Jog motor dialog scale
@genghisnico13 said in Jog motor dialog scale:
Since we are talking about it, in the dialog there isn't a button to abort or cancel the manual probing procedure, it would be nice to have one. All of this only on DWC.
That will come when the firmware supports conditions in GCode, so that some action can be specified when probing fails.
Cool.
I found the configuration to change the babystep size, but not one for the jog motor dialog. the babystep size dialog is helpful already though. This is the 1.21 version of the firmware/DWC, is the dialog value change a feature in newer firmware?
@supraguy it's not in the settings page. You just right click on the actual jog button.
In what browser?
I use Chrome, and right click on the buttons yields the "open link in new tab/new window/incognito window..." result, no editing options. It might be even trickier when trying to do mesh leveling, too, because then it's Chrome on my phone or tablet.
@supraguy I'm using chrome and
Firmware Version: 2.02RC2(RTOS) (2018-09-07b2)
WiFi Server Version: 1.21
Web Interface Version: 1.22.3I'm not sure what version this feature was released. I only just learned of it myself.
Yes it was introduced in a fairly recent version of DWC
So it looks like I should update firmware.
I generally don't use RC versions of software unless I'm actively testing, and looking to update often, so I generally stick to stable releases.
I don't mind beta testing, but I like to stick the experimental variables to as few as possible, and since my printer is still more or less in beta, I like the control software to be stable. Well, I guess the machine is pretty much proven ready to go now. Still a bug or two to squash.
If this functionality is implemented, that's all good. I do have to say that I was also very happy to find the baby stepping interval tuning.
@supraguy you could try 2.01 stable release. It would be the latest DWC version that matters anyway I would think.
Hmmm... on this board at least, upgrading to the 2.01 seems to have some trouble with directory listings looping all of the files in the directory over and over and over.... The additional functionality is nice though.
Last I had looked, all of the 2.x releases were still beta or RCs. Well, I suppose that I'll try the latest, and see if that fixes things. Okay, 2.02RC2 seems to work better that way.
Have you also updated the DWC version? It may only be the 2.02 versions that have fixed the too many files in a folder bug.
Easiest way to resolve without updating would be to move the SD card to a PC and manaully moving the gcode files into folders.
