Sovol SV08 Multiple Motion System Upgrade.
@dwuk obviously removing the backlash is the best solution. however there is backlash compensation in the firmware:
https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m425-configure-backlash-compensation -
@T3P3Tony Thanks -
By changing the Motor Pulleys - from 16 teeth to 20 teeth (as per Voron 2.4) and tightening up the belts on front idler mounts I have got the backlash down to between 0.05 to 0.1 - but it is still worse on the V motor the all of the others.
will try backlash compensation too - but after I have got it as small as possible by strengthening up a few of the parts and doing a bit of lubrication.
Plus also I am currently using quite a lot of bolts directly in to 3d prints (using the recent @ThomasSanladerer method) - so will have to add a few more nuts or threaded inserts to tension things up a bit more.
Have also got the @Vector3d Calibration Lantern - as I think I am going to have to get the XY & Z pretty accurate for the two heads to work reliably on the same print.
@dwuk Backlash won't be your primary problem when you use the "outer perimeter in one go" version of your gcode postprocessor.
I wouldn't spend too much time on it now and try to make a working proof of concept first.
You might have to redesign alot anyway, just put it on your ToDo list. -
@o_lampe good point.
I have got the backlash down to <0.1mm and it seems to be related somehow to the movement of the V axis.
Setting backlash compensation to 0.1mm on U and V with an S value of 1 seems to more or less mitigate it.
Also if it is related to the V axis then the move to dual Y + dual V would greatly simplify the belt structure for those Axis - so I moved last night back to looking at auto alignment with the ball probe, and will today start doing some printing of the Vector3d alignment lantern on both gantries (using duplicate mode).
Will also start moving the 3d printed parts away from mostly bolts into shaped plastic holes into threaded inserts (which I have always avoided in the past).
Built a Vector3d VLP2 over the last couple of days which was a fun project.
Got some good advice from 'Ken' on the Vector3d discord - so I think my immediate priorities now are:
- Consistent auto XYZ alignment using a ball probe - with XY checked using CXC.
- Keeping X&Y alignment across a large area of the build surface. - maybe I will just print a simple large squares for this and adjust steps/mm if necessary - and leave the Lantern until later as you suggest.
- Bed level Mesh adjustment - if necessary - (not sure how flat my bed is yet).
- 2 Colour IDEX testing
- Parallel printing of separate Models
- Parallel printing on a single model.
In terms of other steps already completed:
- PID tuning done for the print heads - but I did get a warning message on the heat bed some will have to sort that out at some point.
- E Steps done
- Z Offset done - although quite a lot more gcode post processing work needed on this - as my print head have independent extra Z axis adjustment capabilities for independent Z hopping and mesh adjustment.
Will then I think do:
7) Speed and acceleration tuning
8 ) Adding print heads 3 & 4 - and repeating most of the above. - my 2nd Mini5+ board ended up being V1.3 luckily - so no desoldering needed:)
9) Fan cooling - I had to take off one of the cooling fans from each head due to Duet tool board connection issues (plus print head size) - think I will try running extra cables for the 2nd cooling fans direct from the main boards.- Retraction
- Input shaping
- Pressure advance
- Advanced calibration using Vector3d Lantern.
- Z hopping and multi head mesh adjustment
- Tool changer - probably just two extra tools initially on the front gantry
- Filament management - which will probably need some sort of custom AMS/MMU to be developed - that can handle splitting spools into up to 4 separate strands for the 4 print head parallel prints and occasional colour swaps that can't be accommodated by the tool changer part of the printer.
Having a few problems with Multiple motion system - I think I am going to need some @dc42 help.
On 3.5.4 - It works ok with some basic commands as below:
With both gantries moving in parallel in different directions ok.M595 Q1 P5 M595 Q0 P5 M596 P1 G90 G1 U100 F500 G1 U200 F500 G1 V300 F500 G1 V250 F500 M596 P0 G1 X200 F2000 G1 X100 F2000 M598 G1 Y20 F1000 G1 Y50 F1000 G1 X200 F2000 G1 X100 F2000
However Problems are:
- M598 does not seem to work - as the G1 Y20 F1000 just carries on - even though the U axis moves haven't completed.
