It's out! Firmware 1.21 released
last touch ups to the pulse filament detector are also included ?
Looks like it:
New features and changed behaviour since 1.21RC5:
The rr_status and M408 reports now include the spindle speed
M106 now also reports the current fan PWM for thermostatically-controlled fans
Machine coordinates are always used when running system macros automatically.
Bug fixes since 1.21RC5:Pulse-type filament monitors are now working
WiFi sockets whose connections abort are now terminated to make them available for re-use
DWC Machine Properties page shows the correct state of active low endstops -
great! thank you
great! thank you
Not sure if this is intended or not, but when trying to simulate a file I get various error messages if the axes are not homed first.
[c]2:02:49 PMM37 P"z-motors_fixed.gcode"
Simulating print of file z-motors_fixed.gcode
Cancelled simulating file z-motors_fixed.gcode after 0h 0m simulated time
Error: G0/G1: insufficient axes homed
2:02:16 PMWarning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
2:02:16 PMM37 P"lm2596_case_fixed.gcode"
Simulating print of file lm2596_case_fixed.gcode
Error: SetPositions called when DDA ring not empty
Cancelled simulating file lm2596_case_fixed.gcode after 0h 0m simulated time[/c] -
That's a known issue.
I have updated the firmware from 1.20 to 1.21. Now the printer does not work anymore.
When I upload a print file, the bed and the extruder are heated, then the printer stops as if it is ready.
At Home All I get the error message G0 / G1: insufficient axes homed. -
Nengerman: you have to read the release notes! Homing on a Cartesian/CoreXY printer changed.
Does you'r homing script 1st lower/raise bed before it homes X and Y ? If so you need to add S2 parameter to you'r Z axis movement and then X and Y can be homed and Z axis after that
Get it from https://github.com/dc42/RepRapFirmware/releases/tag/1.21 and be sure to read the upgrade notes at https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md. If you want the full list of changes since release 1.20, for now you will have to read all of the 1.21RC release notes too, but in a few days I'll delete the 1.21RC releases and consolidate the change lists.
Hello
there ist webcontrol 1.21 out
https://github.com/chrishamm/DuetWebControlIngo
Thanks, I've updated the release to include it.
I was running rc4 and have today updated to 1.21. I expected this to just work.
I uploaded the Duet2CombinedFirmware.bin, DuetWiFiServer.bin, iap4e.bin and DuetWebControl.zip files. When the duet rebooted it could not connect.
The USB printer interface connected to the printer so I tried to run M997 S0 to install the firmware again but this did not work.
I then erased and reset the board and used BOSSA 1.18 to install, so device manager shows Duet 2 WiFi or Duet 2 Ethernet 3D printer control electronics (COM5)
Then reset the board and connected the USB again. The printer is online but when I send M997 S0 I get the error Can't read from printer (disconnected?).
I have followed the Fallback procedure instruction on https://duet3d.dozuki.com/Wiki/Installing_and_Updating_FirmwareI am now stumpted How can I resolve this?
This is the result of M122.
SENDING:M122
Used output buffers: 1 of 32 (1 max)
RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.0 or 1.01 + DueX5
Board ID: 08DAM-999TL-NL5T8-6J1DL-3SJ6P-T65BJ
Static ram used: 16152
Dynamic ram used: 100440
Recycled dynamic ram: 2192
Stack ram used: 3576 current, 4456 maximum
Never used ram: 7832
Last reset 00:00:13 ago, cause: power up
Last software reset at 2018-03-12 17:04, reason: User, spinning module GCodes, available RAM 7768 bytes (slot 2)
Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
Error status: 0
Free file entries: 10
SD card 0 detected, interface speed: 12.0MBytes/sec
SD card longest block write time: 0.0ms
MCU temperature: min 18.1, current 21.3, max 21.4
Supply voltage: min 0.0, current 0.0, max 0.0, under voltage events: 0, over voltage events: 0
Driver 0: ok, SG min/max not available
Driver 1: ok, SG min/max not available
Driver 2: ok, SG min/max not available
Driver 3: ok, SG min/max not available
Driver 4: ok, SG min/max not available
Driver 5: ok, SG min/max not available
Driver 6: ok, SG min/max not available
Driver 7: ok, SG min/max not available
Driver 8: ok, SG min/max not available
Driver 9: ok, SG min/max not available
Expansion motor(s) stall indication: yes
Slowest main loop (seconds): 0.000242; fastest: 0.000047
MaxReps: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
Bed compensation in use: none
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is ready with "M122" in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
HTTP sessions: 0 of 8- WiFi -
Network state is disabled
WiFi module is disabled
Failed messages: pending 2779096485, notready 2779096485, noresp 2779096485
=== Expansion ===
DueX I2C errors 0
- WiFi -
This is after re-enabling M552 S1 in config
=== Network ===
Network state is starting
=== Expansion ===
DueX I2C errors 0
- WiFi -
resolved
For some reason it appears that the WiFi server had not started.
re-installed and now all OK. -
It is alright changing stuff around, but how do you raise your Z when you have a bed crash, and all you get is
M120
G91
G1 Z5 F6000
M121
Error: Pop(): stack underflow!and Yes I do have S2 in the files.
Those messages indicate that the printer was not homed when you ran that command. I guess you powered the machine down when you had the crash and then powered it up again. Possible actions in this situation include;
- Home the printer. The homall file for a Cartesian or CoreXY printer normally raises the head a few mm before it does anything else.
- Use M564 H0 to allow movement before axes are homed, either in config.g if you want it to be permanent, or temporarily
- Use a macro to raise the head by 5mm, using S2 on the G1 Z command
I am getting
Request TimeoutThe last HTTP request has timed out. Please make sure the connection between your device and the board is not interrupted.
Anytime I go into G-Code Files then into a Directory with lots of files. I get a spinney icon then
request Timeoutthe files has a * infront of them.
Looks like when I go into a directory that I have not gone into after the patch
Some sort of processing is going on change the * to a page iconSame problem when I upload a large gcode file
when I hit close after uploading
the file show a * and the the Request Timeout -
jnolan72: try to reformat your SD card. I have similar issues from time to time. I think the filesystem on my card just gets fragmented or something - or my card is bad in general.
Copy all your files to you PC. Format & wipe the cards. Make a clean FAT32 filesystem, and copy your files back.
Also make sure to keep not too many files in one folder. There is a limit on how many files the Duet can handle. Less than 50 files per folder usually works for me.
That timeout is triggered when you have a very large gcode file on the SD card and your SD card is formatted with a small cluster size. You can send M39 to find the cluster size if you are running firmware 1.21.
Get a new SD card, format it using FAT16 it is 4Gb or smaller, else FAT32 with 64kb clusters. Then copy all the files and folders over from the old SD card.
Upgrading to firmware 1.21 may also help, if you are running an older version.
