RRF Tool Not creating accurate config.g?? WassuP?
Greeting and Salutations,
Tried the RRF Online configurator and tried to set a static IP addy on my Duet Ethernet (See attached Pic). After Upload the Board came back up with a different addy than what I assigned. Looked at my config.g and could not find a M552 with any ip addy? Weird Huh? I just edited my config file but now I'm starting to wonder what else I asked for that I'm not getting? The struggle is real yo!!
I'm sorry, I can't reproduce that. This is the start of the config.g file that it generated, using those settings:
; Configuration file for Duet WiFi (firmware version 1.21) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2 on Tue Jan 08 2019 15:13:28 GMT+0000 (Greenwich Mean Time) ; General preferences G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves M665 R105.6 L215 B85 H250 ; Set delta radius, diagonal rod length, printable radius and homed height M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them ; Network M550 P"My Printer" ; Set machine name M552 P192.168.0.230 S1 ; Enable network and set IP address M553 P255.255.255.0 ; Set netmask M554 P192.168.0.1 ; Set gateway M586 P0 S1 ; Enable HTTP M586 P1 S0 ; Disable FTP M586 P2 S0 ; Disable Telnet
Thank you for looking at this. I've tried multiple times to create new firmware files but I still do not get correct IP address settings. I can't imagine why this is the case? Maybe I need to clear the cache on my browser??? Weirdness.
Please clear your browser cache and try again. Assuming it still doesn't generate the correct file, post the config.json and the config.g files that it generated.
That worked DC! Thank you Sir!!!