- If I set the Queue size above 5 the motion in Queue 1 (M596 P1) - G1 moves goes haywire - just doing a G1 U1 for example moves the gantry to the back and beyond with a grating sound.
I noted that on the 3.6.0 beta4 notes that there is mention of some sort of M598 fix - so tried a firmware upgrade to that version.
Firstly this resulted in me somehow tanking my 6HC firmware completely so I had to erase and reset it back to 3.5.4, then I also messed up the Mini5+ firmware too somehow - so again had to erase and reset it.
Eventually got it working again, and managed to do the 3.6.0 Beta Change on all boards.
Problem then with 3.6.0 beta 4 - was:
My homeall.g sequence no longer worked - it seemed to just to X and Y then stop - so I had to individually home each axis.
Also The U & V axis homing didn't seem to move the same - I am using switches - but I wonder if there is some sort of hangover from when I tried to get it to work on sensorless (which I would still quite like to do) - as the ball probe alignment would probably now be good enough. -
I then kept getting messages about the U axis already being in use when I ran the test script that worked ok on 3.5.4 (apart from M598 and M595 issues).
So decided to revert back to 3.5.4 and ask for help.
Config.g
; Configuration file for RepRapFirmware on Duet 3 Main Board 6HC ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.5.10 on Wed Jan 29 2025 10:20:21 GMT+0000 (Greenwich Mean Time) ; General G90 ; absolute coordinates M83 ; relative extruder moves M550 P"Duet 3" ; set hostname ; Network M552 P0.0.0.0 S1 ; configure Ethernet adapter M586 P0 S1 ; configure HTTP M586 P1 S1 ; configure FTP ; Wait a moment for the CAN expansion boards to become available G4 S2 ; Smart Drivers M569 P0.0 S1 D2 ; driver 0.0 goes forwards (Z axis) M569 P0.1 S1 D2 ; driver 0.1 goes forwards (Z axis) M569 P0.2 S0 D2 ; driver 0.2 goes backwards (Z axis) M569 P0.3 S1 D2 ; driver 0.3 goes forwards (X axis) M569 P0.4 S0 D2 ; driver 0.4 goes backwards (Y axis) M569 P0.5 S0 D2 ; driver 0.5 goes backwards (Z axis) M569 P1.0 S0 D3 V2000 ; driver 1.0 goes backwards (U axis) M569 P1.1 S0 D3 V2000 ; driver 1.1 goes backwards (V axis) M569 P1.2 S1 D2 ; driver 1.2 goes forwards (A axis) M569 P1.3 S1 D3 ; Z-hopper 1 M569 P1.4 S1 D3 ; Z-hopper 2 M569 P121.0 S0 D2 ; driver 121.0 goes backwards (extruder 0) M569 P122.0 S0 D2 ; driver 122.0 goes backwards (extruder 1) ; Motor Idle Current Reduction M906 I30 ; set motor current idle factor M84 S30 ; set motor current idle timeout ; Axes M584 X0.3 Y0.4 Z0.1:0.2:0.0:0.5 U1.0 V1.1 A1.2 B1.3 C1.4; set axis mapping M350 X16 Y16 Z16 U16 V16 A16 B16 C16 I1 ; configure microstepping with interpolation M906 X800 Y800 Z800 U800 V800 A800 B150 C50 ; set axis driver currents M92 X80 Y80 Z533.33 U80 V80 A533 B629 C629 ; configure steps per mm if exists(global.vMin) == false global vMin = 120 global vMax = 330 