How to tune Stall Detection?
Stall detection is only enabled when printing a GCode file. It's not really possible to test it any other way, because you need the variety of moves that you get in a print to test it properly.
The mapping of axes to drivers is determined by the M584 command. Send M584 with no parameters to show the existing parameters.
If your Z axis never trigger stall detection, it probably means that your Z axis speed is configured such the the back emf of the motor is greater than the driver supply voltage at that speed. See https://duet3d.com/wiki/Choosing_stepper_motors#How_to_work_out_the_power_supply_voltage_you_need (there is a link to a spreadsheet at the end).
So this means, Z is simply to fast?
Use the link in my previous post to work out whether Z is too fast for stall detection to work, or not.
Unfortunately I do not know all the required information because there is no chart with all specifications available for my stepper motors. These are Anet 42SHDC3025-24B motors.
Phase inductance is the one that is missing.I entered all values I know (left phase inductance as it was) and got these results:
[c]Speed at which torque starts to drop (mm/sec), low slip angle 22,3
Step pulse frequency at this speed and x16 microstepping 8,9
Speed at which torque starts to drop (mm/sec), high slip angle 29,7
Step pulse frequency at this speed and x16 microstepping 11,9
[/c]So the maximum speed for stall detection should be 22,3 mm/s, right?
My Z axis speed is 16.7mm/s but I never got a false stall detection with M915 Z S-10 F0 R1.
Is this possible? I would like to make sure it works. -
You really do need the phase inductance. To estimate it, search a good range of stepper motors (e.g. the ones at stepperonline.com) for another Nema 17 motor with the same length and a similar phase resistance and rated current.
Well I tried to find similar stepper motors or other sources for the required information. After several hours I gave up now. I wrote the Anet support an email but to be honest, I do net expect to get a useful answer.
So I could reduce the speed and try to find a speed where I get false stall reports, reduce the speed even more (additional -2mm/s or so) and tune the S value again. Would this work to give me precise stall detection?
What I did now is:
I switched to using two stepper drivers (Z and E1) for my Z axis.
I added axes U and V for Z1 and Z2. I zero them when Z is homed so homing does not throw errors.
Changed [c]M915 Z S-10 F0 R1[/c] to [c]M915 P2:4 S-10 F0 R1[/c] just to be sure.What I expected:
Using two drivers instead of one with the motors cinnected in series should double the maximum speed for stall detection. Is this correct?The result:
Even at the very low speed of 5mm/s no false stall detections occur.I am stuck now
Edit:
Now I wrote a gcode script that moves Z up and down with 5mm/s over and over again.
No stalls detected.
When I reduce the current of the motors to 20mA, it stopps moving up (obviously), but still no stalls are detected.
M950 S was -50 during this test! -
Well, no other suggestions?
I need to make this work! -
Are you definitely running 1.20 or 1.21RC series firmware, on a Duet WiFi or Duet Ethernet?
Sure!
What are your Z steps/mm?
It's 400 steps/mm
From comparing other motors, I estimate the inductance of that motor to be about 8 to 10mH. What maximum Z speed at full torque does that give?
I am not 100% sure, if all the other values I have are correct.
I took them from this site: http://www.mytechnologie.de/2017/05/22/projekt-3d-drucker-die-motoren/I suppose by "maximum Z speed at full torque" you mean "Speed at which torque starts to drop (mm/sec), high slip angle".
For 8mH this gives me 32,7mm/s and for 10mH it is 27,9mm/s.
No additional suggestions?
This feature was one of the main reasons for buying the Duet -
Is it just the Z motor that you can't get stall detection working on? Does it work on the X and Y motors? How about U?
It works on X and Y. I tuned the values until I got no more false detections. S22 seems to be the value to go on these axes.
I tried [c]M915 Z S-50 F0 R1[/c] and [c]M915 P2:4 S-50 F0 R1[/c] for Z but never got stall detections on drives other than 0 and 1 (X and Y).
I have added this to my list of pending investigations. I should get to it before the end of this coming week.
Great, thank you!
Any news on this already?
