How to create a mesh for Bltouch
To do mesh grid compensation you will need to specify the grid area in config.g with M557 and then tell it to load your saved heightmap on powerup with M375.
For example:
M557 X15:285 Y15:245 S30 ; Define mesh grid M375 ; Load heightmap.csv
To create a heightmap, run G29. Ideally after you've tried to level your bed mechanically as good as possible.
@phaedrux said in How to create a mesh for Bltouch:
For example:
Thank you for your answer, I just did what it says but when I send the G29 command the printer moves about 15mm and then stops and does nothing, the duetwifi plate stays in busy state and I can only hit the stop button emergency, why does this happen to me?
Send M557 without parameters and review the response, to check that the mesh parameters you set in config.g have been accepted.
After you run G29 and it stops, check the GCode Console page of Duet Web Control for error messages.
@dc42 said in How to create a mesh for Bltouch:
When I send the M557 command, the following message appears:
M557
Grid: X15.0:205.0, Y15.0:245.0, radius -1.0, X spacing 30.0, Y spacing 30.0, 56 pointsAfter sending G29 there is no error message or anything, the printer moves a little and stops, the status of the printer is always busy and nothing else I can give emergency stop or turn off the duertwifi and turn it on current.
Please change your microstepping from x256 to x16 with interpolation enabled in the M350 command in config.g and try again.
Hello I have changed it to x16 interpolated and now if it works correctly, although the noise from the engines is annoying, is there any way to work it to x256 interpolated?
M350
Does your M350 command have I1?
But I do not understand why with the configuration of X16 interpolated steps if it works correctly but when I change it to interpolated X256 the G29 command does not work
Depending on your steps/mm and how fast you are trying to move the print head, the rate at which step pulses need to be generated and the Z probe checked can exceed the capabilities of the processor. When this happens the movement should just slow down, however in the past few days it has become evident that under some conditions it causes the movement system to lock up. This is on my list to investigate and fix.
So for the moment the only solution is to run X16 the steps of the engine? I buy a duetwifi for the X256 and for the little noise that engines make but if I have to run to X16 it makes the same noise as my mks gen
@ivang from a noise perspective running x16 interpolated to 256 and running x256 is functionally the same. The only difference is that the driver is generating the intermediate steps. I could not tell a noise difference between the two during testing.
I think maybe you do not have I1 in you M350 command ?
Also note that interpolation only works on x16 (not for example x32 and x64)
@t3p3tony said in How to create a mesh for Bltouch:
He is right I just put the end I1 and the noise is almost nonexistent, thank you very much.
@ivang glad you got it sorted!
