G-code Syntax Highlighting in Text Edit Windows
There is also Notepad++ which has a few definitions for syntax highlighting here.
http://docs.notepad-plus-plus.org/index.php/User_Defined_Language_Files
Jan
Atom is using nc-gcode as well.
NotePad++ doesn't have a Mac version sadly. Hence using Atom.
But it would be nice to get the highlighting in the browser without having to download it.
I had tried using FTP to interface with the Duet since it will launch your local editor to edit the files, but I was having problems with FTP uploads not actually completing even though they claimed they had. It would just result in a correctly named empty file.
On a Mac you should be able to use vim/vi in a terminal, there is syntax definitions for that as well.
Jan
Right. I have Atom for that on the Mac side. It's fine. But I'd like highlighting when I'm editing a macro live on the Duet in the DWC.
Oh I see, I guess that is a server side application which would require the highlighting to be implemented on the DWC end. I have not used ftp on the Duet before, just tried but have not been able to DL or UL files. Not done any troubleshooting yet.
Jan
@snoozer You'll need to ensure the FTP client is set to only use a single concurrent connection.
Ah, I interperated your question as you were looking for a replacement for Atom in ms windows. Some highlighting in the web editor would be a nice feature.
@snimax said in G-code Syntax Highlighting in Text Edit Windows:
This is for chrishamm to answer; however, implementing syntax highlighting is I think much harder in HTML/CSS/javascript than it is in a normal program or an app.
I am unable to put or get files with FTP. I can log in but put and get fails with the "PORT failed" error. Usually a sign that the client needs to use passive mode or NAT is an issue yet I am in the same subnet without firewall. I am sure its off topic just here now, I have a look through the forum what I find.
Jan
@dc42 a quick google for in browser syntax highlighting brought up a few promising options.
@snoozer said in G-code Syntax Highlighting in Text Edit Windows:
Jan
The FTP server in RRF only supports one connection. If your FTP client defaults to opening 2 connections, reconfigure it to use just one.
@phaedrux said in G-code Syntax Highlighting in Text Edit Windows:
Just found the same thing. It does have GCode listed as supported language and there also exists Vue Prism Editor to integrate it into the new UI based on Vue.
I just created a pull request..
https://github.com/chrishamm/DuetWebControl/pull/226Based on PrismJS. The only one I could find that reliably highlights gcode. Also is pretty lightweight.
Needs some testing though and I also propose a UI setting to turn it on/off, but I don't have the means to translate it to all the supported languages.
Doesn't do much besides syntax highlighting based on file extensions, but at least to me it's already a great help to have comments greyed out and commands/params highlighted..
If there's a full tree of (maintained) RRF gcodes acailable then maybe CodeMirror could be an option for a more polished WebIDE.
I also think a slight rework of the FileEditor would be helpful (custom Route instead of the Dialog so a page refresh or the back button doesn't break the Dialog), but that's a topic for another day..
If there's interest I'm open to do some slight refactoring of that feature to make it work.
@bberger Awesome!!
