Auto Bed Compensation Javascript Error
@dc42 did you manage to replicate this. I now see this same error and no height map file being saved after upgrading. I'm using G29 in my bed file. and see it in both Chrome and Edge.
A JavaScript error has occurred so the web interface has closed the connection to your board. It is recommended to reload the web interface now. If this happens again, please contact the author and share this error message: Version: 1.22.4-b1 Message: JSON.parse Error: Invalid character at position:107 URL: http://10.0.0.10/js/dwc.js Line: 1065:9 Error object: {}
Software Information
Firmware Electronics: Duet WiFi 1.0 or 1.01
Firmware Version: 2.02RC3(RTOS) (2018-10-17b2)
WiFi Server Version: 1.21
Web Interface Version: 1.22.4-b1I've attached my bed.g and config.g.
Any thoughts?
I was unable to replicate it.
Please can you update DWC to the 1.22.4 release and check whether it still occurs. If it does, then it would be most helpful if you can get a Wireshark trace of the transaction that produces the error message. You can either save the trace and make the .pcap file available to me, or search for the faulty transaction. It will be an HTTP 200 OK response with the data type reported as JSON, but when you expand it, instead of displaying the JSON object it will offer "Line based text data". That's the data I need; so right click on it, select Copy, and then paste it into a post.
@dc42 yes of course I will get that this evening.
@dc42 ok I'm getting this response first and then following that I get the disconnect response. I assume because it's not catching the error.
GET /rr_reply HTTP/1.1 Host: 10.0.0.10 Connection: keep-alive Accept: text/html, */*; q=0.01 X-Requested-With: XMLHttpRequest User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/70.0.3538.77 Safari/537.36 Referer: http://10.0.0.10/ Accept-Encoding: gzip, deflate Accept-Language: en-GB,en;q=0.9,es;q=0.8 HTTP/1.1 200 OK Cache-Control: no-cache, no-store, must-revalidate Pragma: no-cache Expires: 0 Access-Control-Allow-Origin: * Content-Type: text/plain Content-Length: 183 Connection: close Bed equation fits points [15.0, 15.0, 0.547] [15.0, 180.0, 0.097] [170.0, 180.0, -0.255] [170.0, 15.0, 0.102] [80.0, 97.5, 0.102] Error: G29: Height map file heightmap.csv not found
GET /rr_disconnect HTTP/1.1 Host: 10.0.0.10 Connection: keep-alive Accept: application/json, text/javascript, */*; q=0.01 X-Requested-With: XMLHttpRequest User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/70.0.3538.77 Safari/537.36 Referer: http://10.0.0.10/ Accept-Encoding: gzip, deflate Accept-Language: en-GB,en;q=0.9,es;q=0.8 HTTP/1.1 200 OK Cache-Control: no-cache, no-store, must-revalidate Pragma: no-cache Expires: 0 Access-Control-Allow-Origin: * Content-Type: application/json Content-Length: 9 Connection: close {"err":0}
Is this because I am running
G29 S1
instead ofG29 S0
? What should be used to probe the bed, save the file and activate bed compensation or if file exists load the file?This is what the configuration tool gave me.
M561 ; clear any bed transform G28 ; home all axes ; Probe the bed at 5 points G30 P0 X15 Y15 H0 Z-99999 G30 P1 X15 Y180 H0 Z-99999 G30 P2 X170 Y180 H0 Z-99999 G30 P3 X170 Y15 H0 Z-99999 G30 P4 X80 Y97.5 H0 Z-99999 S G29 S1 ; Detailed Z-Probe. Load the height map from file and activate bed compensation.
Those are not the responses that cause the error message from DWC.
@dc42 The only calls I can see before that were to
GET /rr_status?type=2 HTTP/1.1
andGET /rr_status?type=1 HTTP/1.1
. Here is the network trace the printer is at 10.0.0.10 and the PC is at 10.0.0.187.My previous post is after I changed from DWC 1.22.4-b1 from your Git repo to 1.22.4 from Chris Hamm https://github.com/chrishamm/DuetWebControl. I was already running 1.22.4-b1 when you asked me to upgrade to 1.22.4 and Chris's version was the only one I could find that was specifically 1.22.4. So I don't know if there are any differences.
So I tried some other stuff last night if I run "Perform automatic mesh compensation (G29)" from the drop down menu. It proceeds to probe the bed in 20mm grid completes, saves the heightmap.csv and displays it.
If I then run Auto Bed Compensation it probes the bed at the 5 points defined in the map.g file then displays the height map.
So to me that seems like if there isn't an existing heightmap.csv and G29 S1 is run, it throws the error on the
GET /rr_reply call
. Then immediately after thatGET /rr_disconnect
is called.Thanks
Thanks for providing the network trace. I was expecting to see an invalid JSON response, but there isn't one. So I suspect it is a DWC issue, not a firmware issue. I have asked chrishamm to take a look.
@dc42 that’s great thanks!
Thank you very much for the Wireshark dump, it makes things easier to diagnose.
I tried out the same bed probing macro that you used and it worked without problems for me too, but once I copied the response from rr_reply and reran the corresponding parsing code I was able to figure out why it fails for you. Apparently DWC receives a multi-line string after the G32 call that it cannot deal with, so I need to work-around this.
I'll come up with a fix soon. In the meantime I suggest you remove the G29 S1 call from your bed.g - in fact I don't quite understand why you use it at all. You can only use bed compensation -or- mesh compensation, but not both at the same time AFAIK.
@chrishamm cool thanks for looking at it.
G29 S1 is in the bed.g file as the RepRap Configuration Tool put it there
