Your Duet rejected the HTTP request: page not found
When you say the endstops are connected as one, do you mean they go to a single endstop connector?
so the endstops are under the x carriage and are triggered when the nozzle hits the bed and the metal trigger on the endstop is released.
@phaedrux I mean the wired the 2 endstops to one connector
@phaedrux exactly
thanks for the early morning help guys
Do both switches have to be hit for the endstop to trigger or does it trigger as.soon as one is hit?
@phaedrux It should trigger when one is hit however I am not completely sure about that.right now I think I will recrimp the connection because it triggers the e0 endstop as hit when its normal and no hit when I lift the carraige. Also this takes a while before it recognizes the hit/no hit but once it does it seems to trigger right away. then I run a home all test and it wants to crash into the bed
Have you seen this?
https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
ok just read through it and I am more confused.
File config.g:... Im not sure what I would put here:
M584 X0 Y1 Z2:5:6 ; three Z motors connected to driver outputs 2, 5 and 6
M671 X-15215 Y190:-10:190 S0.5 ; leadscrews at rear left, front middle and rear right
File bed.g:
I assume I would remove M401 and G30 P2 X100 Y10 Z-99999 S3 ; probe near a leadscrew and calibrate 3 motors
M402 ; retract probe?
G28 ; home
M401 ; deploy Z probe
G30 P0 X20 Y190 Z-99999 ; probe near a leadscrew
G30 P1 X180 Y190 Z-99999 ; probe near a leadscrew
M402 ; retract probe -
@phaedrux said in Your Duet rejected the HTTP request: page not found:
Well in your case you only have 2 motors and 2 lead screws, so in those examples you just need to remove one of the references for each and make the remaining ones match your setup.
So something like
M584 X0 Y1 Z2:4
assuming your Z motors are connected to the Z connector and the second extruder connector (e1)
And then you'd need your lead screw positionsM671 X-15:315 Y150:150
assuming the lead screws are in the middle of the bed in the Y dimension, and then a left and right value for the X axis.and for the bed.g same deal, you just need 2 positions for your 2 lead screws.
I'm not an expert on using independent lead screws to level the bed though as I've never used it.
my z motors are both connected in the port z motor a and port z motor b
fyi i am using duet 2 wifi
; bed.g
; generated by RepRapFirmware Configuration Tool on Sun Oct 28 2018 16:32:40 GMT-0700 (Pacific Daylight Time)
; Probe the bed at 4 points
G30 P0 X15 Y15 H0 Z-99999
G30 P1 X15 Y239 H0 Z-99999
G30 P2 X215 Y239 H0 Z-99999
G30 P3 X215 Y15 H0 Z-99999 S -
I dont have m584 in my config.g anywhere
anyone around?
anyone home?
The link provided above lists the requirements for getting the leveling to work.
As I said, the motors will need to be connected to separate drivers.
The bed.g you just posted will not work, because you do not have a Z probe. The best you can do is tilt correction of the X axis to keep the Z motors aligned properly. To do anything more will require an actual Z probe.
Sorry bud but I dont understand what you are telling me to do
as i mentioned there is no m584 in my config.g
