New PanelDue firmware 1.15 beta 2
Broke my usb connector, too.
Soldered usb cable on. -
I noticed that on my PanelDue the Active temperature for the Bed shows -273 on startup until I set it to anything else. The extruder shows 0 like it should. Probably just cosmetic or a variable initialization problem.
That's because -273 is what it is set to. I believe DWC displays 0 when it sees -273 as the active or standby temperature, but PanelDue doesn't do that. You can put M140 S0 in config.g if it bothers you
Ok. Thanks. Is that just in case a bed thermistor isn't connected it won't think it needs to raise the bed temp to 0 and causes it to heat?
I don't think there is a particular reason for it. The hot end temperature Is the same, however most people put G10 commands in config.g to set the temperatures to zero.
David
Don't know if this is a bug at all but on my V1.0 PanelDUE Controller and 4.3 inch screen running 1.15B3 I no longer get the Gcode file list so can't print from it?
DWC Work's fine and all other FW is upto Date FW 1.15c Wifi at 1.02 and DWC 1.12.
Any ideas? Think I may roll back to 1.14 on the Panel in stages to see what happens?
Doug
Doh feel like a complete wally now just re-read the change log and see you've moved the SD Card to control Page!!
I was looking on the Print page for it Doh.
Yes, I decided it made more sense on the control page - because all the other commands I use just before starting a print are also there.
I cannot update my PanelDue because I cannot get the BOSSAC installed. It starts to install and then gives an error.
In this case I will revert to the definition of insanity, and try it again. For the 5th time.Nope. Setup wizard ended prematurely.
Lykle what OS are you using?
Sorry, of course.
I am running Win10 on a laptop. -
You don't need to install bossac if you just copy the bossac.exe file from the Tools folder of my GitHub repo.
I installed it using sam-ba v2.16 as I had some familiarity with this having using it to recover the duet wifi. Seems straightforward enough.
Found it, done it and updated the firmware.
Thanks guys. Great support.My PanelDue is now running 1.15beta3.
