sam-ba 21 driver
hello everyone. i have a problem with the panelduet. i always have a white screen and if i connect it to the pc it says usb not recognized so i cant flash it with bossa. the problem is that i cant find the sam-ba windows drivers. any link on the net doesnt work anymore. can you help me anymore? thanks
@leodege which version PanelDue? Have you pressed the Erase button and then the Reset button?
What message if any do you get from the PC when you connect the USB cable?
If Bossa can't flash it because the Bossa port is not coming up on the PC then SAM-BA won't either.
For reference here are the instructions for updating the PD firmware.
https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_PanelDue
When it's showing the white screen do you hear any beeps when you touch the screen as if you were pressing buttons? This would assume that the firmware hasn't already been cleared.
