Can't stay connected after adding heated bed?
It's a fairly small and weak antenna and needs to be in the clear to send and receive properly. I can definitely see how a heated bed blocking it with all it's electrical wiring and high current could cause interference.
I can understand interference, but what kind of distances are we talking in order to avoid said interference? I'll inevitably have to extend a ton of wires move it out from underneath so I'd like to get it right the first time.
It's going to depend. Perhaps you can post a photo of your current setup so we can gauge better if interference is likely.
https://duet3d.dozuki.com/Wiki/Mounting_and_cooling_the_board#Section_Wireless
If you run M122 you can find out the strength of the wireless signal currently.
I also notice that you're running release candidates of the wifi server and web interface. It may be worth upgrading those to full releases to see if you get any improvement in connection stability.
The bed heater element will act as a WiFi shield. If the Duet WiFi is mounted underneath the bed (which is a common arrangement for delta printers) then the WiFi antenna should protrude from an opening at the side. To see how I do it on my delta, see https://www.thingiverse.com/thing:965396.
My arrangement is nothing like that. I'll try to grab a picture this afternoon, but the bed is almost 2 feet above the electronics board.
Disregard the mess.
It's hard to make out the Duet in your photo. I suggest:
- Keep the wiring clear of the WiFi antenna
- If possible, mount the Duet with the wifi antenna well clear of the aluminium frame, and preferably vertical instead of horizontal
- Use the M122 command to check the WiFi signal strength with the Duet in various locations and various orientations
@kskiff7034 said in Can't stay connected after adding heated bed?:
Disregard the mess.
That looks like a Dbot. I mounted the duet along the right bottom side rather than directly underneath. Added benefit of having it vertical. Though in your case it's hard to say if it would make a difference as the bed is quite high above it. What are you getting for signal strength? Can you bring the router in the same room and see if it still drops out? If it still drops than maybe you have some wiring issues?
It began as a D-Bot, but there's so many changes it's hard to call it a D-Bot at this point.
The problem seems to come and go. I just ordered a bunch of wire and am going to dive into the arduous task of re-doing all the wiring from scratch and cleaning everything up. If the problem persists I'll get some more details and try to dive further in.
I think that's the story of most DBots. It's a good starting platform for customization.
Good luck with the wiring. My suggestion is to do everything right the first time, because once it's in there you will loathe to take it all down again to redo something. Ask me how I know.