global yMin = -5 global yMax = 210 M208 X0:315 Y-5:210 Z0:300 U35:350 V120:330 A0:300 B0:3 C0:3 ; set minimum and maximum axis limits M566 X12000 Y12000 Z3000 U6000 V6000 A3000 B1000 C1000 ; set maximum instantaneous speed changes (mm/min) M203 X42000 Y42000 Z3000 U21000 V21000 A3000 B1000 C1000 ; set maximum speeds (mm/min) M201 X500 Y500 Z20 U250 V250 A20 B20 C20 ; set accelerations (mm/s^2) ; Extruders M584 E121.0:122.0 ; set extruder mapping M350 E16:16 I1 ; configure microstepping with interpolation M906 E800:800 ; set extruder driver currents M92 E492:492 ; configure steps per mm M566 E120:120 ; set maximum instantaneous speed changes (mm/min) M203 E3600:3600 ; set maximum speeds (mm/min) M201 E250:250 ; set accelerations (mm/s^2) ; Kinematics M669 K8 ; configure CoreXYUV kinematics ; Probes M558 K0 P8 C"121.io1.in" H5 F1200 T18000 ; configure unfiltered digital probe via slot #0 G31 P500 X-17 Y10 Z2.55 ; set Z probe trigger value, offset and trigger height M558 K1 P8 C"122.io1.in" H5 F1200 T18000 ; configure unfiltered digital probe via slot #1 G31 P500 X-17 Y10 Z2.55 ; set Z probe trigger value, offset and trigger height M558 K2 P8 C"!121.io2.in" H1 F300 T300 ; configure unfiltered digital probe via slot #2 M558 K3 P8 C"io3.in" H1 F300 F300; Ball Probe ; Endstops M574 X1 S3 ; configure X axis endstop M574 Y1 S3 ; configure Y axis endstop M574 Z1 S2 K0; configure Z axis endstop M574 U2 P"!122.io0.in" S1 ; configure U axis endstop M574 V2 P"!122.io2.in" S1 ; configure V axis endstop M574 A1 P"1.io0.in" S1 ; configure A axis endstop M574 B1 S2 K2 ; Sensors M308 S0 P"temp0" Y"thermistor" A"Heated Bed" T100000 B4725 C7.06e-8 ; configure sensor #0 M308 S1 P"121.temp0" Y"thermistor" A"Nozzle" T110000 B4487 C6.95777e-8 ; configure sensor #1 M308 S2 P"122.temp0" Y"thermistor" A"Nozzle2" T110000 B4487 C6.95777e-8 ; configure sensor #2 ; Heaters M950 H0 C"out0" T0 ; create heater #0 M143 H0 P0 T0 C0 S105 A0 ; configure heater monitor #0 for heater #0 M307 H0 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #0 M950 H1 C"121.out0" T1 ; create heater #1 M143 H1 P0 T1 C0 S305 A0 ; configure heater monitor #0 for heater #1 M307 H1 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #1 M950 H2 C"122.out0" T2 ; create heater #2 M143 H2 P0 T1 C0 S305 A0 ; configure heater monitor #0 for heater #2 M307 H2 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #2 ; Heated beds M140 P0 H0 ; configure heated bed #0 ; Fans M950 F0 C"121.out2+out2.tach" ; create fan #0 M106 P0 S0 L0 X1 B0.1 ; configure fan #0 M950 F1 C"121.out1+out1.tach" ; create fan #1 M106 P1 C"Hotend" S0 B0.1 H1 T45 ; configure fan #1 M950 F2 C"122.out2+out2.tach" ; create fan #2 M106 P2 C"E2Cool" S0 L0 X1 B0.1 ; configure fan #2 M950 F3 C"122.out1+out1.tach" ; create fan #3 M106 P3 C"Hotend2" S0 B0.1 H2 T45 ; configure fan #3 ; Tools M563 P0 D0 H1 F0 ; create tool #0 M568 P0 R0 S0 ; set initial