motors. Feel like giving up sometimes.
Do your axis actually show as homed in the DWC or on the PanelDue?
Can you post your homing files?
@Phaedrux Head position in DWI shows as n/a for all three axes, endstops showing no for triggered in machine properties, but do change to yes when i manually trip the switches.
Extruder shows as endstop triggered, but there isn't one installed. could this be causing a confllct?
homedelta.g
; called to home all towers on a delta printer
G91 ; relative positioning;*** Slow homing has been configured. Change F180 to F1800 below when your configuration is working
G1 S1 X130 Y130 Z130 F180 ; move all towers to the high end stopping at the endstops (first pass)
G1 X-5 Y-5 Z-5 F1800 S2 ; go down a few mm
;*** Slow homing has been configured. Change F180 to F360 below when your configuration is working
G1 S1 X10 Y10 Z10 F180 ; move all towers up once more (second pass)
G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
G90 ; absolute positioning
G1 X0 Y0 F6000 ; move X+Y to the centre -
One other point that may be relevant.
I am waiting for a better psu to come and am only putting a 5A supply onto the machine, but I've only ran one heater at a time, and 95%+ of my attempted axis movements have been with heaters off.
could there be insufficient power coming form the psu?
@dugee said in Help, stepper motor/endstops problem:
No that's normal.
Power should be enough to move the motors.
Can you try sending G92 X0 Y0 Z0 when the towers are at the top. This will set their position and set the axis as homed. You should then be able to move the motors.
Try sending a G1 X10 S2 to move the individual motor.
nothing, motors not responding at all.
The DWI thought the head had been homed, and the x, y and z head position changes in DWI when I use commands to move the head, but the physical head is not moving.
sorry, should have included:
10:37:30 PMG1 Y10 S2
Error: G0/G1: attempt to move individual motors of a delta machine to absolute positions -
You may need to send G91 first to put it in relative movement mode first.
Test the motors individually as described at https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter#Section_Testing_the_motors_and_endstops_individually.
@dc42 Just tried that, no movement or response, the head position in the machine status box changes but there is no actual physical movement.
@dugee, please try moving the motors again (as described in that link), then run M122 once only and post the report here.
as requested
9:28:12 AMM122
Used output buffers: 1 of 20 (13 max)
Static ram: 19476
Dynamic ram: 92932 of which 0 recycled
Exception stack ram used: 152
Never used ram: 18512
Tasks: NETWORK(ready,672) HEAT(blocked,1356) MAIN(running,3940) IDLE(ready,204)
Owned mutexes:
Last reset 00:01:55 ago, cause: power up
Last software reset at 2019-04-21 22:35, reason: User, spinning module GCodes, available RAM 18440 bytes (slot 2)
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0400f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
Error status: 0
Free file entries: 10
MCU temperature: min 16.7, current 23.4, max 23.5
Supply voltage: min 0.0, current 12.3, max 12.4, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 1495
Driver 1: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 1495
Driver 2: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 1495
Driver 3: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 1494
Driver 4: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 1494
Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 1494
Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 1494
Date/time: 2019-04-23 09:28:09
Slowest loop: 1.45ms; fastest: 0.06ms
Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
=== Network ===
Slowest loop: 5.00ms; fastest: 0.02ms
9:28:02 AMG1 S2 X-10
9:27:49 AMG92 X0 Y0 Z0
9:27:29 AMMessage Log cleared! -
@dc42 just noticed I hadn't entered G91 first. Restarted the board and performed tests again. No movement on the motors still
0:42:48 AMM122
Used output buffers: 3 of 20 (13 max)
Static ram: 19476
Exception stack ram used: 200
Never used ram: 18464
Owned mutexes:
Last reset 00:01:13 ago, cause: software
Last software reset at 2019-04-23 10:41, reason: User, spinning module GCodes, available RAM 18464 bytes (slot 3)
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04427000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
Error status: 0
MCU temperature: min 30.8, current 31.1, max 31.3
Driver 0: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 948
Driver 1: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 948
Driver 2: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 947
Driver 3: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 947
Driver 4: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 947
Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 947
Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 947
Date/time: 2019-04-23 10:42:48
Slowest loop: 1.46ms; fastest: 0.06ms
Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 239, MaxWait: 54757ms, Underruns: 0, 0
Scheduled moves: 3, completed moves: 3
Segments left: 0
=== Network ===
Slowest loop: 5.01ms; fastest: 0.03ms
10:42:43 AMG1 S2 Z-10
10:42:38 AMG1 S2 Y-10
10:42:31 AMG1 S2 X-10
10:42:14 AMG91
10:41:57 AMMessage Log cleared! -
Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 947This indicates a problem with the UART communication to the TMC2224 drivers. Assuming you don't have anything connected to the stepper driver expansion connector, I suggest you ask for your Duet to be replaced under warranty.
ok thanks @dc42 I'll fill in the form now, as I purchased direct.
