Duet Wifi unable to upload files
Been dealing with this problem for a long time, and trying to troubleshoot from other posts but I've given up and have no idea where else to go. I've done every single fix anyone has ever offhandedly mentioned.
I am completely unable to upload anything to my Duet anymore. This problem has gradually grown from being non-existent at first, to slow upload speeds, to intermittently causing issues, to being completely unable to upload anything anymore. I've tried every firmware combination imaginable, and every web control version.
Pretty sure my hardware is just broken, not sure what else I can possibly try.
Here's my M122:
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03beta3 running on Duet WiFi 1.02 or later
Board ID: 08DDM-9FAM2-LW4SD-6JKFA-3S46P-K3XHW
Used output buffers: 1 of 20 (8 max)
Static ram: 25632
Dynamic ram: 93836 of which 396 recycled
Exception stack ram used: 268
Never used ram: 10940
Tasks: NETWORK(ready,524) HEAT(blocked,1236) MAIN(running,3816) IDLE(ready,196)
Owned mutexes:
Last reset 00:06:10 ago, cause: power up
Last software reset at 2019-03-28 14:41, reason: User, spinning module GCodes, available RAM 12752 bytes (slot 3)
Error status: 0
Free file entries: 10
SD card longest block write time: 8.7ms, max retries 0
MCU temperature: min 39.5, current 39.7, max 43.0
Supply voltage: min 13.3, current 13.4, max 13.5, under voltage events: 0, over voltage events: 0, power good: yes
Date/time: 2019-03-29 11:50:07
Cache data hit count 1340612078
Slowest loop: 10.68ms; fastest: 0.07ms
I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
Hiccups: 0, FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
Bed compensation in use: none
=== MainDDARing ===
=== AuxDDARing ===
Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1
Segments left: 0, aux move: no
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 42.06ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is running
WiFi firmware version 1.21
WiFi MAC address 5c:cf:7f:ee:61:e8
WiFi Vcc 3.36, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 12896
WiFi IP address 192.168.1.85
WiFi signal strength -46dBm, reconnections 0, sleep mode modem
and my M39
SD card in slot 0: capacity 62.21Gb, free space 31.44Gb, speed 20.00MBytes/sec, cluster size 64kb
I'm using a high quality, high class SD card currently. I've tried using tons of different SD cards of various sizes and speeds and nothing fixes this problem.
- WiFi -
I believe the max acceptable size for an SD card on the Duet is 32gigs and it looks like you are using a 64 gig card so I believe a smaller size card may be needed.
Its formatted to 32gb, there's no way the Duet could possibly care. I believe the reasoning behind 32gb max is because anything past that won't allow you to do FAT32 which I have done here.
Also, I've tried that solution to no avail
What are the symptoms when you try to upload a file?
Steps to recreate my problem would be:
- Click upload&start
- Select file
- Dialog appears, shows some small amount of file instantly uploaded when using Google Chrome, then immediately freezes. If I use Edge, it never even upload the first chunk instantly.
- Timeout, upload gives up and throws error
The strangest thing is that it seemingly randomly might let me upload a file every once in a while. Sometimes it even behaves for a while. Its been behaving pretty well after making this post, even though I changed nothing. I'm sure the problem will come back though.
Are there any potential sources of radio interference during the times the uploading doesn't work? Do you live in an apartment building? Is their wifi congestion in the area? Microwaves or 2.4Ghz wireless phones being used? Are there many people in your own house using the same wifi network?
Please test writing to the SD card by sending M122 P104. You can optionally add an S parameter to specify the file size in Mb, default 10.
Also please update your WiFi firmware (DuetWiFiServer) to 1.22 or 1.23. Your M122 report shows that you are running 1.21.
@bot said in Duet Wifi unable to upload files:
No interference, and the ESP8266 is basically within 2 meters of the router. I even tried using a WiFi extender to basically make a network entirely dedicated to the print which did nothing.
@dc42 said in Duet Wifi unable to upload files:
I've tried every firmware you've mentioned here and none worked. I tried rolling back since the problem has only gotten worse over time. 1.22, 1.23, and 1.21 are all the same.
M122 Results: SD write speed for 10.0Mbyte file was 2.62Mbytes/sec
Please update DuetWiFiServer to 1.22 or 1.23, then confirm using M122 that the update succeeded:
WiFi -
Socket states: 0 0 0 0 0 0 0 0There is a known issue in 1.21 that causes problems with a small number of routers.
WiFi -
Ok I have updated back to 1.23. The problem randomly stopped happening sometime last night as it normally does, maybe by some act of god it won't come back.
If/when the problem comes back, a WireShark trace of a failed upload may help diagnose the reason.
Good idea, I'll have to try that next time. Appreciate the help and have been in love with my Duet for almost 2 years now! Thank you
@dc42 This is almost a year old, but I am now having this issue. I cannot upload files to my Duet WiFi from PrusaSlicer any more, but was in the past. I have changed routers and seeing that 1.21 had issues with some routers, I'm thinking it may be similar. It also fails when using the Upload button in the web interface. It doesn't fail at the same location.
How do you do a WireShark trace?
Firmware Electronics: Duet WiFi 1.02 or later + DueX5
Firmware Version: 2.03 (2019-06-13b2)
WiFi Server Version: 1.23
Web Interface Version: 1.22.6M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later + DueX5
Board ID: 08DGM-917DA-G4MS8-6J1F2-3S06R-T9THB
Used output buffers: 3 of 24 (8 max)
Static ram: 25680
Dynamic ram: 94148 of which 416 recycled
Exception stack ram used: 320
Never used ram: 10508
Tasks: NETWORK(ready,524) HEAT(blocked,1236) DUEX(suspended,156) MAIN(running,3748) IDLE(ready,160)
Owned mutexes:
Last reset 00:07:10 ago, cause: software
Last software reset at 2020-01-14 17:21, reason: User, spinning module GCodes, available RAM 10372 bytes (slot 0)
Error status: 0
SD card longest block write time: 6.0ms, max retries 0
MCU temperature: min 34.6, current 34.8, max 35.6
Supply voltage: min 24.2, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
Driver 5: standstill, SG min/max not available
Driver 6: standstill, SG min/max not available
Driver 7: standstill, SG min/max not available
Date/time: 2020-01-14 17:28:29
Cache data hit count 1688952282
Slowest loop: 8.35ms; fastest: 0.07ms
=== DDARing ===
Heater 1 is on, I-accum = 0.0
Segments left: 0
=== Network ===
Slowest loop: 81.74ms; fastest: 0.00ms
WiFi firmware version 1.23
WiFi MAC address
WiFi flash size 4194304, free heap 20080
WiFi IP address 192.168.1.197
WiFi signal strength -67dBm, reconnections 0, sleep mode modem
- WiFi -