tool #0 active and standby temperatures to 0C M563 P1 D1 H2 F2 ; create tool #1 M568 P1 R0 S0 ; set initial tool #1 active and standby temperatures to 0C ; Miscellaneous ; Custom settings M915 X Y U V R0 F0 M671 X410:-60:-60:410 Y420:-10:420:-10 S7 M307 H1 R7.427 K0.701:0.030 D1.50 E1.35 S1.00 B0 V24.5 M307 H2 R7.020 K0.857:0.148 D1.65 E1.35 S1.00 B0 V24.0 M307 H0 R0.527 K0.163:0.000 D5.70 E1.35 S1.00 B0 M557 X0:200 Y0:220 S20 M950 S1 C"122.io0.out" M280 P1 S60 ;M42 P1 S0 ; Allow movement without homing ;M564 S0 H0 ; Tools ;Tool T1 - 2nd Gantry as X and Y M563 P1 D1 H2 X3 Y4 F1 G10 P1 X0 Y0 U0 V0 S0 R0 ; T2 - duplicate mode M563 P2 D0:1 H1:2 X0:3 Y1:4 F0:1 G10 P2 X0 Y0 U0 V-150 S0 R0 M567 P2 E1:1 M568 P2 S1 ; Backlash compensation M425 U0.1 V0.1 S1
@dwuk It would be good to work out why homing was not working as expected in 3.6beta4. Where have been a lot of changes between 3.5.4 and 3.6 so the release notes may explain why. If not then please share your U and V homing files so we can have a look at those.
@dwuk
Your homeu for reference (please use code blocks for these file, it makes it easier for people, especially on phones):
;echo "homeU disabled" ;M99 ; homeu.g ; called to home the U axis M569 P1.0 S0 D3 V500 ; driver 1.0 goes backwards (U axis) M569 P1.1 S0 D3 V500 ; driver 1.1 goes backwards (V axis) ; ; generated by RepRapFirmware Configuration Tool v3.5.10 on Thu Jan 23 2025 15:02:10 GMT+0000 (Greenwich Mean Time) ;M913 U40 V40 ;M400 ; increase Z G91 ; relative positioning if exists(param.Z) ;G1 H2 Z{param.Z} F6000 else G1 H2 Z5 F6000; move Z relative to current position to avoid dragging nozzle over the bed G1 H2 V10 U-10 M400 G90 ; absolute positioning ; home U G91 ; relative positioning var maxTravel = move.axes[0].max - move.axes[0].min + 5 ; calculate how far X can travel plus 5mm G1 H1 U{var.maxTravel} F8000 ; coarse home in the +U direction G1 U-5 F6000 ; move back 5mm G1 H1 U{var.maxTravel} F3000 ; fine home in the +U direction G90 ; absolute positioning ; decrease Z again G91 ; relative positioning ;G1 H2 Z-5 F6000 ; move Z relative to current position G90 ; absolute positioning ;M400 ;M913 U100 V100 ;M400 M569 P1.0 S0 D3 V2000 ; driver 1.0 goes backwards (U axis) M569 P1.1 S0 D3 V2000 ; driver 1.1 goes backwards (V axis)
you are setting U and V configurations in home U. I would remove the references to V in home U.
This is an issue:
given U is not axis 0. It probably working if U and X are the same length though.Also you are lifting Z but not returning it (that may not be an issue)
I see you are switching the speed of switch from stealthChop to to spreadCycle mode during homing. and the U and V are in stealthchop while the other axes are in spreadCycle so i expect thats the route of the issue/different behaviour.
Try getting everything working in spreadCycle and then explore sensor less homing
@T3P3Tony Thanks for the comments.
