Duet Wifi Webserver not responding
Please try RC4 of DuetWiFiServer, by following this link https://github.com/dc42/DuetWiFiSocketServer/blob/dev/Release/DuetWiFiServer-1.21RC4.bin and then pressing Download.
Got it! I will report back tomorrow.
I didn't get as much testing in today as I'd hoped, but I haven't seen any connection resets so far. Yesterday it was as often as 10 minutes, or as rare as 6 hours. I've had about 2 hours of prints so far today, so… looking good so far?
Does the DuetEthernet still use this, or is there something else equivalent that we DuetEthernet folk should be trying out?
Duet Ethernet doesn't use the DuetWiFiServer.bin file. If you are getting disconnections on the Duet Ethernet and they only happen when you are homing the printer or when printing a file, run M122 after you reconnect and check the MaxReps figure in the report. Note: MaxReps gets reset back to zero after you run M122.
I think my disconnects have all been during print processes, but I'm not super confident in that statement. I will look into the maxreps thing. While I'm waiting for another disconnect event, can you explain what the maxreps means? And is any non-zero value bad, or…?
MaxReps figures above about 50 are bad. The value gives an indication of the interrupt load of the step pulse generator. If it gets too high then the http responder gets starved of CPU time.
Got it, thanks.
I just had an ethernet drop out, and when I did an M122 afterwards, I got a maxreps of 4. So I'm guessing that's not my problem…
Sad news on my front. I'm still seeing the web console stop responding on 1.21RC4. Looks like the same issue still. The packet trace shows the same pattern as before (HTTP GET followed immediately by a connection reset) and the console indicates the same message ("refused conn on port 80 no free conn").
I tried to do an [c]M586 P0 S0[/c]/[c]S1[/c] cycle and it looks like it might have crashed the WiFi module. My print froze and I got this on the console:
M586 P0 S0 HTTP is disabled ok WiFi: ESP reported status change WiFi: Soft WDT reset ESP reported status change WiFi: WiFi: ctx: cont WiFi: sp: 3fff2fc0 end: 3fff32c0 offset: 01b0 WiFi: WiFi: >>>stack>>> WiFi: 3fff3170: 40233576 00000030 0000001c 40225893 WiFi: 3fff3180: 40225d11 3fff6cac 3fff5b3c 40225a2b WiFi: 3fff3190: 00000003 3fff31d0 00000000 40105f8d WiFi: 3fff31a0: 00000050 000000ff 00000000 00000000 WiFi: 3fff31b0: 3fff2125 3fff2190 3fff2194 00000000 WiFi: 3fff31c0: 00000000 3fff211c 3fff1900 40106542 WiFi: 3fff31d0: 00000000 005000ff 20000000 00000000 WiFi: 3fff31e0: 00000000 3fffc6fc 00000001 3fff22a0 WiFi: 3fff31f0: 00000000 3fffdad
You could use M552 S0/S1 instead of M586, worked for me every time without problems during printing. (probably used 30+ times)
I'm still on 1.21.RC1 and had no wifi problems in the last 2 weeks.
I just installed my PanelDue and added two macros for disabling/enabling wifi, so i can restart it without connecting the usb. -
I'm sorry to hear you are still having problems. Have you confirmed that you are running version 1.21RC4 of both the main firmware and the wifi firmware? Look on the Settings->General page of DWC to check.
You could try downloading and installing DuetWiFiServer 1.21RC4 again, in case the file got corrupted somewhere.
Here's what DWC says I'm running right now:
Firmware Version: 1.21RC4 (2018-03-11 build 1) WiFi Server Version: 1.21RC4(08b3) Web Interface Version: 1.21-RC4
I will re-download and re-flash and report back.
Confirmed it still stops responding.
New conn on socket 7 for local port 80 HTTP connection accepted Found responder Received 459 bytes Sending reply, file = no HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=3 } WiFi: ../src/Listener.cpp(62): refused conn on port 80 no free conn WiFi: ../src/Listener.cpp(62): refused conn on port 80 no free conn WiFi: ../src/Listener.cpp(62): refused conn on port 80 no free conn WiFi: ../src/Listener.cpp(62): refused conn on port 80 no free conn WiFi: ../src/Listener.cpp(62): refused conn on port 80 no free conn WiFi: ../src/Listener.cpp(62): refused conn on port 80 no free conn WiFi: ../src/Listener.cpp(62): refused conn on port 80 no free conn WiFi: ../src/Listener.cpp(62): refused conn on port 80 no free conn
Thanks, that gives me an idea of where to look. Do you use either FTP or Telnet, or just the web interface?
I'll add more debugging in RC5 so that M122 dumps the state of all the connections.
Just the web interface. Do you want me to test something on the others as well? (Or are you just wondering whether something else is also consuming sockets?)
I was wondering whether FTP or Telnet was consuming sockets.
I've completed version 1.21RC5 of the main firmware, so I'll look at why the wifi firmware might be running out of connections now.
I have just added DuetWiFiServer.bin version 1.21RC5 to the RRF 1.21RC5 files at https://github.com/dc42/RepRapFirmware/releases/tag/1.21RC5. Please install it on your system. When the problem next occurs, send M111 S1 P14 to enable WiFi debugging (if you haven't already), then send M122. The debug output at the end will include the status of all the connection objects. This should help me determine why none of them is free.
Will do! I'm waiting for a 24-hour print to finish up, so it will be tomorrow.
Any chance you added the remote port numbers to the output? That would help correlate them to a packet trace, and to the client's net state.
So, acknowledging that my issue may not be the same one being primarily discussed in this thread, I still think my issue is due some addressing as well. Would you like me to start a separate thread for it, or…?
If it's different symptoms then a separate thread would be better.
