New Board Can't Connect to Wi-Fi.
First, THANK YOU for accepting me into this forum. It's greatly appreciated!
Second, please forgive me if this has been answered before, but I've searched and can't find the answer.
I just purchased a Wifi-Duet and got it yesterday. I used the supplied mini-USB to connect it to YAT on my computer. When I go through the steps to connect my board (M115 shows firmware 1.19.2, M552 shows "idle," M587 S"MY ACTUAL NETWORK NAME" P"MY ACTUAL PASSWORD") it goes well until the M587 S1 command. At that point I get "ok<lf>WiFi reported error: no known networks found<lf>Wifi module is idle<lf>"
Am I doing something wrong? Is the module malfunctioning? My router is 2.4MH and functioning with every other piece of equipment I have.
Thanks in advance for your help!</lf></lf></lf>
I presume you mean until the M582 S1 command, not M587 S1. I suggest the following:
1. Check that your router is configured to provide a network on the 2.4GHz WiFi band. The Duet WiFi does not support 5GHz.
2. Run
M577M587 with no parameters to list the configured WiFi networks, and check that the SSID shown is exactly the same as the one your WiFi network transmits on 2.4GHz, as shown on your smartphone if you scan for WiFi networks. SSIDs are case-sensitive.3. If the SSID is exactly correct then it is probably a signal strength issue. See https://duet3d.dozuki.com/Wiki/WiFi_disconnections_and_AJAX_timeout_errors#Section_How_to_improve_RSSI.
Thanks for the help, DC42.
I ran the M577 command and got the following: "ok<lf>" Nothing else. I confirmed that my network is running at 2.4 GHz and that signal strength is excellent with a link speed of 1.44 Mbps on my cell phone. Any other thoughts on what I can do?
Thanks again.</lf>
I'm sorry. I meant M587.
This post is edited to add correct information:
Sadly, no joy.
When I use the 587 command, I get the following: "Remembered networks:<lf>TNCAP2FCC19<lf>My Network Name<lf>your=network-My Network Name Fa<lf>your-network-My Network Name Fa<lf>My Network Name <lf>My Network Name 2<lf>ok<lf>"
When I type the 552 S1 command, I still get: "ok<lf>WiFi reported error: no known networks found<lf>Wifi module is idle<lf>"
Hope I'm not being dense…</lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf>
The latest: now an M587 command reports "M587: Failed to retrieve network list<lf>ok<lf>" This is after an M552 command that shows WiFi module idle. Seems like I have a defective board. Anyone else have any ideas before I return the board as defective?</lf></lf>
Please run M122 and check that the versions of main firmware (listed near the start of the response) and WiFi firmware (listed under the "Network" section) are compatible.
I had Firmware version 1.19.2 but upgraded to the latest 1.21 via SD card in the hopes that would help. When I run M122 I get the following:
m122
=== Diagnostics ===<lf>Used output buffers: 1 of 32 (1 max)<lf>=== Platform ===<lf>RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.02 or later<lf>Board ID: 08DDM-9FAM2-LW4S4-6J1DA-3S46R-K3TZW<lf>Static ram used: 16152<lf>Dynamic ram used: 100600<lf>Recycled dynamic ram: 2032<lf>Stack ram used: 3576 current, 4420 maximum<lf>Never used ram: 7868<lf>Last reset 00:00:18 ago, cause: power up<lf>Last software reset details not available<lf>Error status: 0<lf>Free file entries: 10<lf>SD card 0 detected, interface speed: 20.0MBytes/sec<lf>SD card longest block write time: 0.0ms<lf>MCU temperature: min 21.3, current 23.6, max 23.7<lf>Supply voltage: min 1.4, current 1.5, max 1.5, under voltage events: 0, over voltage events: 0<lf>Driver 0: ok, SG min/max not available<lf>Driver 1: ok, SG min/max not available<lf>Driver 2: ok, SG min/max not available<lf>Driver 3: ok, SG min/max not available<lf>Driver 4: ok, SG min/max not available<lf>Date/time: 1970-01-01 00:00:00<lf>Slowest main loop (seconds): 0.001772; fastest: 0.000041<lf>=== Move === <warning: maximal="" number="" of="" bytes="" per="" line="" exceeded!="" check="" the="" end-of-line="" settings="" or="" increase="" limit="" in="" advanced="" terminal="" settings.="">I can't tell you how much I appreciate the help, DC!</warning:></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf> -
I noticed that in my last post, I exceeded the number of bytes per line which truncated the command reply. Here is the full display with the M122 command:
m122