Had another go on 3.6.0.beta4
With the following motor settings:
;M569 P1.0 S0 D3 V2000 ; driver 1.0 goes backwards (U axis) ;M569 P1.1 S0 D3 V2000 ; driver 1.1 goes backwards (V axis) M569 P1.0 S0 D2; driver 1.0 goes backwards (U axis) M569 P1.1 S0 D2 ; driver 1.1 goes backwards (V axis)
And the following homeU
G91 ; relative positioning if exists(param.Z) ;G1 H2 Z{param.Z} F6000 else G1 H2 Z5 F6000; move Z relative to current position to avoid dragging nozzle over the bed ; G1 H2 V10 U-10 F6000 M400 ; var maxTravel = move.axes[0].max - move.axes[0].min + 5 ; calculate how far X can travel plus 5mm G1 H1 U{var.maxTravel} F8000 ; coarse home in the +U direction M400 G1 U-5 F6000 ; move back 5mm M400 G1 H1 U{var.maxTravel} F3000 ; fine home in the +U direction G90 ; absolute positioning
And homeV
G91 ; relative positioning if exists(param.Z) ;G1 H2 Z{param.Z} F6000 else G1 H2 Z5 F6000; move Z relative to current position to avoid dragging nozzle over the bed var maxU = move.axes[4].max - 5 G90 ; absolute positioning G1 U345 ; home V G91 ; relative positioning var maxTravel = move.axes[0].max - move.axes[0].min + 5 ; calculate how far V can travel plus 5mm G1 H1 V{var.maxTravel} F6000 ; coarse home in the +V direction G1 V-5 F6000 ; move back 5mm G1 H1 V{var.maxTravel} F7000 ; fine home in the +V direction G90 ; absolute positioning ; decrease Z again G91 ; relative positioning ;G1 H2 Z-5 F6000 ; move Z relative to current position G1 V-10 U-10 G90 ; absolute positioning
Results were:
On 3.6.0b4 the U and V axis (which are on the toolboard mode Mini5+) are moving - but are unresponsive - they don't move instantly like they do on 3.5.4 (went back and rechecked), and the two stage homing takes quite a while to get to the 2nd stage. (unlike 3.5.4 where it is instant).Also the V Axis homing sometimes misses the end stop (which is at the back right) - probably due to slow reaction too - when I use HomeAll.
Also when you just use the button's to move the U & V - they don't react instantly - so I am wondering where there is some sort of comms issue in 3.6.0b4 - as I don't notice this in 3.5.4
X&Y (which are directly connected to the 6HC) still seem ok on 3.6.0b4
Also I am still getting the issue with not being able to access the U axes within M596 P1 - which doesn't occur in 3.5.4
Tried doing the homing within M596 P1 for U&V. and M596 P0 for X&Y - and that failed because Z was then stuck in P1 - and couldn't be accessed in P0.
In response to your points:
"you are setting U and V configurations in home U. I would remove the references to V in home U."- Would be good if I could - the main reason it is there is that in my current microswitch based design the V axis switch gets knocked sideways if the U axis tries to home when V is too far to the back.
"This is an issue:
given U is not axis 0. It probably working if U and X are the same length though."- Agreed that is an issue which I will correct - however as I have set the minimum for U at 30 - then it is slightly shorter than X - so the end stop will still hit.
"Also you are lifting Z but not returning it (that may not be an issue)"
- Agreed need to tidy up Z lifting
"I see you are switching the speed of switch from stealthChop to to spreadCycle mode during homing. and the U and V are in stealthchop while the other axes are in spreadCycle so i expect thats the route of the issue/different behaviour."
- Removed the settings in config.g - tried both modes - but still got the slow reaction problem in 3.6.0b4 - and still works fine with the new settings in 3.5.4
"Try getting everything working in spreadCycle and then explore sensor less homing"
I've switched back to 3.5.4 again for now - as the slow response of U and V on 3.6.0b4 are I think too much of an issue. I could try a different version - to which beta version it starts to appear. -
@dwuk Further update; @T3P3Tony
Tried with 3.6.0b3 - same issue with slow response of U&V
Tried reverting just the Mini5+ to 3.5.3 - that seems to remove the issue.So for me both 3.6.0 beta versions are not working with a FD connected Mini5+
Also on 3.6.0b3 (with 3.5.3 Mini5+) I get the same issue with not being able to access the U axis within M596 P1. - where's with exactly the same macro's and homing sequences I can with 3.5.3
Will go back to 3.6.4b4 again (with both 3.5.3 on the Mini5+) to see if I can work out a sequence that allows me to access the U axis from the 2nd motion system.
