Attempt to move motors when VIN is not in range
have you got an atx power supply that you can temporarlity hook up?
@veti said in Attempt to move motors when VIN is not in range:
yes i have a 24V 15A. I hope its not to much.
@aimrabbit said in Attempt to move motors when VIN is not in range:
I already saw that in my log but i don't understand why its so different to what i get from my multimeter. My multimeter show me 12,3V and not 8,5V. Thats my problem what i don't understand.
Some possible explanations:
- VIN connections not tight.
- 3.3V rail (which is used by the Duet as the voltage reference to measure VIN) is actually at 5V. But then I would expect the microcontroller to be cooked.
- A fault with one of the 3 passive components that form the voltage divider used to measure VIN. Unlikely, but not impossible.
what i mean is, have you got another power supply that you can test. i.e. a spare one from a pc.
what i said 24V 15A is my second one.
I have made a post with a similar issue and haven't been able to solve it. I have a 24V power supply but when I look in the interface it says 0.5V and the same "attempt to move blah blah..."
OK, I changed the power supply to the 24V 15A and get 24V on my multimeter.
But again I get this from M122:
Supply voltage: min 16.4, current 16.5, max 17.2, under voltage events: 0, over voltage events: 0, power good: yesI don't understand why it drops 7,5V to nothing. I disconnect every wires to check if i have a bad item pluged in but its the same again.
A question, is it maybe possible that the PanelDue 7i take the 7,5V ?
I solved the problem! And indeed it was the PanelDue 7i which use 7,5V from the V input.
Thanks to all for helping me! -
@aimrabbit something is seriously broken, unless your PSU is WAY underpowered. i can power my i7 from USB..... meaning it doesnt take that much power,
was it miswired?
@tenjin said in Attempt to move motors when VIN is not in range:
was it miswired?
No everything with the PSU is ok but I don't have my USB wired up to the board. maybe if I do it the VIN will increase but now with the 24V PSU i've got 16,5V on VIN (Webinterface). If I meassure on the VIN screws i have 24V.
And I checked the wires and everything is like the diagram told me it should be I don't know why the PanelDue 7i is taking that much power but now the M122 said also the power is good. I will have an eye on it. I hope that nothing will burn up.
But if this not normal I appreciate everyone who can solve this miracle! -
since 12.3/8.5 = 1.44 and 24/16.5 = 1.45 are the same ratio, it is possible that there is something wrong with the resistors of the divider that measures Vin.
@genghisnico13 said in Attempt to move motors when VIN is not in range:
and what could i do to fix that?
or do i have to send it back to the shop for a replacement?
or is that no problem and i should do nothing? -
You could measure Resistors 80,81 or 15,16 (I'm not sure which pair is used to measure) that are near the always on fans connectors and 5vEnable jumper on the side of the expansion header. There should be 2 of 4.7kOhm and 2 of 47kOhm.
Although as far as I know (could be wrong) not many things are affected considerably by having a wrong input voltage reading (power loss range, heater power voltage compensation,etc) so I wouldn't consider it a big deal, but if it is a resistor it would be easy to fix.
edit: added pictures
you should see Vin/11 more of less.
same here, I don't know which side is GND so you will see 0 in one of the points.edit2: I took the pictures from the internet so they may not match your board exactly, but it should be similar.
@genghisnico13 very nice from you but without the connected PanelDue 7i i get the 24V also in the interface.
Are this two resistors for powering the display? -
@aimrabbit No, they just lower the voltage to be measured by the microcontroller. if you get 24v in DWC(Web) of M122 without the PanelDue connected then there is no need to do what I told you.
@genghisnico13 you don't know how much better i feel now! thank you thank you thank you.
Something odd is happening if connecting the PanelDue causes the VIN reading reported by DWC to drop. My best guess is that in the cable connecting PanelDue to the Duet, the Dout pin is shorted to the +5V pin. Or perhaps you are connecting the PanelDue cable to the wrong connector on the Duet?
Due to the risk of damaging the Duet, I recommend that you do not connect the PanelDue until you have resolved that.
@dc42 said in Attempt to move motors when VIN is not in range:
I found the problem. It was the two jumpers which were on the second z step. After I removed them the web shows 24V and the PanelDue is also pluged in. Maybe there is some issue in the circuit. But now everything seems to be fine. fingers crossed
Edit: Not the two jumpers are the issue. It's the 10pin cable from the PanelDue if I connect it to the Duet 2 then the voltage drops. The other 4 pin cable have no effect on the voltage.
Edit 2: Oh man shame on me... I connected the 10pin cable to the conn_lcd because of his labeling but it should connect to the conn_sd. I'm so sorry.
so glad you got it sorted, sounds like your super lucky you didnt take any thing out, sounds like a dead short caused by the wrong connection was your issue
