Possible bug with first layer height always showing 0.2mm
Do you have anything in your slicer start gcode that moves the head to Z0.2 ?
Why yes I do. I purge a line of filament. Makes sense as I recently added that to the start code.
Is that expected behaviour?
The firmware determines the first layer height by looking for the first G1 Znn move where nn is a plausible layer height.
I could be wrong but something at the back of my mind tells me that using G0 Znn instead of G1 Znn might be a cure? I believe G1 and G0 moves are treated the same as regards to movement but if the firmware looks for G1 Znn to determine layer height, would it ignore G0 Znn?
I can give that a try.
Does it matter if the first g1 move is commented out or not? I could add ; G1 Z[first_layer_height] at the start.
Can't you use G1 [first_layer_height] at the start, followed by G1 Z0.2 ?
Now that you mention it, obviously I can. Thanks David.
@dc42 So it doesn't seem to work as hoped.
; Purge some filament
G90 ; Absolute positioning
G1 X25 ; drop nozzle down to the bed
G91 ; Relative positioning
G92 E0 ; zero the extruded length
G1 X25 E5 F200 ; extrude 5mm while moving right
G1 E-0.5
G92 E0 ; zero the extruded length again
G90 ; absolute
G1 Z0.05
G91 ; relative
G1 Y10 F8000 ; wipe nozzle
G90 ; absolute
M400The only Z height it seems to use for display in the DWC is the G1 Z0.05 now. It ignores the ones that use the slic3r variable place holders [first_layer_height].
Not a big deal.
What does the start of the generated gcode file look like?
@dc42 it looks the same as what I posted above except [first_layer_height] has been replaced by the numerical value for the layer height. In this case 0.26
Full gcode here: https://www.dropbox.com/s/mleu5lljacvyq0k/Wooden_bowl.gcode.zip?dl=1
Just an update.
I added a feedrate to the G1 command and now they show up in the DWC properly.
G1 Z[first_layer_height] F600
