smarteffector v2 sensitivity not stored
@dc42 can you confirm me, what version of fw from https://github.com/Duet3D/SmartEffectorFirmware/releases should I flash to this board.
thanks in advance
@apak use 2.13. Choose the binary for the version2 hardware.
@apak and what app and board should I configure asuming I have a arduino UNO
also have this little fellow
@apak there are several videos about this, search for "Arduino as isp". For example, https://www.youtube.com/watch?v=TtC6crf_EP4 (this is not a recommendation, I haven't watched all of it).
undefined apak referenced this topic
I didn´t wait for the popo pins to arrive, so I soldered some pins and used a Arduino UNO as Arduino ISP Programer, with avrdudes and upload he .hex file you mentioned.At detect (before uploading) it had a checksum mismatch, but I forced the upload and had that log below.
Is it there and way to know what version of fw it uploaded on a smarteffecto?
How could I know it was flashed ok? Maybe with a new M command such as M672 S99:99 that was included in fw 2.13?
I was only able this morning to plug the 8 pin plug and the smarteffector flashed 2 times, but couldnt test any more, had to leave to work
@apak Update, It did not flash ok. I set a sensitibity other that stock, power cicle and only 2 led flashing
Succesfully updated to 2.13 and solder pad restored
thanks
@apak Well done! What did you change to get it to flash? And does it now store the sensitivity?
@droftarts i didn’t use the arduino uno.
Now once changed sensitibity, if power cicle led blinks 3 timesWill upload tomorrow destiled instructions
Recap: Old smarteffector v2 that does not remember sensitivity custom settings.
Solution: Flash new firmware V2.13 via PROG pin pads on top board side.
Procedure: Solver pin strip to exposed pads and use a direct pin to pin cable from the ISP port on programer
Programed with a FT232r programer with AVRDUDES app
can change it to SOLVE
undefined dc42 has marked this topic as solved
