DuetWiFiFirmware minor release 1.15c
Ok, got it to work, this is what i ended up with for a Configuration:
; Configuration file for RepRap Ormerod
; RepRapPro Ltd
M111 S0 ; Debug on
M550 PTricolour Mendel WIFI
M551 Pgdww1620
M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xEA ; Set the MAC address
M552 S1 ; Enable WiFiM555 P2 ; Set output to look like Marlin
M575 P1 B57600 S1 ; Comms parameters for PanelDue
M906 X800 Y1000 Z800 E800:800 ; Motor currents (mA)M305 P0 R4700 T10000 B3988 ; set bed thermistor parameters
M307 H0 A117.7 C395.8 D1.8 B0
M307 H1 A759.1 C95.9 D5.8 B0M574 X0 S1 ; Set endstop configuration
M574 Y2 S0 ; Set endstop configuration
M574 Z0 S1 ; Set endstop configurationM569 P0 S0 ; Set X Axis Direction
M569 P1 S1 ; Set Y Axis Direction
M569 P2 S0 ; Set Z Axis Direction
M569 P3 S0 ; Set E0 Axis Direction
M569 P4 S0 ; Set E1 Axis DirectionM558 P1 X1 Y0 Z1 ; Set Z probe type
M92 X100.25 Y100.25 Z4001.50 E420.00:420.00 ; Set axis steps per unit
M570 S180 ; Set heater timeout
M667 S0 ; set Cartesian modeM350 X16 Y16 Z16 E16:16 I01 ; Set microstepping mode
M563 P0 D0 H1 ; Create tool 0 = Color 1
M563 P1 D1 H1 ; Create tool 1 = Color 2
M563 P2 D2 H1 ; Create tool 2 = Color 3G10 P0 X20.0 Y0.0 Z0.0 S0 R0 ; Set tool 0 operating and standby temperatures
G10 P1 X20.0 Y0.0 Z0.0 S0 R0 ; Set tool 1 operating and standby temperatures
G10 P2 X20.0 Y0.0 Z0.0 S0 R0 ; Set tool 2 operating and standby temperaturesM106 P2 T45 H1 ; Fan control, Thermostatic on Heater H1
M572 D0 S0.00 ; Set extruder 0 pressure advance
M572 D1 S0.00 ; Set extruder 1 pressure advance;M566 X600 Y600 Z5 E10 ; Set allowable instantaneous speed change
M201 X800 Y800 Z15 E1000:1000 ; acceleration tweaks for improved finish
M203 X15000 Y15000 Z150 E3600:3600 ; speed tweaks for improved finish
M208 X200 Y200 Z120 ; set axis max travel
M208 X0.0 Y0.0 Z0.0 S1 ; set axis minimum (adjust to make X=0 the edge of the bed)G21 ; Work in millimetres
G90 ; Send absolute coordinates…
M83 ; relative extruder movesG31 P500 Z1.30 ; Set the probe height and threshold PLA = 0.65, ABS = 0.75
T2
M500 ;Store setting in EEPROM -
Are you certain that setting nonzero extruder pressure advance in M572 is causing a problem? Also, have you checked on the web interface or by sending M115 that you really are running firmware version 1.15e? Firmware updates do fail sometimes.
No Actually, it just helped. Things started working right when i put the M667 S0 and the M500. I can set the M572 D0 S0.00 to something other then zero. Whats a Recommended value to start with?
oww, yes i am running firmware version 1.15e. At least that is what the web interface reads out.
Try S values between 0.05 and 0.25. If you are using more than about 2mm of retraction then be prepared to reduce it when you use high S values. For example, using S0.25 will add about 1mm of retraction at the end of a fast printing move.
Ok, i set the pressure advance to this, and started a test print
M572 D0 S0.05 ; Set extruder 0 pressure advance
M572 D1 S0.05 ; Set extruder 1 pressure advanceWhen i got to the 1.00mm Z height, the Y axes started to jump, as if it was moving, braking, moving, braking. i killed the print as it was getting pretty load and i was afraid it was going to brake the printer.
Ok, Installed the 1.16 Alfa. The Ste-per motor noise is Still there. I did notes its only on coordinated moves. I can calibrate, move the table around and extrude and all is well. But i run a Print and the noise is there. Note - don't get me wrong this is not machanical, its motor drive control
OK, This probably needs to be under the next release of the Firmware (dc42/Version 1.16 beta 2), but i could not find a Blog or forum for it. So hear is the info:
- Ste-per motor noise is down to a Dull rorre (Sounds like a Skipping Hart beet). Its still coming out of extrude motor when i listen to it through a Sc-row driver handle.
Temperature control, the best i can do with Auto-tune is the hot end doing +- 0.3. it is holding that. at lest for the short print times i have been testing.
Going to let this test print finish to see if it finushes.
you have
Should it not be
M350 X16 Y16 Z16 E16:16 I1 ; Set microstepping mode
or
M350 X16 Y16 Z16 E16:16 I0 ; Set microstepping mode
Depending on whether or not you are using interpolation or not?
Also your X and Y axis steps per millimetre are the same but your motor currents are different? are you using different motors?
Same motors, one is the Y axes, heavy mechanism, it gets slope if there the same. will fix the M350 command. I uploaded the Firmware (dc42/Version 1.16 beta 3). noisy in the steeper motors is gone.
Was ruining another test print. 4mm x 4mm 75mm square. The over extruding started at about 3mm. Looks like its over extruding, then under extruding. Then go's back to normal for 60mm, then it dos it age-an.
That sounds to me like either a problem with your extuder drive, or inconsistent filament diameter.
The filament would have to have a difference of .75mm to do this.
I went from:
M350 X16 Y16 Z16 E16:16 I1 ; Set microstepping mode, interpolation mode On
to
M350 X16 Y16 Z16 E16:16 I0 ; Set microstepping mode, interpolation mode OffSecond test print cam out OK. looks like its interpolation. Docs on Stepper state it needs a Good Clock pulse. Probably is noise or not up to snuf, it also explanes why its a repeting intervall. Adding to mush plastick then not enuff. All leave interpolation mode switched off
Figured it out, Extruder issues:
M350 X0 Y0 Z0 E0:0 I0 ; Set microstepping mode
looks like my Stepper motors wont do microstepping mode. If i understand the command right. Symptoms noise steppers, Pore Speed control (Extruder). Switching to latest FW
