First-Time Setup - Problem with Connecting to Network
The IP it gave should be fine.
If you reboot the board and wait for the blue light to stop flashing you should be able to connect to that IP address.
I assume that by reboot you mean 'reset', right? (sorry, not meaning to be pedantic, just not familiar with this controller and wanted to make sure we're talking about the same thing).
If we are, I tried it and it didn't work either :-@
I've tried rebooting the controller both by clicking the 'reset' button in Printrun, and in a separate attempt, by clicking the physical 'reset' button on the DuetWifi.
I should note that in both cases, I didn't see any blue light blinking. There was a red light next to the USB connector on the controller that turned on for a few seconds and then turned off.
Not sure how to proceed with this?
(edit: sorry, forgot to mention that in my response to dc42 in the following post, I include 2 screenshots: one of Printrun indicating that the connection has been established ok, and on of the Chrome webpage with the IP address that can't be found - perhaps this would help make sense of things?)
So if you enter http://192.168.1.108 into your browser address bar (assuming that is the IP address that M552 reports every time), it should connect.
Hi dc42 & thanks for joining the conversation!
I tried your suggestion, but still no go.
In a bit more detail, I repeated the whole procedure once again, that is, connecting the DuetWifi to the Mac over USB, starting up the wifi module, and making sure I got confirmation about the connection being established.
Here is a screenshot of Printrun and the information in the console: https://drive.google.com/open?id=1LzulArSIj3sFN6ReQ7uKg1I_oJbO-2Gb
Despite that, when I go to Chrome and enter the exact address you gave, I get an error message about the page not being found.
Here's a screenshot of the result I get in Chrome: https://drive.google.com/open?id=1sleWbq0t-RCWi841cxvONJ03VNB71wpM
Btw, you might notice the 'http://' missing from the address bar, but that's just Chrome removing it automatically (I typed the address exactly as you did) - if you look at the content of the message on the error page, it shows the full address with the 'http://'.
Help please?
The blue light on the wifi module will blink when the M552 S1 command to connect to your WiFi network is processed; except that if that command is in your config.g file, it will be deferred until config.g has finished running.
Thanks for the quick response dc42!
Ok, but I'm unclear as to how does that help me solve the current problem of not being able to see the web interface.
Could you please explain more? (preferably, in a step-to-step total noobie style
Just out of curiosity, I reset* the controller again and run the 'M552 S0' & 'M552 S1' commands, while looking at the wifi module on the controller the whole time, and saw no blue light anywhere (although the Printrun console confirmed that a connection was established like before).
Could it be that the wifi module on the controller isn't working as it should and that's the source of the problem?
- by 'reset' I mean a hard-reset, i.e. pressing the physical 'reset' button on the controller.
I meant to power cycle the board. I'm not exactly sure if the reset button has the same effect.
As far as I can tell, if you are getting an IP address from the duet connect message then you should be able to use that IP to connect to the DWC.
Which firmware version are you using? Older versions of the WiFi module firmware don't flash the blue LED.
Thanks for the clarification, Phaedrux!
I've done the power cycle too, and still no go.
dc42 said it should work as well, but unfortunately so far it doesn't…
btw, I've check the browser side to see that there's nothing blocking the content, but couldn't find anything there either.
As noted in my original post, firmware version number: 1.19.2
Here is what I got in the Printrun console:
M115
SENDING:M115
FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.19.2 ELECTRONICS: Duet WiFi 1.0 FIRMWARE_DATE: 2017-09-01Btw, any idea why I'm constantly getting automatically unsubscribed every time I post on this thread?
Ok, that explains why the blue led doesn't flash.
With the Duet powered on, if you open a terminal window and use the command [c]Ping 192.168.1.108[/c] What do you get?
If you remove the SD card from the Duet and put it in your computer do you see files listed? Can you post the contents of config.g if it exists?
Looks like there's something working there.
Here's a screenshot of what I get when I ping the address from terminal: https://drive.google.com/open?id=1oe_3Y65EfZliX55R7QwzH_N8s8GVv1sL
Does this tell you anything?
I don't have an SD card reader on hand atm, but will get one tomorrow so I can find out and post the results.
Thanks again, Phaedrux!
Another update & it's not a particularly happy one:
Got my hands on a Windows 7 PC and I can now confirm that the exact same problem I've been experiencing on my Mac also occurs in the Windows setup.
In more detail, I've installed the Duet drivers without a hitch, downloaded and run YAT, and repeated the by now familiar procedure of starting the wifi module, getting confirmation of a connection and finally, the error message that the page can't be found in Chrome.
