How to tune Stall Detection?
What I did now is:
I switched to using two stepper drivers (Z and E1) for my Z axis.
I added axes U and V for Z1 and Z2. I zero them when Z is homed so homing does not throw errors.
Changed [c]M915 Z S-10 F0 R1[/c] to [c]M915 P2:4 S-10 F0 R1[/c] just to be sure.What I expected:
Using two drivers instead of one with the motors cinnected in series should double the maximum speed for stall detection. Is this correct?The result:
Even at the very low speed of 5mm/s no false stall detections occur.I am stuck now
Edit:
Now I wrote a gcode script that moves Z up and down with 5mm/s over and over again.
No stalls detected.
When I reduce the current of the motors to 20mA, it stopps moving up (obviously), but still no stalls are detected.
M950 S was -50 during this test! -
Well, no other suggestions?
I need to make this work! -
Are you definitely running 1.20 or 1.21RC series firmware, on a Duet WiFi or Duet Ethernet?
Sure!
What are your Z steps/mm?
It's 400 steps/mm
From comparing other motors, I estimate the inductance of that motor to be about 8 to 10mH. What maximum Z speed at full torque does that give?
I am not 100% sure, if all the other values I have are correct.
I took them from this site: http://www.mytechnologie.de/2017/05/22/projekt-3d-drucker-die-motoren/I suppose by "maximum Z speed at full torque" you mean "Speed at which torque starts to drop (mm/sec), high slip angle".
For 8mH this gives me 32,7mm/s and for 10mH it is 27,9mm/s.
No additional suggestions?
This feature was one of the main reasons for buying the Duet -
Is it just the Z motor that you can't get stall detection working on? Does it work on the X and Y motors? How about U?
It works on X and Y. I tuned the values until I got no more false detections. S22 seems to be the value to go on these axes.
I tried [c]M915 Z S-50 F0 R1[/c] and [c]M915 P2:4 S-50 F0 R1[/c] for Z but never got stall detections on drives other than 0 and 1 (X and Y).
I have added this to my list of pending investigations. I should get to it before the end of this coming week.
Great, thank you!
Any news on this already?
Do you have one Z motor or two? If you have two, how are they connected?
See this post: https://www.duet3d.com/forum/thread.php?pid=37997#p37997
If you run M915 without parameters, what stall detect configurations does it report for drivers 2 and 4?
The console does not show the whole response. Seems to be too long:
Driver 0: stall threshold 23, filter off, steps/sec 200, coolstep 0, action: log
Driver 1: stall threshold 23, filter off, steps/sec 200, coolstep 0, action: log
Driver 2: stall threshold -10, filter off, steps/sec 200, coolstep 0, action: log
Driver 3: s -
You can send M915 D# where # is the drive number, to report the settings for a single drive.
