Firmware 2.02 Release candidate 3 now available
Interesting thing I found about G30:
- If you use:
G30 X20 Y20
to probe the bed at a specific point, you always have to calculate the offset of the probe, because the coordinates of the nozzle are used.
Whereas if you use 2:
G30 P0 X20 Y20 H0 Z-99999
the offset of the probe is already calculated and the real probe coordinates are used but not the "actually" coordinates of the nozzle
- The H- parameter is still not taken into account when probing. Therefore, I performed a little test:
M561 ; delete any bed transformation G1 X45.457 Y8.602 Z10 F15000 ; go to probing point on floating bed G30 X45.457 Y8.602 H0 S-1 ; define this point as Z=0 M561 ; delete any bed transformation G1 X45.457 Y8.602 Z10 F15000 ; go to probing point on floating bed G30 X45.457 Y8.602 H5 S-1 ; define this point as Z=0 M561 ; delete any bed transformation G30 P0 X20 Y20 H0 Z-99999 S-1 ; probe point P0 M561 ; delete any bed transformation G30 P0 X20 Y20 H3 Z-99999 S-1 ; probe point P0 M561 ; delete any bed transformation G30 P1 X20 Y20 H3 Z-99999 S-1 ; probe point P1
This ended up in the results:
20:20:45G32 bed probe heights:, mean nan, deviation from mean nan 20:20:42G32 bed probe heights: 0.004, mean 0.004, deviation from mean 0.000 20:20:39G32 bed probe heights: 0.007, mean 0.007, deviation from mean nan 20:20:36Stopped at height 1.399 mm 20:20:31M98 P"0:/macros/Test H-Factor" Stopped at height 1.399 mm
So as the H-factor differs every probe, the results are all the same...
greetings kuhni
@dc42 updated to 2.02rc3 and dwc 1.22.4-b1. Prints fine, but at the end of a print, the 'job status' does not seem to finish properly. Previously the 'print another' option would appear, but now I just get greyed out 'pause job' button. Using a Kossel delta. Can select and print another job from the g-code files tab.
@adrian52 previous version dwc seems to work fine with rc3
@phaedrux
Did you test M600 yet?Does it have pause and park feature or does this have to be macros on the side?
/Roy
Had a problem with the 1.22.4 web interface:
Uploading a file the first time using the upload&print button was fine.
However if I upload it again with the same filename, having made some slicer settings, and having paused and canceled the original it usually failed the re-upload.Just retrying with 1.22.3 and it works fine
@pro3d it will run pause.g by default or filament-swap.g if present. So you have to customize the macro to your needs.
@dc42 updated to 2.02rc3 and dwc 1.22.4-b1. Since upgrading whenever I scroll down in DWC it automatically scrolls back up a couple seconds later. Very irritating. I'm using Safari 12.0. This hasn't been a problem with any previous version. It seems to print fine however.
@k3lag said in Firmware 2.02 Release candidate 3 now available:
Which version of DWC were you using previously?
@k3lag I can't reproduce this in Safari 12.0 it appears just fine to me tho I normally use Chrome.
Doug
I have that too (with Chrome).
It depends on the screen size, I noticed.Here are two pictures see scroll bar
jump back (100%)
scrolling works (110%)But I already had it with the previous version DWC 1.22.1
I was using 1.22 and never noticed a problem. I reverted back to 1.22.3 and it behaved the same as the .4b1. However, I figured out that it is related to 'scaling' the web page. If I use the buttons in my browser to either shrink or enlarge the page the problem occurs. It does not occur if it's not being scaled. It appears others have seen the same thing in other browsers. I don't have this problem with any other web pages that I've noticed.
@adrian52 I also see that the Print Again is missing, and it is super annoying. I keep testing the same parts after making small adjustments, pause, cancel, print again etc... And this got annoying the first time I printed after updating the firmware and web interface.
I've seen an error message on the PanelDue console that hasn't shown up in the Gcode console.
Wifi reported error: incomplete write wifi reported error: incomplete write
It shows up twice like that.It happened once while trying to download a gcode file from the DWC. The download failed in the browser as well.
Then it happened again uploading a Gcode file. But the gcode file seems to have uploaded correctly.
When I saw the error message I checked the DWC console which was up and running but nothing was there.
I then ran a M122 to see the diagnostics and the DWC reloaded and the printer paused for a second mid print and then carried on. When the DWC reloaded I ran M122 again. This time it worked. But doesn't seem to show anything amiss. Nothing was logged to the PanelDue console.
=== Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02RC3(RTOS) running on Duet WiFi 1.02 or later Board ID: 08DDM-9FAM2-LW4SD-6JKF0-3SN6N-T2ZBY Used output buffers: 1 of 20 (20 max) === RTOS === Static ram: 28532 Dynamic ram: 98720 of which 12 recycled Exception stack ram used: 512 Never used ram: 3296 Tasks: NETWORK(ready,328) HEAT(blocked,1184) MAIN(running,3484) Owned mutexes: === Platform === Last reset 02:13:18 ago, cause: power up Last software reset at 2018-10-15 13:21, reason: User, spinning module GCodes, available RAM 3480 bytes (slot 0) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d Error status: 4 Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest block write time: 0.0ms, max retries 0 MCU temperature: min 44.5, current 44.9, max 45.3 Supply voltage: min 23.8, current 23.9, max 24.1, under voltage events: 0, over voltage events: 0 Driver 0: ok, SG min/max 0/1007 Driver 1: ok, SG min/max 0/254 Driver 2: standstill, SG min/max 0/222 Driver 3: ok, SG min/max 0/240 Driver 4: standstill, SG min/max not available Date/time: 2018-10-21 16:43:25 Cache data hit count 4294967295 Slowest loop: 4.63ms; fastest: 0.07ms === Move === Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 150, MinFreeDm: 150, MaxWait: 0ms, Underruns: 0, 0 Scheduled moves: 191830, completed moves: 191800 Bed compensation in use: mesh Bed probe heights: 0.000 0.000 0.000 0.000 0.000 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 Heater 0 is on, I-accum = 0.2 Heater 1 is on, I-accum = 0.4 === GCodes === Segments left: 1 Stack records: 3 allocated, 0 in use Movement lock held by null http is idle in state(s) 0 telnet is idle in state(s) 0 file is doing "G1 X186.602 Y122.915 E0.08193" in state(s) 0 serial is idle in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 182.79ms; fastest: 0.08ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) HTTP sessions: 1 of 8 - WiFi - Network state is running WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.21 WiFi MAC address 5c:cf:7f:ef:4a:74 WiFi Vcc 3.31, reset reason Turned on by main processor WiFi flash size 4194304, free heap 13216 WiFi IP address 10.10.0.63 WiFi signal strength -40dBm, reconnections 0, sleep mode modem Socket states: 0 2 0 0 0 0 0 0 === Expansion ===
I have been using it without any real problem but a funny one.
While I was connected I had to turn my router off. When the router was back online the duet reconnected but the web interface would not connect again, even after a refresh of the page. I closed the browser and reopened it, but nothing it would not connect to the duet.
I had to turn the duet off then on and all was back to normal. -
If you have a panel due try sending an M552 S1to restart the Wifi.
See https://duet3d.dozuki.com/Wiki/GCode#Section_M552_Set_IP_address_enable_disable_network_interface
@adrian52 Thanks for the note, I'll fix this shortly.
@k3lag I'm afraid I cannot reproduce this. I tried it on Firefox (Win+Linux), Edge and Safari (OS X) but it never scrolls up for me. Can you check if the toggling the option "Always show info area and menu" on the Settings makes a difference?
Edit: There you go - v1.22.4 is now official: https://github.com/chrishamm/DuetWebControl/releases/tag/1.22.4
I can't duplicate now either. It was consistent for a few days now suddenly it seems fine. I'll let you know if the problem returns and I'll pay attention to any change in circumstances that may cause it.
It just started doing it again and I noticed what's going on but I don't know why. My printers name on the network is "bigbox.local". If the URL in address bar is "bigbox.local" it does not exhibit the problem. Somehow the URL is changing to "bigbox.local." (notice the "." at the end) and when it is that way it scrolls back to the top after scrolling down. I'm not sure where the extra "." is coming from. If I manually put the "." on the end when it's working correctly the behavior will start as well. For some reason the extra "." is getting added to the end of URL on its own somehow.
Z Baby Stepping doesn't seem to work any more.
I just updated DWC to 1.22.4 to see if that would fix it, and it did not.Current version
Firmware Electronics: Duet Ethernet 1.02 or later
Firmware Version: 2.02RC3(RTOS) (2018-10-17b2)
Web Interface Version: 1.22.4Is anyone else having this problem?
@bluedust said in Firmware 2.02 Release candidate 3 now available:
It seems to be working for me from both the 1.22.4 DWC (that was just put out today) and from the PanelDue 1.22 released a couple days ago. (It's annoying from the Paneldue due to the "response" popups, but it seems to work.)
What symptoms are you seeing that suggest it's not working?
