Stable firmware 2.01 (Duet 2) and 1.22 (Duet 06/085) released
Next to the date, what does the b2 mean in firmware version number (2018-07-26b2)? Obviously doesn't impact anything just curious.
It means it was the second build of the day.
When i try to upgrade from 2.0 to 2.01 it goes through the motions of upgrading ("do you want to update?", yes, the bar moves)" but after its done it still ways 2.0 (2018 - 06 - 05b3)....
Firmware Electronics: Duet WiFi 1.0 or 1.01
Firmware Version: 2.0(RTOS) (2018-06-05b3)
WiFi Server Version: 1.21
Web Interface Version: 1.21.2-dc42Any ideas?
@qdeathstar You didn't fall into the same trap as me did you? - see the strike through text on my post above (and the Edit below that).
unfortunately no, i thought that might be happening so i downloaded the file into a completely different folder, no dice.
@qdeathstar Just a shot in the dark: delete the existing firmware file on the Duet first before uploading the new one. If this works there might be a SD card failure upcoming.
I eventually solved it by changing the name of "Duet2CombinedFirmware.bin" to "DuetWifiFirmware.bin" and it worked..... I had to do this going from 2.0 to 2.01beta2 (trying to fix the OG problem) and then also when upgrading from 2.01beta2 to 2.01 stable...
It wasn't a old file issue like deckingman suggested because i tried updating the firmware on a mac and then on a PC. But, hey, at least it is fixed.
Is that normal?
Funny mistake I just noticed:
If you hover over the Voltage Sensor display on the top right, the display says 12.1 V actual, Minimum: 12 °C and Maximum: 12.3 °C But Voltage isn't temperaturegreetings kuhni
image url)
@qdeathstar said in Stable firmware 2.01 (Duet 2) and 1.22 (Duet 06/085) released:
Is that normal?
Yes if you have a very old version of iap4e bin on the SD card.
I’ve never uploaded a new one, can i just delete the old one and replace it with the new one using the web interface?
You can just upload the new one through the web interface.
New features/changed behaviour:
- The Z probe MOD pin can now be accessed as a GPIO pin
GPIO pn can be PWM capable? This pin should be PWM capable...... It would be so much easier to set a lot of different probes with a single connector if it was.
The Z probe MOD pin on the Duet WiFi/Ethernet is not PWM capable.
One very minor bug with the latest DWC, on smaller screens the text for speed is mangled, I think with some reduction in padding this should be fixable.
@dadiy thats not the latest version of DWC
@dougal1957 1.21.2-dc42 was the that was on the Github with the firmware and its newer than on https://github.com/chrishamm/DuetWebControl so perhaps a pointer to the newer version would be helpful.
@dadiy https://forum.duet3d.com/topic/5485/duet-web-control-wishlist-notes-and-priorities/63 in the DWC Section of the forum
Found a new problem, "object height" is no longer populated since the latest firmware/DWC.
Slicer is the same as can be seen from the pic.
The only thing I have changed is upgrading DWC and the firmware to the latest available versions:Firmware Name: RepRapFirmware for Duet 2 WiFi/Ethernet Firmware Electronics: Duet WiFi 1.02 or later + DueX5 Firmware Version: 2.01(RTOS) (2018-07-26b2) WiFi Server Version: 1.21 Web Interface Version: 1.22-b3
@whosrdaddy I just checked on my machine with same versions and I cannot reproduce it neither for existing nor for just now newly uploaded Gcode files. Though, mine are all sliced with Cura.