=== Diagnostics ===<lf>Used output buffers: 1 of 32 (1 max)<lf>=== Platform ===<lf>RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.02 or later<lf>Board ID: 08DDM-9FAM2-LW4S4-6J1DA-3S46R-K3TZW<lf>Static ram used: 16152<lf>Dynamic ram used: 100600<lf>Recycled dynamic ram: 2032<lf>Stack ram used: 3576 current, 4420 maximum<lf>Never used ram: 7868<lf>Last reset 00:02:09 ago, cause: power up<lf>Last software reset details not available<lf>Error status: 0<lf>Free file entries: 10<lf>SD card 0 detected, interface speed: 20.0MBytes/sec<lf>SD card longest block write time: 0.0ms<lf>MCU temperature: min 18.7, current 25.6, max 25.7<lf>Supply voltage: min 0.5, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0<lf>Driver 0: ok, SG min/max not available<lf>Driver 1: ok, SG min/max not available<lf>Driver 2: ok, SG min/max not available<lf>Driver 3: ok, SG min/max not available<lf>Driver 4: ok, SG min/max not available<lf>Date/time: 1970-01-01 00:00:00<lf>Slowest main loop (seconds): 0.001768; fastest: 0.000041<lf>=== Move ===<lf>MaxReps: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0<lf>Scheduled moves: 0, completed moves: 0<lf>Bed compensation in use: none<lf>Bed probe heights: 0.000 0.000 0.000 0.000 0.000<lf>=== Heat ===<lf>Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1<lf>Heater 1 is on, I-accum = 0.0<lf>=== GCodes ===<lf>Segments left: 0<lf>Stack records: 1 allocated, 0 in use<lf>Movement lock held by null<lf>http is idle in state(s) 0<lf>telnet is idle in state(s) 0<lf>file is idle in state(s) 0<lf>serial is ready with "m122" in state(s) 0<lf>aux is idle in state(s) 0<lf>daemon is idle in state(s) 0<lf>queue is idle in state(s) 0<lf>autopause is idle in state(s) 0<lf>Code queue is empty.<lf>=== Network ===<lf>Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)<lf>HTTP sessions: 0 of 8<lf>- WiFi -<lf>Network state is running<lf>WiFi module is idle<lf>Failed messages: pending 0, notready 0, noresp 0<lf>WiFi firmware version 1.19.2<lf>WiFi MAC address 60:01:94:73:5b:4b<lf>WiFi Vcc 3.08, reset reason Turned on by main processor<lf>WiFi flash size 4194304, free heap 40544<lf>Socket states: 0 0 0 0 0 0 0 0<lf>=== Expansion ===<lf>ok</lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf> -
Please put LF as line ending (<eol>) in YAT, this will give you proper printouts</eol>
Thanks for the tip, Whosrdaddy.
Here is the command response in proper format:
ok
m122 <cr>=== Diagnostics ===
Used output buffers: 1 of 32 (9 max)
Dynamic ram used: 100800
Recycled dynamic ram: 1832
Stack ram used: 3576 current, 4584 maximum
Never used ram: 7704
Last reset 00:01:29 ago, cause: power up
Error status: 0
MCU temperature: min 26.5, current 27.2, max 27.2
Supply voltage: min 1.6, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0
Slowest main loop (seconds): 0.004284; fastest: 0.000042
Segments left: 0
=== Network ===
HTTP sessions: 0 of 8- WiFi -
WiFi module is idle
=== Expansion ===
ok</cr>
- WiFi -
You are running main firmware 1.21 but WiFi firmware 1.19.2. Please upgrade your wifi firmware to 1.21. As you can't connect via WiFi at present, you will need to move the SD card to a PC, copy the new DuetWiFiServer.bin file to /sys, eject or safely remove it, put the card back in the Duet, restart the Duet, and send M997 S1.
After that, if you run M122 it should report "WiFi firmware version 1.21" in the Network section.
Sadly, still no joy.
I updated both firmware and wifi drivers to 1.21.
When I run M122, I get:
m122
Used output buffers: 1 of 32 (8 max)
Stack ram used: 3576 current, 4900 maximum
Never used ram: 7388
Last reset 00:17:35 ago, cause: power up
Error status: 0
MCU temperature: min 31.8, current 35.3, max 35.4
Slowest main loop (seconds): 0.100089; fastest: 0.000041
Segments left: 0
=== Network ===
WiFi module is idle
WiFi Vcc 3.36, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 19808
=== Expansion ===
ok
When I run M587, I get:
m587
TNCAP2FCC19 IP=192.168.1.14 GW=0.0.0.0 NM=0.0.0.0
MY NETWORK NAME IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
your=network-MY NETWORK NAME IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
your-network-MY NETWORK NAME IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
MY NETWORK NAME IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0Yet, when I run the M552 S1 after setting-up the network with the M587 S"MY NETWORK NAME" P"MY PASSWORD" command, I get:
m552 s1
ok
WiFi module is idleok
My wifi network has an apostrophe in its name. Perhaps that could that be the problem? Any additional thoughts? At this point I'm close to stumped…
- WiFi -
Never trust an apostrophe and anything to do with computer naming.
Apostrophe in a quoted string forces the following character to lowercase. So you need to use two apostrophes to represent one, in both SSIDs and passwords.
I suggest you send M588 "*" to delete all those dud remembered networks, then send the M587 command using two apostrophes in the SSID this time. Then send M587 without parameters to check it is remembered correctly.
Huzzah! That was the issue; a silly little apostrophe in the network name. My Duet Wifi is now connected to my network.
A big THANK YOU to all who helped, but especially to you dc42 for you patience and generosity with this issue!
No problem, it was you who suggested the apostrophe might be the problem and made the diagnosis easy. I've updated step 7 at https://duet3d.dozuki.com/Guide/1.%29+Getting+Connected+to+your+Duet/7?lang=en to cover the case of apostrophes in the SSID and password.
