D3 magnetic encoder/1hcl max rpm
What would be the maximum motor rpm and are there factors that contribute to it?
Thanks -
@3DPMicro the maximum motor RPM in closed loop mode is generally lower than in open loop mode and is heavily influenced by the motor inductance (lower is better) and supply voltage (higher is better).
@dc42 thank you.
