Duex5 Testers
If there are any left I will buy one.
Please add me to the list!
Would love to. But first need to launch the Zesty Nimble.
This takes all my time at the moment so it would not be fair to those guys that can spend time on it.But I am very interested as I am prepping a Diamond nozzle head so need 1 more extruder.
Also want to start looking into full colour printing so I will need more control. -
I'll sign up for one.
Count me for one
I'd like to help test.
Love to try it out!
Yes add me to the list
Add me too !
I'd love to help. Please add me.
Please add me to the list (hopefully having being overseas doesn't mean I miss out)
Yes please a pre production duex5 board will be great.Thank you for this offer
Paul -
Count me in
Count me in, I would love to help
I'd be interested, especially if it's possible to use the extra heater channels for 12 volt rgb led control. I see no reason why not other than the firmware shutting down the channels due to bogus thermistor readings.
The DueX5 design has 5 additional PWM outputs for fans and LEDs. This is the untried part of the design, so there is a possibility that it won't work properly - which I guess is why Tony didn't mention it in the first post.
If there any any left i also would be interested.
I have another use case that might work well here.
One of the FRC teams I mentor for asked me to put together a parts list for a larger 3d printer. Something in the range of 400x200mm. Debating on a larger CoreXY or i3 style…
The relevant portion of this is the bed heaters. I am looking at a split bed in a side by side configuration covered in a single PEI sheet. This should allow for a dual zone heated bed. To do this a thermistor would be installed in each side and each bed would be driven separately. This is where the extra heater or PWM channels would be perfect. I understand that the 2nd bed heater would need to have it's own temperature set and that would require a little training.
Then again, this should be possible with a standard DuetWifi using the 2nd hot end heater output, driving a SSR or external mosfet setup.
Please add me to the list as well - thanks.
hi
yes please i got a lot of extra time on my hands just gone part time at work
