big box madness
@magdi said in big box madness:
M92 X160 Y360
also are your steps correct for y?
This if from the github marlin config
define DEFAULT_AXIS_STEPS_PER_UNIT {160,180,1600,417.5} // default steps per unit for Titan BigBox -
@veti cheers for the help, have tried to change it still the same error messages
Warning: motor phase A may be disconnected reported by driver(s) 1
Warning: motor phase B may be disconnected reported by driver(s) 1 -
M906 X800 Y600 Z800 E600:600 ; Set motor currents (mA)
I am not familiar with the BigBox, but 600mA for the Y motor current sounds rather low to me. What motors are you using?
@dc42 have changed to the x axis 800 amount as this works for the X but still no fix
- just upped to 1A still no movment of the Y and Z, X still runs though at 1A
motors are 42BYGHM809 Wantai 1.7A
Warning: motor phase B may be disconnected reported by driver(s) 1Check the cable. if both phases are not connected no wonder that it does not move.
I suggest you test the motors using G1 S2 moves at low speeds (send G91 first to put axis motion in relative mode).
If you plug the X motor into the Y or Z output, can you get it to move? Power down before connecting or disconnecting motors.
Right im with you guys. Am now in the process of testing all the wires and getting the stepper sorted will then re-wire and hopefully be sorted.
Cheers for the help will confirm once complete
M574 X1 Y1 Z1.2 S1 ; set endstop configuration (X and Y endstops only, at low end, active high)
Z1.2? I don't think that's valid.
Hi @magdi,
Thanks for posting your config.g file and the model of your motor. You want to see it to no more than 1.45A.
That error normally relates to a wire being disconnected or not properly connected. As DC42 suggested try the known working X-Axis wire with either the Y or Z-Axis motor.
If that fails try plugging the known working X-Axis wire AND motor into the Y-Axis or Z-Axis port.
Best Regards
Ryan Lock
So I've unplugged every wire on the motherboard, tested everything on another motherboard including all the wires for steppers and the steppers that I've been using. They all work there. Now I plug one motor into the duet (currently working with z motors) and nothing happens. Have tried every combination of pin connection and everything ugh.
I'm just pulling my hair out at this point im so confused.What have I done wrong?!
I already made a suggestion to try to pin down the problem, but you appear to have ignored it.
@dc42 have tried that i get the same error for connection sorry I didn't reply to it so that's with putting the x axis motor on another axis.
I was just doing what you then later said but I tested all the hardware to see if it worked first
@ryan-lock thanks for the advice. I have tried moving around the x axis motor to other ports, with and without the same wire. And using that working X wire on other motors. Still the same errors unfortunately. Even got some new wires and the same issue
Let's start with getting the X motor working when it is connected to the Y motor output. Please add the following command to the start of config.g:
M584 X1 Y0
That will swap the X and Y motor outputs over. Also connect the X motor to the Y motor output, and vice versa. Then try moving X and Y again. If the X motor (connected to the Y motor output) moves correctly when you command X movement, but the Y motor (connected to the X motor output) doesn't, then it is a configuration problem. If the X motor stops working but the Y motor starts working, then it is a problem with the Y driver.
@dc42 said in big box madness:
M584 X1 Y0
right i have tried what you have advised. problem still persists with the Y driver, driving the x axis.
Thanks. Please ask your supplier to replace your Duet.
@dc42 so new board, new problems.
I cant seem to get the end stops to now work.
motors are moving fine but the end stops aren't doing their bit.have a 2 wire endstop so ive wired them on both ends of the endstop. (light starts off as red and then when the stops are engaged turns off) . have tried both X1 Y1 and X0 Y0 and the current code also on my endstop in config.g
M574 X2 Y2 S1 ; Set active high endstops
also i have an E3d hot end and am a bit confused about using the pt1000 amps? ive connected them currently straight to the duet but temps are like 2000c.
@magdi right i have made stuff do things.
problem now is when i press to 'home y' it homes y a little and also homes x.
so both axis move not just one. But then they also dont move all of the way to homing. hopefully that makes sense. -
do you mean pt100?
did you configure the m305 correctly?
@veti yes pt100 i think.
heres what i have atm but in all honesty im not sure what to configure here.M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
M305 P2 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 2
M143 H2 S280 ; Set temperature limit for heater 2 to 280C