For comparison, here's a screenshot of YAT showing the above procedure:
https://drive.google.com/open?id=10JMymyqviY-IiLkknzm9QSrbHp-5lTUg
And here's a screenshot of the terminal window (or whatever it's called in Windows) running the ping command:
https://drive.google.com/open?id=1JmmGHdT2f3HJK68FZTcR8MrYII7DPhDk
Like I said, the result is unchanged, i.e. page not found in Chrome.
Another small detail I noticed is that in my 'remembered list' of wifi routers there are 2 slightly different entries - one is the correct router name and the other is incorrect as it's all uppercase.
However, in the connection confirmation message in YAT, the correct router name appears so I'm guessing that's not the problem (but do correct me if I'm wrong on this).
Lastly, in the Windows setup, I also changed the baud-rate value from 9600 to 115200 as I seem to remember seeing that speed setting on the Mac, but it made no difference.
From all this it's starting to look to me like this boils down to a hardware problem either in the wifi module or somewhere else in the controller.
With that said, I still need to check the content of the SD card and report the results in the hope that the problem is actually there and can be manually fixed. I'll hopefully get this done tomorrow when I get the SD card reader.
In the meantime, if anyone has any insight about the information above or the problem in general, please do let me know.
Well I don't think there is a hardware issue just yet. You are able to ping the board and it is replying, so that's good. You're on the network.
The duplicate wifi network with all caps is just a dud entry. It will do no harm. You can tell it to forget that network later.
There might be something wrong with the files on the SD card preventing a webpage from showing, so until we can verify what's on the card I'm not sure how best to proceed.
We could try setting up the Duet to run in access point mode where it creates it's own network and you connect to it that way, but if there is something wrong with the files on the card it would lead to the same result.
Just a shot in the dark, but have you tried power cycling your wifi router?
Also, how far away is the Duet from the router?
Have you ever logged into your router web interface?
It would be nice to verify at the router end that the Duet is actually getting a proper IP address.
Cool, and…?
And now we know which firmware is installed. In 1.21 the wifi LED blinks 3 times and then goes solid when it's ready to go and is turned off when the wifi module is off.
Hi Phaedrux,
Turns out the problem is almost certainly with the SD card (or related hardware)!
It just occurred to me to connect the PanelDue (which I got with the DuetWifi) and see what it shows (sorry, I didn't think about this before because I haven't had any experience with the display before and didn't know it can show the content of the SD card).
I discovered that the display itself works fine, but when I click on the SD Card icon (or anything else that requires the card like the 'macros' button), I get the following error message:
Files on SD Card 0
Error 1 Accessing SD Card
So either the SD card is empty or faulty or the hardware used for reading it is defective.
I'll only be able to confirm if it's the card tomorrow when I get the reader, though.
However, in the likely even that it is the card that's been causing the problem, do you know if there's a source somewhere from which I could download all the relevant content and paste it into a new replacement card?
The PanelDue SD card slot is a little different than the main slot. I'm not sure these results are conclusive.
But yes, you will be able to recreate the correct directories on the card if they are missing.
Ah, I didn't realize the PanelDue is attempting to read the card from its own slot - I thought it was trying to read the SD card in the controller.
Another step forward, though. I dug up my old camera and discovered an SD card adapter which meant I could read the content of the DuetWifi Mirco-SD card on my Mac.
And the card seems to be reading fine…
I've uploaded all the content of the SD Card here: https://drive.google.com/open?id=19-slsC29NlJQrPa0UW8JmAyMfc3sW_aC
Could you please have a look and see if it's right?
First thing I would do is a make a backup of the contents of the card. Just in case.
The config files on the card are pretty generic and will need to be modified to suit your printer.
But there might be one change we can try to see if it will get you connected. I really don't know if this will help, but it's the only thing I can see that might be interfering.
In the config.g file find the lines that have
[c];*** Ethernet networking: Adjust the IP address and gateway in the following 2 lines to suit your network
M552 P192.168.1.14 ; (0 = DHCP)
M554 P192.168.1.255 ; Gateway
M553 P255.255.255.0 ; Netmask[/c]
and either add a ; before each line, or just delete them.Put the card back in and power it up and see if you can connect.
Even if that doesn't let you connect, I think you should try getting a configuration file package ready to go anyway with the online config tool.
https://configurator.reprapfirmware.org/
It will ask you to enter your network information as well and will generate a full set of config files that should more closely match your printer since you'll be providing the details. When you have that ready, copy it over to the SD card and replace the existing files, and give those a try.
