My Maestro Menu Files are now on github
Version 1.3 including all of David's suggestions from his post above (19 Jan 2019. 10:06) is now released on github
https://github.com/mudcruzr/Duet-Maestro-12864-Menu-Files/releases
enjoy
@mudcruzr said in My Maestro Menu Files are now on github:
@dc42 Yes, but it appears that it's only missing in the transition from "printing" to "not printing". Changing from "not printing" to "printing" works fine.
What's happening is that when the state changes, menu items that should no longer be visible are not being erased. I will fix this in 2.03beta1.
@dc42 thank you Mr. C
V1.4 is now on Github
The readme:
Tidied up the heat menu screen, using graphics instead of the words "Bed" & "E". Also removed the display of M117 messages from this screen and added a display of the IP address.
Very Nice! I am doing an extensive update to the Crane Series menus at the time. It's really great to see someone else's take on this. I feel like I've been the only person on earth doing this lately.
I've been so incredibly tied up with the launch of the Crane and QuadFusion head that I've been focused entirely on customer issues and improvements. Now that we are off the ground well I will be turning my attention back to active development.
If you're interested, I have created a number of icons for things like the hotend, heatbed, etc. I can provide them here but they will be making their way to the Crane github today. I'll post a few pics also. For now, I am going to check your menu files out.
Cheers!
David Hargrove
M3D -
@streamliner Cheers David, I've set a watch on the Crane github.
@mudcruzr Excellent. I just applied your menu files to one of my test printers and it looks great. Really good use of real estate on the main menu. I wasn't sure about the format of the image file in this case. I actually created the few i'm working with byte-by-byte -- do you have a different conversion method you'd be willing to share?
Thanks,
David
@streamliner LOL! Sorry David, but I do it bit by bit on squared paper, manually convert to hex then into a hex editor to make the image file. Hi-tech or what?
You and me both. lol... I went with the Graph Paper -> Binary -> Hex, then wrote it all into a hex editor. I know that somewhere in my head there's a better way to do this, but I can't seem to locate it.
The bmp2c-escher3d application that is used to create PanelDue checks the color depths of the bitmap before proceeding -- in the case of a 1-bit bitmap, it returns a warning stating that this has not yet been implemented. I'm unsure if the source of this application is available, I've only been able to find the executable. This could be a good place to start.
Anybody see my suggestion that the file menu filter out file system meta data files like with a "._" prefix? Or they they get outright deleted.
v1.5 now up on github:
Release note:
Added a new control menu (CTRL), accessed from the main screen. it allows the following:
COOLDOWN (turns off bed and nozzle heaters and the parts cooling fan)
MOTORS OFF (releases all motors N.B. also "unhomes" all axes)
REBOOT MAESTRO
RUN MESH COMP (homes all axes, heats bed to 50C, heats nozzle to 180C, runs mesh compensation and then turns heaters off) -
@3dmntbighker said in My Maestro Menu Files are now on github:
If you can't stop your Mac putting those files on the SD card, I suggest you delete them. You can do that on the Display Editor page.
@dc42 said in My Maestro Menu Files are now on github:
Actually, the "._" files are Windows. The Mac uses ".DS_Store" files for metadata. So likely I inherited these from someplace else? My proposal was to not display them since everyone is so likely to end up with them at some point.
The firmware already suppresses returning filenames that start with '.' and I just tested that it still works. So I am puzzled that you are seeing them. Which firmware version are you using?
@dc42 Files whose names begin with "." are suppressed in DWC as you have confirmed, but are displayed by the Maestro's menu system "files" command on the 12864 lcd. I have just tested and confirmed this. (Latest firmware, latest DWC etc.)
Yep, that's what I'm sayin bro
Now I understand! I thought you were saying that files beginning with '.' in the /menu folder were showing up in DWC.
I've made a code change to hide filenames beginning with '.' in the 12864 files display. This will be released in the 2.03beta firmware.
@dc42 Many thanks.
Sweet!!!
v1.6 is now on github,
https://github.com/mudcruzr/Duet-Maestro-12864-Menu-Files/releases/tag/v1.6
here are the release notes:
As I no longer need a blank line at the bottom of the main page for M117 messages (Now using M291 messages). I was able to use that real estate to give the existing layout some extra elbow room in the vertical direction. If you do have any M117 message strings (e.g. M117 "Print Started" in your slicer's start G code section) you should change them to use M291 (e.g. M291 P"Print Started") if you want them to display on the 12864
Additionally, I was made aware that without a license assigned to this project, technically no-one should use it. I think that the unlicense is the most liberal available and the most appropriate for the intent behind providing these menu files.enjoy
