Panel Due v2.0
A serial port shows as …... "Duet 3D printer control electronics (COM19)"
Nothing on the screen but testing the cable from the PCB shows that +4.63v is available.
What should the jumper position be on the Panel Due to set the voltage?
I am having the same issue. The panel lights up but the screen is blank. I moved the jumper to 5V but still nothing.
If it's blank, then the firmware could be missing or corrupt.
I meant connect the USB port on PanelDue to the PCB, not the USB port on the Duet.
The jumper should be set to 3.3V.
The jumper should be left on 3.3V. Changing it to 5V may damage the display.
If it's a version 1.1 board then it sounds to me that it is not programmed. See the PanelDue firmware update instructions at https://miscsolutions.wordpress.com/paneldue/.
A version 2 board that is not programmed will have the display unlit.
OK ….... plugging the USB lead into the Panel Due v2.0, I get ....."Bossa Program Port (COM18)" and nothing else .......
Hey Gregk, looks to me like the firmware is not loaded or it got erased.
Check out the section on reloading the firmware in David's blog post:
https://miscsolutions.wordpress.com/paneldue/The uptodate firmware is available here:
https://github.com/dc42/PanelDue/tree/master/Release
make sure you use the right one for your screen size. -
Many thanks for your help, I will try this later after my dinner.
The BOSSA software was downloaded but failed to install because it require a 32-bit machine …............ uggghhhh.
All is sweetness and light …........ downloaded the 64-bit version of bossa.exe and used the command line as suggested.
Many thanks for your help.
the current version of found here Bossa 1.2.1 64
https://sourceforge.net/projects/b-o-s-s-a/files/1.2.1/
does not seem to support Windows 10Version 1.7 found here
https://github.com/shumatech/BOSSA/releasesbut they dont offer any windows binarys to run
do paneldue 2.0 come preloaded?
You need to disable Driver signature verfication in windows 10 64 and then Bossa 64 will install
