New beta firmware 2.01beta1/1.21.2beta1 available
@dc42, Java script error, if you save settings in the web interface.
I use windows 10, error was in Firefox developer.
Z moved in -Y. -
@dc42, if you want, I could install it this night and write down the errors.
John had the same problem with a Delta in Z axis
https://forum.duet3d.com/topic/5842/weird-z-behavior-with-first-attempt-with-rtos-firmware-on-delta/2
When I tried to open the js.gz, I got an error from Microsoft Scripting host:
just installed the beta 2 today and the Script errors are gone if i want to add a new temp button
hi! i did not find a link to b2 and now using b1 .
in webUI it showsError: Can't open 0:/sys/oem.json to read, error code 4
There is no b2 - @Barracuda72 is this a typo?
@c310 the oem.json error is normal - only OEM vendors ship this file. "Normal" users can ignore the error.
There is a b2 of DWC 1.21.2, it's in chrishamm's github repo.
As David stated...no typo
I am getting an error that I know I am making happen. I currently have V2.0 and I tried to upgrade to 2.01. I downloaded "Duet2CombinedFirmware.bin, loaded it to my DuetWifi, try to update, and I get an error,
'Error: M997: In-application programming binary "iap4e.bin not found'I know this has to be something I am missing, but I dont have any idea where to start looking to fix the problem. Hopefully someone can point me in the direction I need to go to fix this problem.
Thanks
TC -
Maybe try updating the IAP files again?
@iamturbo1978, download iap4e.bin from https://github.com/dc42/RepRapFirmware/releases/tag/2.0 and upload it through the Settings General page of DWC.
@dc42, Wonderful. Thank you so much for the help.
I just upgraded my DuetWifi will latest releases (Firmware 2.01beta1 / Web server 1.21 / Web interface 1.21.2-b2), and now, I can't home anymore; when I click on either 'home all/x/y/z' buttons, I get:
G28
Error: G0/G1: insufficient axes homedWhat did I miss?
See the upgrade notes for release 1.21.
Ok, need to add S3 to G0 command lifting Z before it is homed...
Thanks!
@fma said in New beta firmware 2.01beta1/1.21.2beta1 available:
Thanks!
Or, if you want to allow axis movement prior to homing, put M564 H0 in config.g.
Thanks!
S2, not S3.
I have added DWC 1.21.2-b2.zip to this beta release. I had already removed DWC 1.21.1-b1 from it.
