Your Duet rejected the HTTP request: page not found
ok just read through it and I am more confused.
File config.g:... Im not sure what I would put here:
M584 X0 Y1 Z2:5:6 ; three Z motors connected to driver outputs 2, 5 and 6
M671 X-15215 Y190:-10:190 S0.5 ; leadscrews at rear left, front middle and rear right
File bed.g:
I assume I would remove M401 and G30 P2 X100 Y10 Z-99999 S3 ; probe near a leadscrew and calibrate 3 motors
M402 ; retract probe?
G28 ; home
M401 ; deploy Z probe
G30 P0 X20 Y190 Z-99999 ; probe near a leadscrew
G30 P1 X180 Y190 Z-99999 ; probe near a leadscrew
M402 ; retract probe -
@phaedrux said in Your Duet rejected the HTTP request: page not found:
https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
Well in your case you only have 2 motors and 2 lead screws, so in those examples you just need to remove one of the references for each and make the remaining ones match your setup.
So something like
M584 X0 Y1 Z2:4
assuming your Z motors are connected to the Z connector and the second extruder connector (e1)
And then you'd need your lead screw positionsM671 X-15:315 Y150:150
assuming the lead screws are in the middle of the bed in the Y dimension, and then a left and right value for the X axis.and for the bed.g same deal, you just need 2 positions for your 2 lead screws.
I'm not an expert on using independent lead screws to level the bed though as I've never used it.
my z motors are both connected in the port z motor a and port z motor b
fyi i am using duet 2 wifi
; bed.g
; generated by RepRapFirmware Configuration Tool on Sun Oct 28 2018 16:32:40 GMT-0700 (Pacific Daylight Time)
; Probe the bed at 4 points
G30 P0 X15 Y15 H0 Z-99999
G30 P1 X15 Y239 H0 Z-99999
G30 P2 X215 Y239 H0 Z-99999
G30 P3 X215 Y15 H0 Z-99999 S -
I dont have m584 in my config.g anywhere
anyone around?
anyone home?
The link provided above lists the requirements for getting the leveling to work.
As I said, the motors will need to be connected to separate drivers.
The bed.g you just posted will not work, because you do not have a Z probe. The best you can do is tilt correction of the X axis to keep the Z motors aligned properly. To do anything more will require an actual Z probe.
Sorry bud but I dont understand what you are telling me to do
as i mentioned there is no m584 in my config.g
Ya that link makes zero sense to me since i dont see those codes in my config.g
Can anyone just create the proper config.g for me this is taking way too long
ive read the links and nothing seems to be working
ive uploaded the .g files
does anyone see what I am doing wrong? -
This is insane How long this is taking!
When will you offering phone support?
is anyone therre?
Perhaps I can skype with support?
@sleepless we do not offer phone support. We are trying to help you resolve the issues. There are a huge number of 3D printers out there, your Robo R1 is not something we have any experience on and appears to have some weird features (such as two endstops under the bed??).
We are trying to work though it step by step with you.
