Stable firmware 2.01 (Duet 2) and 1.22 (Duet 06/085) released
I’ve never uploaded a new one, can i just delete the old one and replace it with the new one using the web interface?
@qdeathstar said in Stable firmware 2.01 (Duet 2) and 1.22 (Duet 06/085) released:
You can just upload the new one through the web interface.
New features/changed behaviour:
- The Z probe MOD pin can now be accessed as a GPIO pin
GPIO pn can be PWM capable? This pin should be PWM capable...... It would be so much easier to set a lot of different probes with a single connector if it was.
The Z probe MOD pin on the Duet WiFi/Ethernet is not PWM capable.
One very minor bug with the latest DWC, on smaller screens the text for speed is mangled, I think with some reduction in padding this should be fixable.
@dadiy thats not the latest version of DWC
@dougal1957 1.21.2-dc42 was the that was on the Github with the firmware and its newer than on https://github.com/chrishamm/DuetWebControl so perhaps a pointer to the newer version would be helpful.
@dadiy https://forum.duet3d.com/topic/5485/duet-web-control-wishlist-notes-and-priorities/63 in the DWC Section of the forum
Found a new problem, "object height" is no longer populated since the latest firmware/DWC.
Slicer is the same as can be seen from the pic.
The only thing I have changed is upgrading DWC and the firmware to the latest available versions:Firmware Name: RepRapFirmware for Duet 2 WiFi/Ethernet Firmware Electronics: Duet WiFi 1.02 or later + DueX5 Firmware Version: 2.01(RTOS) (2018-07-26b2) WiFi Server Version: 1.21 Web Interface Version: 1.22-b3
@whosrdaddy I just checked on my machine with same versions and I cannot reproduce it neither for existing nor for just now newly uploaded Gcode files. Though, mine are all sliced with Cura.
Ok, I sliced a smaller file and now I can see the object height. I suppose the firmware does not attempt to read the height for larger files?
@whosrdaddy I just uploaded the largest GCode file I could find on my hard drive (just a little under 11 MiB) and it got the height correctly from it. I also checked the file and it does not contain a comment with object height, so RRF must have scanned for the last rise in Z.
Don't get me wrong, I don't wanna say you don't have a problem, just that I cannot reproduce it.
Could you try to slice the same source file with another slicer?
Well did as requested and it seems it has nothing to do with the slicer, used exactly the same STL files:
@whosrdaddy OK, your file is larger than mine, so maybe there is a lower limit to this issue.
@whosrdaddy Can you post the stl for the 2 that fail so we can try it? I have several file much bigger than those that are correct
Sure, you can download it from here:
https://www.thingiverse.com/download:3377042 -
@whosrdaddy With this file I can reproduce your issue:
@whosrdaddy this is what I get for that file
It's not easy to read cos this forum is re-sizing the image but my file is 3 times the size of yours but gives 8.2mm hight and 39.xxx mtrs of filament. the diff may be the amount of infill mind
so we established there is an issue, it's not the file size because you have a 31MB file.
Lets wait & see what @dc42 thinks about this...
