My prints are in mirror, but the axis are good.
So it definitely looks like you have it configured for Y max homing, but simplify 3D is set for Y min homing.
@mickey30m said in My prints are in mirror, but the axis are good.:
That's a left-hand coordinate system, which explains your problem. Tell S3D to flip the Y axis.
@dc42 that have i changed. Before was IT also in mirror.
I Just flip it tot test it. I had it before on right hand
But same prints.
I will change it now.
I now slice it with cura the new version.
Default settings.
And Also prints in mirror. With a 0.06 later height so its printing for a long time now ;-).
But a Nice print. But in mirror :') -
okay
just for sure, i take photos from all my settings and download my config file.
https://photos.app.goo.gl/OLfa5DH2pnX90JBi2
0_1525205946994_config.gwhen everything is homed i get this in webcontrol
https://photos.app.goo.gl/ZJxTiC9zjXVzdQwL9Machine Status
Head Position X Y Z
15.0 280.0 14.95
Extruder Drives Drive 0
n/a 0.0
Sensors Vin Z-Probe Fan RPM
11.8 V 0 -
Are you absolutely certain that when you press the X+10 button the head moves to the right, and when you press Y+10 it moves towards the rear of the printer i.e. away from you?
https://photos.app.goo.gl/I6pkMGxCEYRMDCmm2see this video.
first i home twice (because y dont wont go in 1 time) (i ask for this later)
than i push
5 times on X+10
5 times on Y+10
5 times on Z+10 -
You have set your printer up with a left hand coordinate system. If +X is to the right, then +Y must move the head towards the rear relative to the bed. As it is the bed that is moving, +Y should move the bed towards you.
You will need to reverse the direction of the Y motor (M569), change the configuration of the Y endstop from low-end to high-end or vice versa (M574), and change homey.g and homeall.g to home in the opposite Y direction.
Sorry for the misunderstanding.
I think now everything is working good...
i go make a print and lett you know..but what a super nice board is it....
first it is a little bit looking for everything.
but change homex.g and no need to reboot or whatever....
damnnnIn the beginning I thought it was a lot of money for a new board. but after a bit of looking around and reading. I was up. and now I am completely up. and I regret that I did not switch sooner ...
soon to buy two more for a DIY project.
Super thanks
Glad to help!
