Motors keeps vibrating but not moving
The json file says that it runs marlin
@sannygt said in Motors keeps vibrating but not moving:
I am also afraid that my motor are mabye to small
42x42x34mm
Rotor Intertia: 34g.cm2
Holding torque: 28N cm
Detent Torque: 1.6N cmThose motors are OK for a small printer. I have similar motors on my Cartesian printer with 200x200mm bed, rated at 1.33A. I run Y and E at 1000mA , X and Z at 800mA.
I expect it says that the USB input channel is configured for Marlin compatibility, which is normal.
@sannygt I hope you aren't using printed motor mounts, because they may melt at those high currents.
I think it's likely you are getting some binding which is requiring so much torque to overcome. I suggest you recheck your mechanical setup and see if you can get things moving more smoothly.
Here are some images of my machine, maybe it can help.
I was thinking about adding ceramic Grease (fat) on the rods to reduce the friction. Should that work?
I have seen that industrial machines like lathes, CNC machines, and robot arms use it a lot. That gave me the idea to use it.
How hot are the motors getting? if you really are running them at 3A and they are rated for only 1.3A then they will get extremely hot quite quickly. If they don't, then the motor specification must be wrong. You could measure the resistance of a winding using a multimeter and compare it to the value on the data sheet.
Sorry for the inactivity.
I managed to get the motors moving on rod Y and Z, only the motor on rod X is still vibrating. I reduced the amps to 1.3A now in the firmware.
I do need to borrow a multimeter sinds i only have a industrial voltage meter
But the good news is that the problems so far has been reduced
@sannygt try temporarily swapping the motor plugs between a working axis and X to see if the problem moves axis or stays with the existing one. What did you do to solve the issue on the other two axis?
I increased the motor current to 1800ma so it receive a bit more power
But the X motor barely moves at 3000ma. and there is barely torque on the X motor when it moves. I think that i am just gonna buy a new stepper motor to replace X motor with a bit more power.
@sannygt did you try the test i suggested?
Yes unfortunately there was no result,
The X motor kept vibrating so i guess the motor itself.
@sannygt yes sounds like that motor is faulty
Hi @T3P3Tony
I installed some brand new motors to the machines and it is working perfect now. So the problem was the motor itself.
Thanks for the suggestions everyone!