@dwuk Further update - got access to the U axis in 3.6.0b4 by surrounding all accesses to it - including in the homing with M596 P1 before and M596 P0 after.
M598 still not working though, plus my Mini5+ is still on 3.5.4.
Short Video showing both heads in motion.
I can't get synchronisation working yet - so not ready to print more than one layer - but nice to at least see the print heads moving independently.
Jay and Andy - this is the thread with more detailed info about my issues @gloomyandy @jay_s_uk
I've got a converted SV08 with a 6HC main board (for Z,X,Y) and Mini5+ as tool board (for UV and Z Hoppers), and then 1LC boards for the extruders.
The system currently has 2 gantries and 2 extruders - but I am aiming to make both of the gantries IDEX once I have got the basic system working.
I'm aiming to parallel print with up to 4 heads at the same time - initially using a GCODE post processor to split each layer into segments that can be printed in parallel.
Horrible print quality I know because I didn't get the Z height quite right on the back gantry, plus it seems to have come loose a bit, plus had to comment out two lines of Gcode out due to Multiple Motion System gantry conflicts - which is why I think the front gantry print messed out.
Also had to manually set temperatures as haven't properly programmed them into the tool changing macros.
But still this is my first dual head, 4 segment print.
With the post processor created segment boundary crossing the 45 square on the back gantry.
@dwuk Still looking good for a first attempt. I guess you had mesh levelling off?
Maybe try to dial in each toolhead independently with unaltered single-head gcode. When both work OK on their own, let them cooperate. -
@o_lampe thanks. It was a pretty poor quality first test I agree, but it was nice to see both heads actually printing something independently.
The rear head had come quite loose which is why the lines are a bit curved- so I have upgraded the bolts that hold the two linear rails together.
Also I had specified ABS instead of PLA in the material profile in Orcaslicer which explains why the extruders kept wanting to go up to 260 and the bed was hotter than it usually is.
Will look at mesh levelling fairly soon.
Will do another attempt in the next couple of days once I have made some corrections to the parallel print gcode post processor.
Won't be able to get beyond layer2 though until I have resolved my RRF MMS M598 sync issue.
I tried working around it with conditional rrf gcode with loops and dwells - but haven't found a reliable way to get the motion systems to wait for each other yet.
@dwuk said in Sovol SV08 Multiple Motion System Upgrade.:
There are known synchronisation issues in 3.6beta releases including beta 4 when a main board is used in expansion mode. These have now been resolved.
@dc42 great - look forward to getting access to the fixed version.
The biggest issue that leaves me with is that I can't seem to get M598 to work in any version I have tried.
I am sending commands in the sequence
M596 P1
G1....setA
M596 P0
G1...setB
M598
G1...setC (with or without M596 P0)When SetB is faster than SetA - I am finding setC moves start before setA moves are complete -which is not the behaviour I was hoping for.
undefined dwuk3d referenced this topic
@dc42 Update - solved my M598 not working issue hopefully.
So far (apart from the poor quality test print) I have been running all my tests with the gcode. M569/G1/M598 sequences in macro's - that I have been executing standalone.
I noticed that in the documentation it mentions something about macro's only using one stream.
Thought I would try downloading the macro, and then re-uploading it as a job.
Doing this completely changed the behaviour - and in my first few tests it looks like now the M598's seem to be doing what I wanted - i.e. Gantries waiting for each other, things that shouldn't be running in parallel waiting for each other.
So will change to using jobs rather than macro's for all of my future tests.
Also using this approach I have been able to get M597 to accept numbers as high as 30 without the motion all getting messed up - like it did in earlier tests when I went above 6.
However I am not sure whether this is due to the macro vs job differences, or the fact that my system is currently set as V3.6.0b4 on all boards (other than the Mini5+ - that is still on 3.5.4 due to the slow motion issue).
