Need help, willing to pay, I'm completely stuck.
@jameswstubbs Well it should only be set to 0 when doing the measurement, but even then it should be able to stop the bed in time it just won't know exactly where your nozzle is.
This leads me to wonder if you have the BLTouch mounted too high or too low.
The body of the BLTouch should be 8mm above the nozzle tip. Are you close to that?
Crashing: LONG before the nozzle gets to the bed, trigger the BLTouch probe with your finger. Everything should stop moving down.
Do this with your other hand on the power switch, ready to power down INSTANTLY if things do not stop.
That's how you avoid crashes, with any probe, while figuring out the physical and configuration offsets.
Hi, apologies I've been away a few days and had to collect the spare z nut holders (literally the other end of the country!!)
I've now repaired what became damaged.
I measured the BlTouch as suggested, to my surprise it was about 10mm higher than the nozzle, this was surprising as the whole carriage design is based around having this sensor and it's a genuine item!
I've now placed two washers between the BlTouch and the mount, this should bring it within the roughly 8mm.
This is the result of my mesh compensation now:
I'm using a genuine E3D V6 and having done a search of the forums, I have found this:
https://forum.duet3d.com/topic/2501/e3d-v6-thermistor-settings/7
Am I right in saying that I need to use?:
M305 P1 T100000 B4725 C7.06e-8 R4700 ; Set thermistor + ADC parameters for heater 1
https://wiki.e3d-online.com/E3D-v6_Assembly#Configure_Firmware_.28Easy.21.29
Here's E3D s docs on setting it up for reprap.
Your height map looks much better. Are you still having issues or is it resolved now?
Just changed some settings with the e3D and have ran a M303 to autotune and have set a M307 command in the config file.
I was having issues with adhesion earlier that I didn't used to have using Marlin.
I'm trying another print now with the new thermistor/PID settings.
Otherwise, it may be the Z offset that is off. -
Did you receive measure the z trigger height after adding the washers?
You may also want to remeasure your e steps per mm since your temperature may have been off before.
We're printing!!
I can already tell it's not a good print, but the fact it's printing is a massive step!
I'm using the recommended e steps for the titan extruder at the moment, but I'll measure this myself properly tomorrow morning.
I recalibrated the z offset and it came out at 0.995 three times in a row, where as beforehand it varied between 0.2 and 0.5.
I think the BlTouch was too high to work properly as you suggested.
Glad to hear it's working now
I'm genuinely surprised at how quiet it is! Do you have a donate link on thingiverse or a paypal account? I wasn't kidding when I said I'd be willing to pay and I do insist.
https://ibb.co/cCaNcK
https://ibb.co/iss2cK
https://ibb.co/cFfYjz
https://ibb.co/jEj4reNow it's the long process of trying to tune the prints and improve my bed adhesion.
At the moment I the bed is probed in 5 places when printing, how would I convert to mesh bed compensation?
@jameswstubbs said in Need help, willing to pay, I'm completely stuck.:
@jameswstubbs Well if you insist. I think I have a tip option on thingiverse. I've never got a tip before. https://www.thingiverse.com/Phaedrux/about
You can find out more about mesh compensation here: https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
It may help you out a bit because it can give a much higher resolution heightmap.
Your print looks like a decent starting point. Tuning the e steps and extrusion multiplier will help get your slight over extrusion under control. It also looks like it might be printed a little hot and a little too fast, but it's hard to tell on such a small test print.
